hal_serial.c
18  * @file hal_serial.c
19  * @brief Serial Driver code.
21  * @addtogroup SERIAL
27 #if (HAL_USE_SERIAL == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
45 /*
46  * Interface implementation, the following functions just invoke the equivalent
47  * queue-level function or macro.
48  */
49
50 static size_t _write(void *ip, const uint8_t *bp, size_t n) {
51
52  return oqWriteTimeout(&((SerialDriver *)ip)->oqueue, bp,
53  n, TIME_INFINITE);
54 }
55
56 static size_t _read(void *ip, uint8_t *bp, size_t n) {
57
58  return iqReadTimeout(&((SerialDriver *)ip)->iqueue, bp,
59  n, TIME_INFINITE);
60 }
61
62 static msg_t _put(void *ip, uint8_t b) {
63
64  return oqPutTimeout(&((SerialDriver *)ip)->oqueue, b, TIME_INFINITE);
65 }
66
67 static msg_t _get(void *ip) {
68
69  return iqGetTimeout(&((SerialDriver *)ip)->iqueue, TIME_INFINITE);
70 }
71
72 static msg_t _putt(void *ip, uint8_t b, sysinterval_t timeout) {
73
74  return oqPutTimeout(&((SerialDriver *)ip)->oqueue, b, timeout);
75 }
76
77 static msg_t _gett(void *ip, sysinterval_t timeout) {
78
79  return iqGetTimeout(&((SerialDriver *)ip)->iqueue, timeout);
80 }
81
82 static size_t _writet(void *ip, const uint8_t *bp, size_t n,
83  sysinterval_t timeout) {
84
85  return oqWriteTimeout(&((SerialDriver *)ip)->oqueue, bp, n, timeout);
86 }
87
88 static size_t _readt(void *ip, uint8_t *bp, size_t n,
89  sysinterval_t timeout) {
90
91  return iqReadTimeout(&((SerialDriver *)ip)->iqueue, bp, n, timeout);
92 }
93
94 static msg_t _ctl(void *ip, unsigned int operation, void *arg) {
95  SerialDriver *sdp = (SerialDriver *)ip;
96
97  osalDbgCheck(sdp != NULL);
98
99  switch (operation) {
100  case CHN_CTL_NOP:
101  osalDbgCheck(arg == NULL);
102  break;
103  case CHN_CTL_INVALID:
104  osalDbgAssert(false, "invalid CTL operation");
105  break;
106  default:
107 #if defined(SD_LLD_IMPLEMENTS_CTL)
108  /* Delegating to the LLD if supported.*/
109  return sd_lld_control(sdp, operation, arg);
110 #else
111  break;
112 #endif
113  }
114  return MSG_OK;
115 }
116
117 static const struct SerialDriverVMT vmt = {
118  (size_t)0,
119  _write, _read, _put, _get,
120  _putt, _gett, _writet, _readt,
121  _ctl
122 };
123
124 /*===========================================================================*/
125 /* Driver exported functions. */
126 /*===========================================================================*/
127
128 /**
129  * @brief Serial Driver initialization.
130  * @note This function is implicitly invoked by @p halInit(), there is
131  * no need to explicitly initialize the driver.
132  *
133  * @init
134  */
135 void sdInit(void) {
136
137  sd_lld_init();
138 }
139
140 /**
141  * @brief Initializes a generic full duplex driver object.
142  * @details The HW dependent part of the initialization has to be performed
143  * outside, usually in the hardware initialization code.
144  *
145  * @param[out] sdp pointer to a @p SerialDriver structure
146  * @param[in] inotify pointer to a callback function that is invoked when
147  * some data is read from the Queue. The value can be
148  * @p NULL.
149  * @param[in] onotify pointer to a callback function that is invoked when
150  * some data is written in the Queue. The value can be
151  * @p NULL.
152  *
153  * @init
154  */
155 #if !defined(SERIAL_ADVANCED_BUFFERING_SUPPORT) || \
156  (SERIAL_ADVANCED_BUFFERING_SUPPORT == FALSE) || \
157  defined(__DOXYGEN__)
158 void sdObjectInit(SerialDriver *sdp, qnotify_t inotify, qnotify_t onotify) {
159
160  sdp->vmt = &vmt;
161  osalEventObjectInit(&sdp->event);
162  sdp->state = SD_STOP;
163  iqObjectInit(&sdp->iqueue, sdp->ib, SERIAL_BUFFERS_SIZE, inotify, sdp);
164  oqObjectInit(&sdp->oqueue, sdp->ob, SERIAL_BUFFERS_SIZE, onotify, sdp);
165 }
166 #else
167 void sdObjectInit(SerialDriver *sdp) {
168
169  sdp->vmt = &vmt;
170  osalEventObjectInit(&sdp->event);
171  sdp->state = SD_STOP;
172 }
173 #endif
174
175 /**
176  * @brief Configures and starts the driver.
