hal_st.h
18  * @file hal_st.h
19  * @brief ST Driver macros and structures.
20  * @details This header is designed to be include-able without having to
21  * include other files from the HAL.
22  *
23  * @addtogroup ST
24  * @{
25  */
27 #ifndef HAL_ST_H
28 #define HAL_ST_H
31 /* Driver constants. */
37
38 /*===========================================================================*/
39 /* Derived constants and error checks. */
40 /*===========================================================================*/
41
43 /* Driver data structures and types. */
45
46 #include "hal_st_lld.h"
47
49 /* Driver macros. */
51
52 /**
53  * @name Macro Functions
54  * @{
55  */
56 /**
57  * @brief Returns the time counter value.
58  * @note This functionality is only available in free running mode, the
59  * behaviour in periodic mode is undefined.
60  *
61  * @return The counter value.
62  *
63  * @api
64  */
65 #define stGetCounter() st_lld_get_counter()
66
67 /**
68  * @brief Determines if the alarm is active.
69  *
70  * @return The alarm status.
71  * @retval false if the alarm is not active.
72  * @retval true is the alarm is active
73  *
74  * @api
75  */
76 #define stIsAlarmActive() st_lld_is_alarm_active()
77 /** @} */
78
79 /*===========================================================================*/
80 /* External declarations. */
81 /*===========================================================================*/
82
83 #ifdef __cplusplus
84 extern "C" {
85 #endif
86  void stInit(void);
87  void stStartAlarm(systime_t abstime);
88  void stStopAlarm(void);
89  void stSetAlarm(systime_t abstime);
90  systime_t stGetAlarm(void);
91 #ifdef __cplusplus
92 }
93 #endif
94
95 #endif /* HAL_ST_H */
96
97 /** @} */
Returns the current alarm time.
Definition: hal_st.c:120
uint64_t systime_t
Type of system time.
Definition: chtime.h:107
Starts the alarm.
Definition: hal_st.c:76
PLATFORM ST subsystem low level driver header.
void stInit(void)
ST Driver initialization.
Definition: hal_st.c:60
Sets the alarm time.
Definition: hal_st.c:104
Stops the alarm interrupt.
Definition: hal_st.c:90
