| #define | lps22hbI2CWriteRegister(i2cp, sad, txbuf, n) |
| Writes a value into a register using I2C. More... | |
| #define | lps22hbBarometerGetAxesNumber(devp) barometerGetAxesNumber(&((devp)->baro_if)) |
| Return the number of axes of the BaseBarometer. More... | |
| #define | lps22hbBarometerReadRaw(devp, axes) barometerReadRaw(&((devp)->baro_if), axes) |
| Retrieves raw data from the BaseBarometer. More... | |
| #define | lps22hbBarometerReadCooked(devp, axes) barometerReadCooked(&((devp)->baro_if), axes) |
| Retrieves cooked data from the BaseBarometer. More... | |
| #define | lps22hbBarometerSetBias(devp, bp) barometerSetBias(&((devp)->baro_if), bp) |
| Set bias values for the BaseBarometer. More... | |
| #define | lps22hbBarometerResetBias(devp) barometerResetBias(&((devp)->baro_if)) |
| Reset bias values for the BaseBarometer. More... | |
| #define | lps22hbBarometerSetSensitivity(devp, sp) barometerSetSensitivity(&((devp)->baro_if), sp) |
| Set sensitivity values for the BaseBarometer. More... | |
| #define | lps22hbBarometerResetSensitivity(devp) barometerResetSensitivity(&((devp)->baro_if)) |
| Reset sensitivity values for the BaseBarometer. More... | |
| #define | lps22hbThermometerGetAxesNumber(devp) thermometerGetAxesNumber(&((devp)->thermo_if)) |
| Return the number of axes of the BaseThermometer. More... | |
| #define | lps22hbThermometerReadRaw(devp, axes) thermometerReadRaw(&((devp)->thermo_if), axes) |
| Retrieves raw data from the BaseThermometer. More... | |
| #define | lps22hbThermometerReadCooked(devp, axes) thermometerReadCooked(&((devp)->thermo_if), axes) |
| Retrieves cooked data from the BaseThermometer. More... | |
| #define | lps22hbThermometerSetBias(devp, bp) thermometerSetBias(&((devp)->thermo_if), bp) |
| Set bias values for the BaseThermometer. More... | |
| #define | lps22hbThermometerResetBias(devp) thermometerResetBias(&((devp)->thermo_if)) |
| Reset bias values for the BaseThermometer. More... | |
| #define | lps22hbThermometerSetSensitivity(devp, sp) thermometerSetSensitivity(&((devp)->thermo_if), sp) |
| Set sensitivity values for the BaseThermometer. More... | |
| #define | lps22hbThermometerResetSensitivity(devp) thermometerResetSensitivity(&((devp)->thermo_if)) |
| Reset sensitivity values for the BaseThermometer. More... | |
Version identification | |
| #define | EX_LPS22HB_VERSION "1.0.0" |
| LPS22HB driver version string. More... | |
| #define | EX_LPS22HB_MAJOR 1 |
| LPS22HB driver version major number. More... | |
| #define | EX_LPS22HB_MINOR 0 |
| LPS22HB driver version minor number. More... | |
| #define | EX_LPS22HB_PATCH 0 |
| LPS22HB driver version patch number. More... | |
| #define | LPS22HB_BARO_NUMBER_OF_AXES 1U |
| LPS22HB barometer subsystem characteristics. More... | |
| #define | LPS22HB_THERMO_NUMBER_OF_AXES 1U |
| LPS22HB thermometer subsystem characteristics. More... | |
Configuration options | |
| #define | LPS22HB_USE_SPI FALSE |
| LPS22HB SPI interface switch. More... | |
| #define | LPS22HB_SHARED_SPI FALSE |
| LPS22HB shared SPI switch. More... | |
| #define | LPS22HB_USE_I2C TRUE |
| LPS22HB I2C interface switch. More... | |
| #define | LPS22HB_SHARED_I2C FALSE |
| LPS22HB shared I2C switch. More... | |
| #define | LPS22HB_USE_ADVANCED FALSE |
| LPS22HB accelerometer subsystem advanced configurations switch. More... | |
LPS22HB data structures and types. | |
| typedef struct LPS22HBDriver | LPS22HBDriver |
| Structure representing a LPS22HB driver. More... | |
| #define | _lps22hb_methods_alone |
LPS22HB specific methods. More... | |
| #define | _lps22hb_methods |
LPS22HB specific methods with inherited ones. More... | |
| #define | _lps22hb_data |
LPS22HBDriver specific data. More... | |
| struct | LPS22HBConfig |
| LPS22HB configuration structure. More... | |
| struct | LPS22HBVMT |
LPS22HB virtual methods table. More... | |
| struct | LPS22HBDriver |
| LPS22HB 2-axis barometer/thermometer class. More... | |
| static msg_t | lps22hbI2CReadRegister (I2CDriver *i2cp, lps22hb_sad_t sad, uint8_t reg, uint8_t *rxbuf, size_t n) |
| Reads registers value using I2C. More... | |
| static size_t | baro_get_axes_number (void *ip) |
| static msg_t | baro_read_raw (void *ip, int32_t axes[]) |
| static msg_t | baro_read_cooked (void *ip, float axes[]) |
| static msg_t | baro_set_bias (void *ip, float *bp) |
| static msg_t | baro_reset_bias (void *ip) |
