lps22hb.c File Reference
LPS22HB MEMS interface module code. More...
#include "hal.h"
#include "lps22hb.h"
#define lps22hbI2CWriteRegister(i2cp, sad, txbuf, n)
 Writes a value into a register using I2C. More...
static msg_t lps22hbI2CReadRegister (I2CDriver *i2cp, lps22hb_sad_t sad, uint8_t reg, uint8_t *rxbuf, size_t n)
 Reads registers value using I2C. More...
static size_t baro_get_axes_number (void *ip)
 Return the number of axes of the BaseBarometer. More...
static msg_t baro_read_raw (void *ip, int32_t axes[])
 Retrieves raw data from the BaseBarometer. More...
static msg_t baro_read_cooked (void *ip, float axes[])
 Retrieves cooked data from the BaseBarometer. More...
static msg_t baro_set_bias (void *ip, float *bp)
 Set bias values for the BaseBarometer. More...
static msg_t baro_reset_bias (void *ip)
 Reset bias values for the BaseBarometer. More...
static msg_t baro_set_sensitivity (void *ip, float *sp)
 Set sensitivity values for the BaseBarometer. More...
static msg_t baro_reset_sensitivity (void *ip)
 Reset sensitivity values for the BaseBarometer. More...
static size_t thermo_get_axes_number (void *ip)
 Return the number of axes of the BaseThermometer. More...
static msg_t thermo_read_raw (void *ip, int32_t axes[])
 Retrieves raw data from the BaseThermometer. More...
static msg_t thermo_read_cooked (void *ip, float *axis)
 Retrieves cooked data from the BaseThermometer. More...
static msg_t thermo_set_bias (void *ip, float *bp)
 Set bias values for the BaseThermometer. More...
static msg_t thermo_reset_bias (void *ip)
 Reset bias values for the BaseThermometer. More...
static msg_t thermo_set_sensitivity (void *ip, float *sp)
 Set sensitivity values for the BaseThermometer. More...
static msg_t thermo_reset_sensitivity (void *ip)
 Reset sensitivity values for the BaseThermometer. More...
void lps22hbObjectInit (LPS22HBDriver *devp)
 Initializes an instance. More...
void lps22hbStart (LPS22HBDriver *devp, const LPS22HBConfig *config)
 Configures and activates LPS22HB Complex Driver peripheral. More...
void lps22hbStop (LPS22HBDriver *devp)
 Deactivates the LPS22HB Complex Driver peripheral. More...
Definition in file lps22hb.c.