177  *
178  * @param[in] sdp pointer to a @p SerialDriver object
179  * @param[in] config the architecture-dependent serial driver configuration.
180  * If this parameter is set to @p NULL then a default
181  * configuration is used.
182  *
183  * @api
184  */
185 void sdStart(SerialDriver *sdp, const SerialConfig *config) {
186
187  osalDbgCheck(sdp != NULL);
188
189  osalSysLock();
190  osalDbgAssert((sdp->state == SD_STOP) || (sdp->state == SD_READY),
191  "invalid state");
192  sd_lld_start(sdp, config);
193  sdp->state = SD_READY;
194  osalSysUnlock();
195 }
196
197 /**
198  * @brief Stops the driver.
199  * @details Any thread waiting on the driver's queues will be awakened with
200  * the message @p MSG_RESET.
201  *
202  * @param[in] sdp pointer to a @p SerialDriver object
203  *
204  * @api
205  */
206 void sdStop(SerialDriver *sdp) {
207
208  osalDbgCheck(sdp != NULL);
209
210  osalSysLock();
211
212  osalDbgAssert((sdp->state == SD_STOP) || (sdp->state == SD_READY),
213  "invalid state");
214
215  sd_lld_stop(sdp);
216  sdp->state = SD_STOP;
217  oqResetI(&sdp->oqueue);
218  iqResetI(&sdp->iqueue);
220
221  osalSysUnlock();
222 }
223
224 /**
225  * @brief Handles incoming data.
226  * @details This function must be called from the input interrupt service
227  * routine in order to enqueue incoming data and generate the
228  * related events.
229  * @note The incoming data event is only generated when the input queue
230  * becomes non-empty.
231  * @note In order to gain some performance it is suggested to not use
232  * this function directly but copy this code directly into the
233  * interrupt service routine.
234  *
235  * @param[in] sdp pointer to a @p SerialDriver structure
236  * @param[in] b the byte to be written in the driver's Input Queue
237  *
238  * @iclass
239  */
240 void sdIncomingDataI(SerialDriver *sdp, uint8_t b) {
241
243  osalDbgCheck(sdp != NULL);
244
245  if (iqIsEmptyI(&sdp->iqueue))
247  if (iqPutI(&sdp->iqueue, b) < MSG_OK)
249 }
250
251 /**
252  * @brief Handles outgoing data.
253  * @details Must be called from the output interrupt service routine in order
254  * to get the next byte to be transmitted.
255  * @note In order to gain some performance it is suggested to not use
256  * this function directly but copy this code directly into the
257  * interrupt service routine.
258  *
259  * @param[in] sdp pointer to a @p SerialDriver structure
260  * @return The byte value read from the driver's output queue.
261  * @retval MSG_TIMEOUT if the queue is empty (the lower driver usually
262  * disables the interrupt source when this happens).
263  *
264  * @iclass
265  */
267  msg_t b;
268
270  osalDbgCheck(sdp != NULL);
271
272  b = oqGetI(&sdp->oqueue);
273  if (b < MSG_OK)
275  return b;
276 }
277
278 /**
279  * @brief Direct output check on a @p SerialDriver.
280  * @note This function bypasses the indirect access to the channel and
281  * checks directly the output queue. This is faster but cannot
282  * be used to check different channels implementations.
283  *
284  * @param[in] sdp pointer to a @p SerialDriver structure
285  * @return The queue status.
286  * @retval false if the next write operation would not block.
287  * @retval true if the next write operation would block.
288  *
289  * @deprecated
290  *
291  * @api
292  */
294  bool b;
295
296  osalSysLock();
297  b = oqIsFullI(&sdp->oqueue);
298  osalSysUnlock();
299
300  return b;
301 }
302
303 /**
304  * @brief Direct input check on a @p SerialDriver.
305  * @note This function bypasses the indirect access to the channel and
306  * checks directly the input queue. This is faster but cannot
307  * be used to check different channels implementations.
308  *
309  * @param[in] sdp pointer to a @p SerialDriver structure
310  * @return The queue status.
311  * @retval false if the next write operation would not block.
312  * @retval true if the next write operation would block.
313  *
314  * @deprecated
315  *
316  * @api
317  */
319  bool b;
320
321  osalSysLock();
322  b = iqIsEmptyI(&sdp->iqueue);
323  osalSysUnlock();
324
325  return b;
326 }
327
328 /**
329  * @brief Control operation on a serial port.
330  *
331  * @param[in] sdp pointer to a @p SerialDriver object
332  * @param[in] operation control operation code
333  * @param[in,out] arg operation argument
334  *
335  * @return The control operation status.