| static msg_t | baro_set_sensitivity (void *ip, float *sp) |
| static msg_t | baro_reset_sensitivity (void *ip) |
| static size_t | thermo_get_axes_number (void *ip) |
| static msg_t | thermo_read_raw (void *ip, int32_t axes[]) |
| static msg_t | thermo_read_cooked (void *ip, float *axis) |
| static msg_t | thermo_set_bias (void *ip, float *bp) |
| static msg_t | thermo_reset_bias (void *ip) |
| static msg_t | thermo_set_sensitivity (void *ip, float *sp) |
| static msg_t | thermo_reset_sensitivity (void *ip) |
| void | lps22hbObjectInit (LPS22HBDriver *devp) |
| Initializes an instance. More... | |
| void | lps22hbStart (LPS22HBDriver *devp, const LPS22HBConfig *config) |
| Configures and activates LPS22HB Complex Driver peripheral. More... | |
| void | lps22hbStop (LPS22HBDriver *devp) |
| Deactivates the LPS22HB Complex Driver peripheral. More... | |
| #define lps22hbI2CWriteRegister | ( | i2cp, | |
| sad, | |||
| txbuf, | |||
| n | |||
| [in] | i2cp | pointer to the I2C interface |
| [in] | sad | slave address without R bit |
| [in] | txbuf | buffer containing sub-address value in first position and values to write |
| [in] | n | size of txbuf less one (not considering the first element) |
Definition at line 84 of file lps22hb.c.
Referenced by lps22hbStart(), and lps22hbStop().
| #define EX_LPS22HB_VERSION "1.0.0" |
| #define EX_LPS22HB_MAJOR 1 |
| #define EX_LPS22HB_MINOR 0 |
| #define EX_LPS22HB_PATCH 0 |
| #define LPS22HB_BARO_NUMBER_OF_AXES 1U |
Definition at line 72 of file lps22hb.h.
Referenced by baro_get_axes_number(), and lps22hbObjectInit().
| #define LPS22HB_THERMO_NUMBER_OF_AXES 1U |
Definition at line 85 of file lps22hb.h.
Referenced by lps22hbObjectInit(), and thermo_get_axes_number().
| #define LPS22HB_USE_SPI FALSE |
| #define LPS22HB_SHARED_SPI FALSE |
| #define LPS22HB_USE_I2C TRUE |
| #define LPS22HB_SHARED_I2C FALSE |
| #define LPS22HB_USE_ADVANCED FALSE |
| #define _lps22hb_methods_alone |
| #define _lps22hb_methods |
| #define _lps22hb_data |
| #define lps22hbBarometerGetAxesNumber | ( | devp | ) | barometerGetAxesNumber(&((devp)->baro_if)) |
| [in] | devp | pointer to LPS22HBDriver. |
| #define lps22hbBarometerReadRaw | ( | devp, | |
| axes | |||
| ) | barometerReadRaw(&((devp)->baro_if), axes) |
| [out] | axes | a buffer which would be filled with raw data. |
| MSG_OK | if the function succeeded. |
| MSG_RESET | if one or more I2C errors occurred, the errors can be retrieved using i2cGetErrors(). |
| MSG_TIMEOUT | if a timeout occurred before operation end. |
| #define lps22hbBarometerReadCooked | ( | devp, | |
| axes | |||
| ) | barometerReadCooked(&((devp)->baro_if), axes) |
| [out] | axes | a buffer which would be filled with cooked data. |
| #define lps22hbBarometerSetBias | ( | devp, | |
| bp | |||
| ) | barometerSetBias(&((devp)->baro_if), bp) |
| [in] | bp | a buffer which contains biases. |
| #define lps22hbBarometerResetBias | ( | devp | ) | barometerResetBias(&((devp)->baro_if)) |
| #define lps22hbBarometerSetSensitivity | ( | devp, | |
| sp | |||
| ) | barometerSetSensitivity(&((devp)->baro_if), sp) |
| [in] | sp | a buffer which contains sensitivities. |
| #define lps22hbBarometerResetSensitivity | ( | devp | ) | barometerResetSensitivity(&((devp)->baro_if)) |
| #define lps22hbThermometerGetAxesNumber | ( | devp | ) | thermometerGetAxesNumber(&((devp)->thermo_if)) |
| #define lps22hbThermometerReadRaw | ( | devp, | |
| axes | |||
| ) | thermometerReadRaw(&((devp)->thermo_if), axes) |
| #define lps22hbThermometerReadCooked | ( | devp, | |
| axes | |||
| ) | thermometerReadCooked(&((devp)->thermo_if), axes) |
| #define lps22hbThermometerSetBias | ( | devp, | |
| bp | |||
| ) | thermometerSetBias(&((devp)->thermo_if), bp) |
| #define lps22hbThermometerResetBias | ( | devp | ) | thermometerResetBias(&((devp)->thermo_if)) |
| #define lps22hbThermometerSetSensitivity | ( | devp, | |
| sp | |||
| ) | thermometerSetSensitivity(&((devp)->thermo_if), sp) |
| #define lps22hbThermometerResetSensitivity | ( | devp | ) | thermometerResetSensitivity(&((devp)->thermo_if)) |
| typedef struct LPS22HBDriver LPS22HBDriver |
| enum lps22hb_sad_t |
| enum lps22hb_odr_t |
| enum lps22hb_lp_t |
| enum lps22hb_bdu_t |
| enum lps22hb_state_t |
static |
| [in] | reg | first sub-register address |
| [out] | rxbuf | pointer to an output buffer |
| [in] | n | number of consecutive register to read |
Definition at line 63 of file lps22hb.c.
