WDG Driver
Generic WDG Driver. More...
Collaboration diagram for WDG Driver:
Generic WDG Driver.
This module defines an abstract interface for a watchdog timer.
Precondition
In order to use the WDG driver the HAL_USE_WDG option must be enabled in halconf.h.
#define wdgResetI(wdgp)   wdg_lld_reset(wdgp)
 Resets WDG's counter. More...
Configuration options
#define PLATFORM_WDG_USE_WDG1   FALSE
 WDG1 driver enable switch. More...
typedef struct WDGDriver WDGDriver
 Type of a structure representing an WDG driver. More...
struct  WDGConfig
 Driver configuration structure. More...
struct  WDGDriver
 Structure representing an WDG driver. More...
void wdgInit (void)
 WDG Driver initialization. More...
void wdgStart (WDGDriver *wdgp, const WDGConfig *config)
 Configures and activates the WDG peripheral. More...
void wdgStop (WDGDriver *wdgp)
 Deactivates the WDG peripheral. More...
void wdgReset (WDGDriver *wdgp)
void wdg_lld_init (void)
 Low level WDG driver initialization. More...
void wdg_lld_start (WDGDriver *wdgp)
void wdg_lld_stop (WDGDriver *wdgp)
void wdg_lld_reset (WDGDriver *wdgp)
 Reloads WDG's counter. More...
Enumerations
#define wdgResetI (   wdgp)    wdg_lld_reset(wdgp)
Parameters
[in]wdgppointer to the WDGDriver object
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 68 of file hal_wdg.h.
Referenced by wdgReset().
The default is FALSE.
Definition at line 47 of file hal_wdg_lld.h.
Typedef Documentation
Definition at line 62 of file hal_wdg_lld.h.
Enumeration Type Documentation
enum wdgstate_t
Enumerator
WDG_UNINIT
Not initialized.
WDG_STOP
Stopped.
WDG_READY
Ready.
Definition at line 49 of file hal_wdg.h.
Function Documentation
void wdgInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 56 of file hal_wdg.c.
References wdg_lld_init().
Referenced by halInit().
void wdgStart ( WDGDriver wdgp,
const WDGConfig config
Parameters
[in]configpointer to the WDGConfig object
Definition at line 69 of file hal_wdg.c.
References WDGDriver::config, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), WDGDriver::state, wdg_lld_start(), WDG_READY, and WDG_STOP.
void wdgStop ( WDGDriver wdgp)
Parameters
Definition at line 89 of file hal_wdg.c.
References WDGDriver::config, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), WDGDriver::state, wdg_lld_stop(), WDG_READY, and WDG_STOP.
void wdgReset ( WDGDriver wdgp)
Parameters
Definition at line 112 of file hal_wdg.c.
References osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), WDGDriver::state, WDG_READY, and wdgResetI.
void wdg_lld_init ( void  )
Function Class:Not an API, this function is for internal use only.
Definition at line 62 of file hal_wdg_lld.c.
Referenced by wdgInit().
void wdg_lld_start ( WDGDriver wdgp)
Parameters
Definition at line 73 of file hal_wdg_lld.c.
Referenced by wdgStart().
void wdg_lld_stop ( WDGDriver wdgp)
Parameters
Definition at line 85 of file hal_wdg_lld.c.
Referenced by wdgStop().
void wdg_lld_reset ( WDGDriver wdgp)
Parameters
Definition at line 97 of file hal_wdg_lld.c.
