LIS3DSH MEMS interface module header. More...
#include "hal_accelerometer.h"Go to the source code of this file.
| struct | LIS3DSHConfig |
| LIS3DSH configuration structure. More... | |
| struct | LIS3DSHVMT |
LIS3DSH virtual methods table. More... | |
| struct | LIS3DSHDriver |
| LIS3DSH 3-axis accelerometer class. More... | |
| #define | lis3dshAccelerometerGetAxesNumber(devp) accelerometerGetAxesNumber(&((devp)->acc_if)) |
| Return the number of axes of the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerReadRaw(devp, axes) accelerometerReadRaw(&((devp)->acc_if), axes) |
| Retrieves raw data from the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerReadCooked(devp, axes) accelerometerReadCooked(&((devp)->acc_if), axes) |
| Retrieves cooked data from the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerSetBias(devp, bp) accelerometerSetBias(&((devp)->acc_if), bp) |
| Set bias values for the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerResetBias(devp) accelerometerResetBias(&((devp)->acc_if)) |
| Reset bias values for the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerSetSensitivity(devp, sp) accelerometerSetSensitivity(&((devp)->acc_if), sp) |
| Set sensitivity values for the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerResetSensitivity(devp) accelerometerResetSensitivity(&((devp)->acc_if)) |
| Reset sensitivity values for the BaseAccelerometer. More... | |
| #define | lis3dshAccelerometerSetFullScale(devp, fs) (devp)->vmt->acc_set_full_scale(devp, fs) |
| Changes the LIS3DSHDriver accelerometer fullscale value. More... | |
Version identification | |
| #define | EX_LIS3DSH_VERSION "1.1.1" |
| LIS3DSH driver version string. More... | |
| #define | EX_LIS3DSH_MAJOR 1 |
| LIS3DSH driver version major number. More... | |
| #define | EX_LIS3DSH_MINOR 1 |
| LIS3DSH driver version minor number. More... | |
| #define | EX_LIS3DSH_PATCH 1 |
| LIS3DSH driver version patch number. More... | |
| #define | LIS3DSH_ACC_NUMBER_OF_AXES 3U |
| LIS3DSH accelerometer subsystem characteristics. More... | |
LIS3DSH communication interfaces related bit masks | |
| #define | LIS3DSH_DI_MASK 0xFF |
| #define | LIS3DSH_DI(n) (1 << n) |
| #define | LIS3DSH_AD_MASK 0x3F |
| #define | LIS3DSH_AD(n) (1 << n) |
| #define | LIS3DSH_MS (1 << 6) |
| #define | LIS3DSH_RW (1 << 7) |
LIS3DSH register addresses | |
| #define | LIS3DSH_AD_OUT_T 0x0C |
| #define | LIS3DSH_AD_INFO1 0x0D |