References i2cMasterTransmitTimeout(), and TIME_INFINITE.
Referenced by baro_read_raw(), and thermo_read_raw().
static |
| [in] | ip | pointer to BaseBarometer interface. |
Definition at line 96 of file lps22hb.c.
References LPS22HB_BARO_NUMBER_OF_AXES.
Referenced by thermo_reset_sensitivity().
static |
Definition at line 118 of file lps22hb.c.
References I2C_READY, i2cAcquireBus(), i2cReleaseBus(), i2cStart(), LPS22HB_READY, lps22hbI2CReadRegister(), MSG_OK, objGetInstance, osalDbgAssert, and osalDbgCheck.
Referenced by baro_read_cooked(), and thermo_reset_sensitivity().
static |
Definition at line 170 of file lps22hb.c.
References baro_read_raw(), LPS22HB_READY, objGetInstance, osalDbgAssert, and osalDbgCheck.
static |
Definition at line 205 of file lps22hb.c.
References LPS22HB_READY, MSG_OK, objGetInstance, osalDbgAssert, and osalDbgCheck.
static |
Definition at line 231 of file lps22hb.c.
static |
Definition at line 259 of file lps22hb.c.
static |
Definition at line 284 of file lps22hb.c.
static |
| [in] | ip | pointer to BaseThermometer interface. |
Definition at line 307 of file lps22hb.c.
References LPS22HB_THERMO_NUMBER_OF_AXES.
static |
Definition at line 329 of file lps22hb.c.
Referenced by thermo_read_cooked(), and thermo_reset_sensitivity().
static |
| [out] | axis | a buffer which would be filled with cooked data. |
Definition at line 383 of file lps22hb.c.
References LPS22HB_READY, objGetInstance, osalDbgAssert, osalDbgCheck, and thermo_read_raw().
static |
Definition at line 415 of file lps22hb.c.
static |
Definition at line 442 of file lps22hb.c.
static |
Definition at line 471 of file lps22hb.c.
static |
Definition at line 497 of file lps22hb.c.
References baro_get_axes_number(), baro_read_cooked(), baro_read_raw(), baro_reset_bias(), baro_reset_sensitivity(), baro_set_bias(), baro_set_sensitivity(), LPS22HB_READY, MSG_OK, objGetInstance, osalDbgAssert, osalDbgCheck, thermo_get_axes_number(), thermo_read_cooked(), thermo_read_raw(), thermo_reset_bias(), thermo_set_bias(), and thermo_set_sensitivity().
| void lps22hbObjectInit | ( | LPS22HBDriver * | devp | ) |
| [out] | devp | pointer to the LPS22HBDriver object |
Definition at line 543 of file lps22hb.c.
References LPS22HBDriver::baro_if, LPS22HB_BARO_NUMBER_OF_AXES, LPS22HB_STOP, LPS22HB_THERMO_NUMBER_OF_AXES, LPS22HBDriver::thermo_if, BaseThermometer::vmt, BaseBarometer::vmt, and LPS22HBDriver::vmt.
| void lps22hbStart | ( | LPS22HBDriver * | devp, |
| const LPS22HBConfig * | config | ||
| [in] | devp | pointer to the LPS22HBDriver object |
| [in] | config | pointer to the LPS22HBConfig object |
Definition at line 565 of file lps22hb.c.
References I2CDriver::config, i2cAcquireBus(), LPS22HBConfig::i2cp, i2cReleaseBus(), i2cStart(), LPS22HB_READY, LPS22HB_STOP, lps22hbI2CWriteRegister, osalDbgAssert, osalDbgCheck, and osalThreadSleepMilliseconds.
| void lps22hbStop | ( | LPS22HBDriver * | devp | ) |
Definition at line 655 of file lps22hb.c.
References i2cAcquireBus(), i2cReleaseBus(), i2cStart(), i2cStop(), LPS22HB_READY, LPS22HB_STOP, lps22hbI2CWriteRegister, osalDbgAssert, and osalDbgCheck.
