Serial over USB Driver
Serial over USB Driver. More...
Collaboration diagram for Serial over USB Driver:
This module implements an USB Communication Device Class (CDC) as a normal serial communication port accessible from the device application.
Precondition
In order to use the USB over Serial driver the HAL_USE_SERIAL_USB option must be enabled in halconf.h.
Driver State Machine
The driver implements a state machine internally, not all the driver functionalities can be used in any moment, any transition not explicitly shown in the following diagram has to be considered an error and shall be captured by an assertion (if enabled).
#define _serial_usb_driver_data
 SerialDriver specific data. More...
#define _serial_usb_driver_methods   _base_asynchronous_channel_methods
 SerialUSBDriver specific methods. More...
SERIAL_USB configuration options
#define SERIAL_USB_BUFFERS_SIZE   256
 Serial over USB buffers size. More...
#define SERIAL_USB_BUFFERS_NUMBER   2
 Serial over USB number of buffers. More...
typedef struct SerialUSBDriver SerialUSBDriver
 Structure representing a serial over USB driver. More...
struct  SerialUSBConfig
 Serial over USB Driver configuration structure. More...
struct  SerialUSBDriverVMT
 SerialDriver virtual methods table. More...
 Full duplex serial driver class. More...
static void ibnotify (io_buffers_queue_t *bqp)
 Notification of empty buffer released into the input buffers queue. More...
static void obnotify (io_buffers_queue_t *bqp)
 Notification of filled buffer inserted into the output buffers queue. More...
void sduInit (void)
 Serial Driver initialization. More...
void sduObjectInit (SerialUSBDriver *sdup)
 Initializes a generic full duplex driver object. More...
void sduStart (SerialUSBDriver *sdup, const SerialUSBConfig *config)
 Configures and starts the driver. More...
void sduStop (SerialUSBDriver *sdup)
 Stops the driver. More...
void sduSuspendHookI (SerialUSBDriver *sdup)
 USB device suspend handler. More...
void sduWakeupHookI (SerialUSBDriver *sdup)
 USB device wakeup handler. More...
void sduConfigureHookI (SerialUSBDriver *sdup)
 USB device configured handler. More...
bool sduRequestsHook (USBDriver *usbp)
 Default requests hook. More...
void sduSOFHookI (SerialUSBDriver *sdup)
 SOF handler. More...
void sduDataTransmitted (USBDriver *usbp, usbep_t ep)
 Default data transmitted callback. More...
void sduDataReceived (USBDriver *usbp, usbep_t ep)
 Default data received callback. More...
void sduInterruptTransmitted (USBDriver *usbp, usbep_t ep)
msg_t sduControl (USBDriver *usbp, unsigned int operation, void *arg)
 Control operation on a serial USB port. More...
Enumerations
Configuration parameter, the buffer size must be a multiple of the USB data endpoint maximum packet size.
The default is 256 bytes for both the transmission and receive buffers.
Definition at line 52 of file hal_serial_usb.h.
Referenced by sduObjectInit().
The default is 2 buffers.
Definition at line 60 of file hal_serial_usb.h.
Value:
/* Driver state.*/ \
sdustate_t state; \
/* Input buffers queue.*/ \
/* Output queue.*/ \
/* Input buffer.*/ \
/* Output buffer.*/ \
/* End of the mandatory fields.*/ \
/* Current configuration data.*/ \
const SerialUSBConfig *config;
io_buffers_queue_t output_buffers_queue_t
Type of an output buffers queue.
Definition: hal_buffers.h:126
io_buffers_queue_t input_buffers_queue_t
Type of an input buffers queue.
Definition: hal_buffers.h:121
sdustate_t
#define _base_asynchronous_channel_data
BaseAsynchronousChannel specific data.
Definition: hal_channels.h:253
#define BQ_BUFFER_SIZE(n, size)
Computes the size of a buffers queue buffer size.
Definition: hal_buffers.h:138
Definition at line 119 of file hal_serial_usb.h.
Definition at line 140 of file hal_serial_usb.h.
Typedef Documentation
Definition at line 88 of file hal_serial_usb.h.
Enumeration Type Documentation
enum sdustate_t
Enumerator
SDU_UNINIT
Not initialized.
SDU_STOP
Stopped.
SDU_READY
Ready.
Definition at line 79 of file hal_serial_usb.h.
Function Documentation
static void ibnotify ( io_buffers_queue_t bqp)
static
Parameters
[in]bqpthe buffers queue pointer.
Definition at line 168 of file hal_serial_usb.c.
References bqGetLinkX.
static void obnotify ( io_buffers_queue_t bqp)
static
Parameters
Definition at line 178 of file hal_serial_usb.c.
References bqGetLinkX, obqGetFullBufferI(), SDU_READY, USB_ACTIVE, usbGetDriverStateI, usbGetTransmitStatusI, and usbStartTransmitI().
void sduInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 211 of file hal_serial_usb.c.
Referenced by halInit().
void sduObjectInit ( SerialUSBDriver sdup)
The HW dependent part of the initialization has to be performed outside, usually in the hardware initialization code.
