hal_wdg_lld.h
18  * @file hal_wdg_lld.h
19  * @brief WDG Driver subsystem low level driver header template.
21  * @addtogroup WDG
25 #ifndef HAL_WDG_LLD_H
26 #define HAL_WDG_LLD_H
28 #if (HAL_USE_WDG == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
37
38 /**
39  * @name Configuration options
40  * @{
41  */
42 /**
43  * @brief WDG1 driver enable switch.
44  * @note The default is @p FALSE.
45  */
46 #if !defined(PLATFORM_WDG_USE_WDG1) || defined(__DOXYGEN__)
47 #define PLATFORM_WDG_USE_WDG1 FALSE
48 #endif
49 /** @} */
50
52 /* Derived constants and error checks. */
54
56 /* Driver data structures and types. */
58
59 /**
60  * @brief Type of a structure representing an WDG driver.
61  */
62 typedef struct WDGDriver WDGDriver;
63
64 /**
65  * @brief Driver configuration structure.
66  * @note It could be empty on some architectures.
67  */
68 typedef struct {
69 } WDGConfig;
70
71 /**
72  * @brief Structure representing an WDG driver.
73  */
74 struct WDGDriver {
75  /**
76  * @brief Driver state.
77  */
79  /**
80  * @brief Current configuration data.
81  */
82  const WDGConfig *config;
83  /* End of the mandatory fields.*/
84 };
85
86 /*===========================================================================*/
87 /* Driver macros. */
88 /*===========================================================================*/
89
90 /*===========================================================================*/
91 /* External declarations. */
92 /*===========================================================================*/
93
94 #if (PLATFORM_WDG_USE_WDG1 == TRUE) && !defined(__DOXYGEN__)
95 extern WDGDriver WDGD1;
96 #endif
97
98 #ifdef __cplusplus
99 extern "C" {
100 #endif
101  void wdg_lld_init(void);
102  void wdg_lld_start(WDGDriver *wdgp);
103  void wdg_lld_stop(WDGDriver *wdgp);
104  void wdg_lld_reset(WDGDriver *wdgp);
105 #ifdef __cplusplus
106 }
107 #endif
108
109 #endif /* HAL_USE_WDG == TRUE */
110
111 #endif /* HAL_WDG_LLD_H */
112
113 /** @} */
Configures and activates the WDG peripheral.
Definition: hal_wdg_lld.c:73
Deactivates the WDG peripheral.
Definition: hal_wdg_lld.c:85
wdgstate_t state
Definition: hal_wdg_lld.h:78
Reloads WDG's counter.
Definition: hal_wdg_lld.c:97
wdgstate_t
Definition: hal_wdg.h:49
const WDGConfig * config
Definition: hal_wdg_lld.h:82
Definition: hal_wdg_lld.h:74
Low level WDG driver initialization.
Definition: hal_wdg_lld.c:62
Definition: hal_wdg_lld.h:68
