ST Driver
Generic System Tick Driver. More...
Collaboration diagram for ST Driver:
This module implements a system tick timer in order to support the underlying operating system.
Macro Functions
#define stGetCounter()   st_lld_get_counter()
 Returns the time counter value. More...
#define stIsAlarmActive()   st_lld_is_alarm_active()
 Determines if the alarm is active. More...
void stInit (void)
 ST Driver initialization. More...
void stStartAlarm (systime_t abstime)
 Starts the alarm. More...
void stStopAlarm (void)
 Stops the alarm interrupt. More...
void stSetAlarm (systime_t abstime)
 Sets the alarm time. More...
systime_t stGetAlarm (void)
 Returns the current alarm time. More...
void st_lld_init (void)
 Low level ST driver initialization. More...
static systime_t st_lld_get_counter (void)
static void st_lld_start_alarm (systime_t abstime)
static void st_lld_stop_alarm (void)
static void st_lld_set_alarm (systime_t abstime)
static systime_t st_lld_get_alarm (void)
static bool st_lld_is_alarm_active (void)
#define stGetCounter ( )    st_lld_get_counter()
This functionality is only available in free running mode, the behaviour in periodic mode is undefined.
Returns
The counter value.
Definition at line 65 of file hal_st.h.
#define stIsAlarmActive ( )    st_lld_is_alarm_active()
Returns
The alarm status.
Return values
falseif the alarm is not active.
trueis the alarm is active
Definition at line 76 of file hal_st.h.
Referenced by stGetAlarm(), stSetAlarm(), and stStartAlarm().
Function Documentation
void stInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 60 of file hal_st.c.
References st_lld_init().
Referenced by halInit().
void stStartAlarm ( systime_t  abstime)
Starts the alarm.
Makes sure that no spurious alarms are triggered after this call.
This functionality is only available in free running mode, the behavior in periodic mode is undefined.
Parameters
[in]abstimethe time to be set for the first alarm
Definition at line 76 of file hal_st.c.
References osalDbgAssert, st_lld_start_alarm(), and stIsAlarmActive.
void stStopAlarm ( void  )
Definition at line 90 of file hal_st.c.
References st_lld_stop_alarm().
void stSetAlarm ( systime_t  abstime)
Parameters
[in]abstimethe time to be set for the next alarm
Definition at line 104 of file hal_st.c.
References osalDbgAssert, st_lld_set_alarm(), and stIsAlarmActive.
systime_t stGetAlarm ( void  )
Returns
The currently set alarm time.
Definition at line 120 of file hal_st.c.
References osalDbgAssert, st_lld_get_alarm(), and stIsAlarmActive.
void st_lld_init ( void  )
Function Class:Not an API, this function is for internal use only.
Definition at line 62 of file hal_st_lld.c.
Referenced by stInit().
static systime_t st_lld_get_counter ( void  )
inlinestatic
Returns
The counter value.
Definition at line 73 of file hal_st_lld.h.
static void st_lld_start_alarm ( systime_t  abstime)
inlinestatic
Starts the alarm.
Parameters
Definition at line 87 of file hal_st_lld.h.
Referenced by stStartAlarm().
static void st_lld_stop_alarm ( void  )
inlinestatic
Definition at line 97 of file hal_st_lld.h.
Referenced by stStopAlarm().
static void st_lld_set_alarm ( systime_t  abstime)
inlinestatic
Parameters
Definition at line 108 of file hal_st_lld.h.
Referenced by stSetAlarm().
static systime_t st_lld_get_alarm ( void  )
inlinestatic
Returns
Definition at line 120 of file hal_st_lld.h.
Referenced by stGetAlarm().
static bool st_lld_is_alarm_active ( void  )
inlinestatic
Returns
The alarm status.
Return values
Definition at line 134 of file hal_st_lld.h.
