hal_serial_lld.c
18  * @file hal_serial_lld.c
19  * @brief PLATFORM serial subsystem low level driver source.
21  * @addtogroup SERIAL
27 #if (HAL_USE_SERIAL == TRUE) || defined(__DOXYGEN__)
37 /** @brief USART1 serial driver identifier.*/
38 #if (PLATFORM_SERIAL_USE_USART1 == TRUE) || defined(__DOXYGEN__)
40 #endif
41
43 /* Driver local variables and types. */
45
46 /**
47  * @brief Driver default configuration.
48  */
49 static const SerialConfig default_config = {
50  38400
51 };
52
54 /* Driver local functions. */
56
58 /* Driver interrupt handlers. */
60
61 /*===========================================================================*/
62 /* Driver exported functions. */
63 /*===========================================================================*/
64
65 /**
66  * @brief Low level serial driver initialization.
67  *
68  * @notapi
69  */
70 void sd_lld_init(void) {
71
72 #if PLATFORM_SERIAL_USE_USART1 == TRUE
73  sdObjectInit(&SD1, NULL, notify1);
74 #endif
75 }
76
77 /**
78  * @brief Low level serial driver configuration and (re)start.
79  *
80  * @param[in] sdp pointer to a @p SerialDriver object
81  * @param[in] config the architecture-dependent serial driver configuration.
82  * If this parameter is set to @p NULL then a default
83  * configuration is used.
84  *
85  * @notapi
86  */
87 void sd_lld_start(SerialDriver *sdp, const SerialConfig *config) {
88
89  if (config == NULL) {
90  config = &default_config;
91  }
92
93
94  if (sdp->state == SD_STOP) {
95 #if PLATFORM_SERIAL_USE_USART1 == TRUE
96  if (&SD1 == sdp) {
97
98  }
99 #endif
100  }
101  /* Configures the peripheral.*/
102  (void)config; /* Warning suppression, remove this.*/
103 }
104
105 /**
106  * @brief Low level serial driver stop.
107  * @details De-initializes the USART, stops the associated clock, resets the
108  * interrupt vector.
109  *
110  * @param[in] sdp pointer to a @p SerialDriver object
111  *
112  * @notapi
113  */
115
116  if (sdp->state == SD_READY) {
117 #if PLATFORM_SERIAL_USE_USART1 == TRUE
118  if (&SD1 == sdp) {
119
120  }
121 #endif
122  }
123 }
124
125 #endif /* HAL_USE_SERIAL == TRUE */
126
127 /** @} */
SerialDriver SD1
Full duplex serial driver class.
Definition: hal_serial.h:123
void sdObjectInit(SerialDriver *sdp, qnotify_t inotify, qnotify_t onotify)
Initializes a generic full duplex driver object.
Definition: hal_serial.c:158
void sd_lld_stop(SerialDriver *sdp)
PLATFORM Serial Driver configuration structure.