336  * @retval MSG_OK in case of success.
337  * @retval MSG_TIMEOUT in case of operation timeout.
338  * @retval MSG_RESET in case of operation reset.
339  *
340  * @api
341  */
342 msg_t sdControl(SerialDriver *sdp, unsigned int operation, void *arg) {
343
344  return _ctl((void *)sdp, operation, arg);
345 }
346
347 #endif /* HAL_USE_SERIAL == TRUE */
348
349 /** @} */
#define SERIAL_BUFFERS_SIZE
Serial buffers size.
Definition: hal_serial.h:73
void iqObjectInit(input_queue_t *iqp, uint8_t *bp, size_t size, qnotify_t infy, void *link)
Initializes an input queue.
Definition: hal_queues.c:177
msg_t iqGetTimeout(input_queue_t *iqp, sysinterval_t timeout)
Input queue read with timeout.
Definition: hal_queues.c:304
Definition: hal_serial.c:185
uint64_t sysinterval_t
Type of time interval.
Definition: chtime.h:119
void oqObjectInit(output_queue_t *oqp, uint8_t *bp, size_t size, qnotify_t onfy, void *link)
Initializes an output queue.
Definition: hal_queues.c:446
#define iqIsEmptyI(iqp)
Evaluates to true if the specified input queue is empty.
Definition: hal_queues.h:187
void iqResetI(input_queue_t *iqp)
Resets an input queue.
Definition: hal_queues.c:201
void sdInit(void)
Definition: hal_serial.c:135
bool sdPutWouldBlock(SerialDriver *sdp)
Direct output check on a SerialDriver.
Definition: hal_serial.c:293
#define osalDbgCheckClassI()
I-Class state check.
Definition: osal.h:292
void oqResetI(output_queue_t *oqp)
Resets an output queue.
Definition: hal_queues.c:470
Definition: osal.h:540
msg_t sdRequestDataI(SerialDriver *sdp)
Definition: hal_serial.c:266
void osalOsRescheduleS(void)
Checks if a reschedule is required and performs it.
Definition: osal.c:119
void sd_lld_init(void)
Low level serial driver initialization.
static void osalEventObjectInit(event_source_t *esp)
Initializes an event source object.
Definition: osal.h:665
void sd_lld_start(SerialDriver *sdp, const SerialConfig *config)
Low level serial driver configuration and (re)start.
void(* qnotify_t)(io_queue_t *qp)
Queue notification callback type.
Definition: hal_queues.h:65
const struct SerialDriverVMT * vmt
Virtual Methods Table.
Definition: hal_serial.h:125
size_t oqWriteTimeout(output_queue_t *oqp, const uint8_t *bp, size_t n, sysinterval_t timeout)
Output queue write with timeout.
Definition: hal_queues.c:658
#define oqIsFullI(oqp)
Evaluates to true if the specified output queue is full.
Definition: hal_queues.h:265
#define TIME_INFINITE
Infinite interval specification for all functions with a timeout specification.
Definition: chtime.h:55
msg_t oqPutTimeout(output_queue_t *oqp, uint8_t b, sysinterval_t timeout)
Definition: hal_queues.c:540
Full duplex serial driver class.
Definition: hal_serial.h:123
SerialDriver virtual methods table.
Definition: hal_serial.h:112
Definition: hal_serial.c:342
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
msg_t oqGetI(output_queue_t *oqp)
Output queue read.
Definition: hal_queues.c:581
Definition: hal_serial.c:158
static void osalSysLock(void)
Definition: osal.h:530
bool sdGetWouldBlock(SerialDriver *sdp)
Direct input check on a SerialDriver.
Definition: hal_serial.c:318
void sd_lld_stop(SerialDriver *sdp)
Low level serial driver stop.
Definition: hal_serial.c:240
#define chnAddFlagsI(ip, flags)
Adds status flags to the listeners&#39;s flags mask.
Definition: hal_channels.h:308
msg_t iqPutI(input_queue_t *iqp, uint8_t b)
Input queue write.
Definition: hal_queues.c:224
#define CHN_OUTPUT_EMPTY
Output queue empty.
Definition: hal_channels.h:239
size_t iqReadTimeout(input_queue_t *iqp, uint8_t *bp, size_t n, sysinterval_t timeout)
Definition: hal_queues.c:389
#define CHN_INPUT_AVAILABLE
Data available in the input queue.
Definition: hal_channels.h:237
#define SD_QUEUE_FULL_ERROR
Queue full.
Definition: hal_serial.h:43
PLATFORM Serial Driver configuration structure.
Stops the driver.
Definition: hal_serial.c:206
int32_t msg_t
Definition: chtypes.h:51
