Serial over USB Driver code. More...
#include "hal.h"
static void | ibnotify (io_buffers_queue_t *bqp) |
Notification of empty buffer released into the input buffers queue. More... | |
static void | obnotify (io_buffers_queue_t *bqp) |
Notification of filled buffer inserted into the output buffers queue. More... | |
void | sduInit (void) |
Serial Driver initialization. More... | |
void | sduObjectInit (SerialUSBDriver *sdup) |
Initializes a generic full duplex driver object. More... | |
void | sduStart (SerialUSBDriver *sdup, const SerialUSBConfig *config) |
Configures and starts the driver. More... | |
void | sduStop (SerialUSBDriver *sdup) |
Stops the driver. More... | |
void | sduSuspendHookI (SerialUSBDriver *sdup) |
USB device suspend handler. More... | |
void | sduWakeupHookI (SerialUSBDriver *sdup) |
USB device wakeup handler. More... | |
void | sduConfigureHookI (SerialUSBDriver *sdup) |
USB device configured handler. More... | |
bool | sduRequestsHook (USBDriver *usbp) |
Default requests hook. More... | |
void | sduSOFHookI (SerialUSBDriver *sdup) |
SOF handler. More... | |
void | sduDataTransmitted (USBDriver *usbp, usbep_t ep) |
Default data transmitted callback. More... | |
void | sduDataReceived (USBDriver *usbp, usbep_t ep) |
Default data received callback. More... | |
void | sduInterruptTransmitted (USBDriver *usbp, usbep_t ep) |
msg_t | sduControl (USBDriver *usbp, unsigned int operation, void *arg) |
Control operation on a serial USB port. More... | |
Definition in file hal_serial_usb.c.