| #define | LIS3DSH_AD_INFO2 0x0E |
| #define | LIS3DSH_AD_WHO_AM_I 0x0F |
| #define | LIS3DSH_AD_OFF_X 0x10 |
| #define | LIS3DSH_AD_OFF_Y 0x11 |
| #define | LIS3DSH_AD_OFF_Z 0x12 |
| #define | LIS3DSH_AD_CS_X 0x13 |
| #define | LIS3DSH_AD_CS_Y 0x14 |
| #define | LIS3DSH_AD_CS_Z 0x15 |
| #define | LIS3DSH_AD_LC_L 0x16 |
| #define | LIS3DSH_AD_LC_H 0x17 |
| #define | LIS3DSH_AD_STAT 0x18 |
| #define | LIS3DSH_AD_PEAK1 0x19 |
| #define | LIS3DSH_AD_PEAK2 0x1A |
| #define | LIS3DSH_AD_VFC_1 0x1B |
| #define | LIS3DSH_AD_VFC_2 0x1C |
| #define | LIS3DSH_AD_VFC_3 0x1D |
| #define | LIS3DSH_AD_VFC_4 0x1E |
| #define | LIS3DSH_AD_THRS3 0x1F |
| #define | LIS3DSH_AD_CTRL_REG4 0x20 |
| #define | LIS3DSH_AD_CTRL_REG1 0x21 |
| #define | LIS3DSH_AD_CTRL_REG2 0x22 |
| #define | LIS3DSH_AD_CTRL_REG3 0x23 |
| #define | LIS3DSH_AD_CTRL_REG5 0x24 |
| #define | LIS3DSH_AD_CTRL_REG6 0x25 |
| #define | LIS3DSH_AD_STATUS 0x27 |
| #define | LIS3DSH_AD_OUT_X_L 0x28 |
| #define | LIS3DSH_AD_OUT_X_H 0x29 |
| #define | LIS3DSH_AD_OUT_Y_L 0x2A |
| #define | LIS3DSH_AD_OUT_Y_H 0x2B |
| #define | LIS3DSH_AD_OUT_Z_L 0x2C |
| #define | LIS3DSH_AD_OUT_Z_H 0x2D |
| #define | LIS3DSH_AD_FIFO_CTRL 0x2E |
| #define | LIS3DSH_AD_FIFO_SRC 0x2F |
| #define | LIS3DSH_AD_ST1_0 0x40 |
| #define | LIS3DSH_AD_ST1_1 0x41 |
| #define | LIS3DSH_AD_ST1_2 0x42 |
| #define | LIS3DSH_AD_ST1_3 0x43 |
| #define | LIS3DSH_AD_ST1_4 0x44 |
| #define | LIS3DSH_AD_ST1_5 0x45 |
| #define | LIS3DSH_AD_ST1_6 0x46 |
| #define | LIS3DSH_AD_ST1_7 0x47 |
| #define | LIS3DSH_AD_ST1_8 0x48 |
| #define | LIS3DSH_AD_ST1_9 0x49 |
| #define | LIS3DSH_AD_ST1_A 0x4A |
| #define | LIS3DSH_AD_ST1_B 0x4B |
| #define | LIS3DSH_AD_ST1_C 0x4C |
| #define | LIS3DSH_AD_ST1_D 0x4D |
| #define | LIS3DSH_AD_ST1_E 0x4E |
| #define | LIS3DSH_AD_ST1_F 0x4F |
| #define | LIS3DSH_AD_TIM4_1 0x50 |
| #define | LIS3DSH_AD_TIM3_1 0x51 |
| #define | LIS3DSH_AD_TIM2_1_L 0x52 |
| #define | LIS3DSH_AD_TIM2_1_H 0x53 |
| #define | LIS3DSH_AD_TIM1_1_L 0x54 |
| #define | LIS3DSH_AD_TIM1_1_H 0x55 |
| #define | LIS3DSH_AD_THRS2_1 0x56 |
| #define | LIS3DSH_AD_THRS1_1 0x57 |
| #define | LIS3DSH_AD_MASK1_B 0x59 |
| #define | LIS3DSH_AD_MASK1_A 0x5A |
| #define | LIS3DSH_AD_SETT1 0x5B |
| #define | LIS3DSH_AD_PR1 0x5C |
| #define | LIS3DSH_AD_TC1_L 0x5D |
| #define | LIS3DSH_AD_TC1_H 0x5E |
| #define | LIS3DSH_AD_OUTS1 0x5F |
| #define | LIS3DSH_AD_ST2_0 0x60 |
| #define | LIS3DSH_AD_ST2_1 0x61 |