Parameters
[out]sduppointer to a SerialUSBDriver structure
Definition at line 223 of file hal_serial_usb.c.
References ibnotify(), ibqObjectInit(), obnotify(), obqObjectInit(), osalEventObjectInit(), SDU_STOP, SERIAL_USB_BUFFERS_NUMBER, SERIAL_USB_BUFFERS_SIZE, and SerialUSBDriver::vmt.
void sduStart ( SerialUSBDriver sdup,
const SerialUSBConfig config
Parameters
[in]sduppointer to a SerialUSBDriver object
[in]configthe serial over USB driver configuration
Definition at line 244 of file hal_serial_usb.c.
References SerialUSBConfig::bulk_in, SerialUSBConfig::bulk_out, USBDriver::in_params, SerialUSBConfig::int_in, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), USBDriver::out_params, SDU_READY, SDU_STOP, and SerialUSBConfig::usbp.
void sduStop ( SerialUSBDriver sdup)
Stops the driver.
Any thread waiting on the driver's queues will be awakened with the message MSG_RESET.
Parameters
Definition at line 271 of file hal_serial_usb.c.
References CHN_DISCONNECTED, chnAddFlagsI, ibqResetI(), USBDriver::in_params, obqResetI(), osalDbgAssert, osalDbgCheck, osalOsRescheduleS(), osalSysLock(), osalSysUnlock(), USBDriver::out_params, SDU_READY, and SDU_STOP.
void sduSuspendHookI ( SerialUSBDriver sdup)
Generates a CHN_DISCONNECT event and puts queues in non-blocking mode, this way the application cannot get stuck in the middle of an I/O operations.
If this function is not called from an ISR then an explicit call to osalOsRescheduleS() in necessary afterward.
Parameters
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 311 of file hal_serial_usb.c.
References bqSuspendI, CHN_DISCONNECTED, and chnAddFlagsI.
void sduWakeupHookI ( SerialUSBDriver sdup)
Generates a CHN_CONNECT event and resumes normal queues operations.
Parameters
Definition at line 330 of file hal_serial_usb.c.
References bqResumeX, CHN_CONNECTED, and chnAddFlagsI.
void sduConfigureHookI ( SerialUSBDriver sdup)
Parameters
Definition at line 344 of file hal_serial_usb.c.
References bqResumeX, CHN_CONNECTED, chnAddFlagsI, ibqResetI(), and obqResetI().
bool sduRequestsHook ( USBDriver usbp)
Applications wanting to use the Serial over USB driver can use this function as requests hook in the USB configuration. The following requests are emulated:
  • CDC_GET_LINE_CODING.
  • CDC_SET_LINE_CODING.
  • CDC_SET_CONTROL_LINE_STATE.
Parameters
[in]usbppointer to the USBDriver object
Returns
The hook status.
Return values
trueMessage handled internally.
falseMessage not handled.
Definition at line 369 of file hal_serial_usb.c.
References USBDriver::setup, and usbSetupTransfer.
void sduSOFHookI ( SerialUSBDriver sdup)
SOF handler.
The SOF interrupt is used for automatic flushing of incomplete buffers pending in the output queue.
Parameters
Definition at line 399 of file hal_serial_usb.c.
References obqGetFullBufferI(), obqTryFlushI(), osalDbgAssert, SDU_READY, USB_ACTIVE, usbGetDriverStateI, usbGetTransmitStatusI, and usbStartTransmitI().
void sduDataTransmitted ( USBDriver usbp,
usbep_t  ep
The application must use this function as callback for the IN data endpoint.
Parameters
[in]epIN endpoint number
Definition at line 434 of file hal_serial_usb.c.
References CHN_OUTPUT_EMPTY, chnAddFlagsI, USBDriver::epc, USBEndpointConfig::in_maxsize, USBDriver::in_params, USBEndpointConfig::in_state, obqGetFullBufferI(), obqReleaseEmptyBufferI(), osalSysLockFromISR(), osalSysUnlockFromISR(), USBDriver::setup, USBInEndpointState::txsize, and usbStartTransmitI().
void sduDataReceived ( USBDriver usbp,
usbep_t  ep
The application must use this function as callback for the OUT data endpoint.
Parameters
[in]epOUT endpoint number
Definition at line 486 of file hal_serial_usb.c.
References CHN_INPUT_AVAILABLE, chnAddFlagsI, ibqPostFullBufferI(), osalSysLockFromISR(), osalSysUnlockFromISR(), USBDriver::out_params, and usbGetReceiveTransactionSizeX.
void sduInterruptTransmitted ( USBDriver usbp,
usbep_t  ep
The application must use this function as callback for the IN interrupt endpoint.
Parameters
[in]ependpoint number
Definition at line 523 of file hal_serial_usb.c.
msg_t sduControl ( USBDriver usbp,
void *  arg
Parameters
[in]usbppointer to a USBDriver object
[in]operationcontrol operation code
[in,out]argoperation argument
Returns
The control operation status.
Return values
MSG_OKin case of success.
MSG_TIMEOUTin case of operation timeout.
MSG_RESETin case of operation reset.
Definition at line 543 of file hal_serial_usb.c.