| #define | LIS3DSH_AD_ST2_2 0x62 |
| #define | LIS3DSH_AD_ST2_3 0x63 |
| #define | LIS3DSH_AD_ST2_4 0x64 |
| #define | LIS3DSH_AD_ST2_5 0x65 |
| #define | LIS3DSH_AD_ST2_6 0x66 |
| #define | LIS3DSH_AD_ST2_7 0x67 |
| #define | LIS3DSH_AD_ST2_8 0x68 |
| #define | LIS3DSH_AD_ST2_9 0x69 |
| #define | LIS3DSH_AD_ST2_A 0x6A |
| #define | LIS3DSH_AD_ST2_B 0x6B |
| #define | LIS3DSH_AD_ST2_C 0x6C |
| #define | LIS3DSH_AD_ST2_D 0x6D |
| #define | LIS3DSH_AD_ST2_E 0x6E |
| #define | LIS3DSH_AD_ST2_F 0x6F |
| #define | LIS3DSH_AD_TIM4_2 0x70 |
| #define | LIS3DSH_AD_TIM3_2 0x71 |
| #define | LIS3DSH_AD_TIM2_2_L 0x72 |
| #define | LIS3DSH_AD_TIM2_2_H 0x73 |
| #define | LIS3DSH_AD_TIM1_2_L 0x74 |
| #define | LIS3DSH_AD_TIM1_2_H 0x75 |
| #define | LIS3DSH_AD_THRS2_2 0x76 |
| #define | LIS3DSH_AD_THRS1_2 0x77 |
| #define | LIS3DSH_AD_DES2 0x78 |
| #define | LIS3DSH_AD_MASK2_B 0x79 |
| #define | LIS3DSH_AD_MASK2_A 0x7A |
| #define | LIS3DSH_AD_SETT2 0x7B |
| #define | LIS3DSH_AD_PR2 0x7C |
| #define | LIS3DSH_AD_TC2_L 0x7D |
| #define | LIS3DSH_AD_TC2_H 0x7E |
| #define | LIS3DSH_AD_OUTS2 0x7F |
LIS3DSH_CTRL_REG1 register bits definitions | |
| #define | LIS3DSH_CTRL_REG1_MASK 0xE9 |
| #define | LIS3DSH_CTRL_REG1_SM1_EN (1 << 0) |
| #define | LIS3DSH_CTRL_REG1_SM1_PIN (1 << 3) |
| #define | LIS3DSH_CTRL_REG1_HYST0_1 (1 << 5) |
| #define | LIS3DSH_CTRL_REG1_HYST1_1 (1 << 6) |
| #define | LIS3DSH_CTRL_REG1_HYST2_1 (1 << 7) |
LIS3DSH_CTRL_REG2 register bits definitions | |
| #define | LIS3DSH_CTRL_REG2_MASK 0xE9 |
| #define | LIS3DSH_CTRL_REG2_SM2_EN (1 << 0) |
| #define | LIS3DSH_CTRL_REG2_SM2_PIN (1 << 3) |
| #define | LIS3DSH_CTRL_REG2_HYST0_2 (1 << 5) |
| #define | LIS3DSH_CTRL_REG2_HYST1_2 (1 << 6) |
| #define | LIS3DSH_CTRL_REG2_HYST2_2 (1 << 7) |
LIS3DSH_CTRL_REG3 register bits definitions | |
| #define | LIS3DSH_CTRL_REG3_MASK 0xFF |
| #define | LIS3DSH_CTRL_REG3_STRT (1 << 0) |
| #define | LIS3DSH_CTRL_REG3_VFILT (1 << 2) |
| #define | LIS3DSH_CTRL_REG3_INT1_EN (1 << 3) |
| #define | LIS3DSH_CTRL_REG3_INT2_EN (1 << 4) |
| #define | LIS3DSH_CTRL_REG3_IEL (1 << 5) |
| #define | LIS3DSH_CTRL_REG3_IEA (1 << 6) |
| #define | LIS3DSH_CTRL_REG3_DR_EN (1 << 7) |
LIS3DSH_CTRL_REG4 register bits definitions | |
| #define | LIS3DSH_CTRL_REG4_MASK 0xFF |
| #define | LIS3DSH_CTRL_REG4_XEN (1 << 0) |
| #define | LIS3DSH_CTRL_REG4_YEN (1 << 1) |
| #define | LIS3DSH_CTRL_REG4_ZEN (1 << 2) |
| #define | LIS3DSH_CTRL_REG4_BDU (1 << 3) |
| #define | LIS3DSH_CTRL_REG4_ODR_0 (1 << 4) |
| #define | LIS3DSH_CTRL_REG4_ODR_1 (1 << 5) |
| #define | LIS3DSH_CTRL_REG4_ODR_2 (1 << 6) |
| #define | LIS3DSH_CTRL_REG4_ODR_3 (1 << 7) |
LIS3DSH_CTRL_REG5 register bits definitions | |
| #define | LIS3DSH_CTRL_REG5_MASK 0xFF |
| #define | LIS3DSH_CTRL_REG5_SIM (1 << 0) |
| #define | LIS3DSH_CTRL_REG5_ST1 (1 << 1) |
| #define | LIS3DSH_CTRL_REG5_ST2 (1 << 2) |
| #define | LIS3DSH_CTRL_REG5_FS_MASK 0x38 |
| #define | LIS3DSH_CTRL_REG5_FS0 (1 << 3) |
| #define | LIS3DSH_CTRL_REG5_FS1 (1 << 4) |
| #define | LIS3DSH_CTRL_REG5_FS2 (1 << 5) |
| #define | LIS3DSH_CTRL_REG5_BW1 (1 << 6) |
| #define | LIS3DSH_CTRL_REG5_BW2 (1 << 7) |
LIS3DSH_CTRL_REG6 register bits definitions | |
| #define | LIS3DSH_CTRL_REG6_MASK 0xFF |
| #define | LIS3DSH_CTRL_REG6_P2_BOOT (1 << 0) |
| #define | LIS3DSH_CTRL_REG6_P1_OVRUN (1 << 1) |
| #define | LIS3DSH_CTRL_REG6_P1_WTM (1 << 2) |
| #define | LIS3DSH_CTRL_REG6_P1_EMPTY (1 << 3) |
| #define | LIS3DSH_CTRL_REG6_ADD_INC (1 << 4) |
| #define | LIS3DSH_CTRL_REG6_WTM_EN (1 << 5) |
| #define | LIS3DSH_CTRL_REG6_FIFO_EN (1 << 6) |
| #define | LIS3DSH_CTRL_REG6_BOOT (1 << 7) |
Configuration options | |
| #define | LIS3DSH_USE_SPI TRUE |
| LIS3DSH SPI interface switch. More... | |
| #define | LIS3DSH_SHARED_SPI FALSE |
| LIS3DSH shared SPI switch. More... | |
| #define | LIS3DSH_USE_I2C FALSE |
| LIS3DSH I2C interface switch. More... | |
| #define | LIS3DSH_SHARED_I2C FALSE |
| LIS3DSH shared I2C switch. More... | |
| #define | LIS3DSH_ACC_USE_ADVANCED FALSE |
| LIS3DSH accelerometer subsystem advanced configurations switch. More... | |
| void | lis3dshObjectInit (LIS3DSHDriver *devp) |
| Initializes an instance. More... | |
| void | lis3dshStart (LIS3DSHDriver *devp, const LIS3DSHConfig *config) |
| Configures and activates LIS3DSH Complex Driver peripheral. More... | |
| void | lis3dshStop (LIS3DSHDriver *devp) |
| Deactivates the LIS3DSH Complex Driver peripheral. More... | |
LIS3DSH data structures and types | |
| #define | _lis3dsh_methods_alone |
LIS3DSH specific methods. More... | |
| #define | _lis3dsh_methods |
LIS3DSH specific methods with inherited ones. More... | |
| #define | _lis3dsh_data |
LIS3DSHDriver specific data. More... | |
| typedef struct LIS3DSHDriver | LIS3DSHDriver |
| Structure representing a LIS3DSH driver. More... | |
Definition in file lis3dsh.h.
