lsm303agr.h File Reference
LSM303AGR MEMS interface module header. More...
#include "hal_accelerometer.h"
#include "hal_compass.h"
struct  LSM303AGRConfig
 LSM303AGR configuration structure. More...
struct  LSM303AGRVMT
 LSM303AGR virtual methods table. More...
struct  LSM303AGRDriver
 LSM303AGR 6-axis accelerometer/compass class. More...
#define lsm303agrAccelerometerGetAxesNumber(devp)   accelerometerGetAxesNumber(&((devp)->acc_if))
 Return the number of axes of the BaseAccelerometer. More...
#define lsm303agrAccelerometerReadRaw(devp, axes)   accelerometerReadRaw(&((devp)->acc_if), axes)
 Retrieves raw data from the BaseAccelerometer. More...
#define lsm303agrAccelerometerReadCooked(devp, axes)   accelerometerReadCooked(&((devp)->acc_if), axes)
 Retrieves cooked data from the BaseAccelerometer. More...
#define lsm303agrAccelerometerSetBias(devp, bp)   accelerometerSetBias(&((devp)->acc_if), bp)
 Set bias values for the BaseAccelerometer. More...
#define lsm303agrAccelerometerResetBias(devp)   accelerometerResetBias(&((devp)->acc_if))
 Reset bias values for the BaseAccelerometer. More...
#define lsm303agrAccelerometerSetSensitivity(devp, sp)   accelerometerSetSensitivity(&((devp)->acc_if), sp)
 Set sensitivity values for the BaseAccelerometer. More...
#define lsm303agrAccelerometerResetSensitivity(devp)   accelerometerResetSensitivity(&((devp)->acc_if))
 Reset sensitivity values for the BaseAccelerometer. More...
#define lsm303agrAccelerometerSetFullScale(devp, fs)   (devp)->vmt->acc_set_full_scale(devp, fs)
 Changes the LSM303AGRDriver accelerometer fullscale value. More...
#define lsm303agrCompassGetAxesNumber(devp)   compassGetAxesNumber(&((devp)->comp_if))
 Return the number of axes of the BaseCompass. More...
#define lsm303agrCompassReadRaw(devp, axes)   compassReadRaw(&((devp)->comp_if), axes)
 Retrieves raw data from the BaseCompass. More...
#define lsm303agrCompassReadCooked(devp, axes)   compassReadCooked(&((devp)->comp_if), axes)
 Retrieves cooked data from the BaseCompass. More...
#define lsm303agrCompassSetBias(devp, bp)   compassSetBias(&((devp)->comp_if), bp)
 Set bias values for the BaseCompass. More...
#define lsm303agrCompassResetBias(devp)   compassResetBias(&((devp)->comp_if))
 Reset bias values for the BaseCompass. More...
#define lsm303agrCompassSetSensitivity(devp, sp)   compassSetSensitivity(&((devp)->comp_if), sp)
 Set sensitivity values for the BaseCompass. More...
#define lsm303agrCompassResetSensitivity(devp)   compassResetSensitivity(&((devp)->comp_if))
 Reset sensitivity values for the BaseCompass. More...
Version identification
#define EX_LSM303AGR_VERSION   "1.0.0"
 LSM303AGR driver version string. More...
#define EX_LSM303AGR_MAJOR   1
 LSM303AGR driver version major number. More...
#define EX_LSM303AGR_MINOR   0
 LSM303AGR driver version minor number. More...
#define EX_LSM303AGR_PATCH   0
 LSM303AGR driver version patch number. More...
#define LSM303AGR_ACC_NUMBER_OF_AXES   3U
 LSM303AGR accelerometer subsystem characteristics. More...
#define LSM303AGR_COMP_NUMBER_OF_AXES   3U
 LSM303AGR compass subsystem characteristics. More...
LSM303AGR communication interfaces related bit masks
#define LSM303AGR_DI_MASK   0xFF
#define LSM303AGR_DI(n)   (1 << n)
#define LSM303AGR_AD_MASK   0x7F
#define LSM303AGR_AD(n)   (1 << n)
#define LSM303AGR_MS   (1 << 7)
LSM303AGR register addresses
#define LSM303AGR_AD_STATUS_REG_AUX_A   0x07
#define LSM303AGR_AD_OUT_TEMP_L_A   0x0C
#define LSM303AGR_AD_OUT_TEMP_H_A   0x0D
#define LSM303AGR_AD_INT_COUNTER_REG_A   0x0E
#define LSM303AGR_AD_WHO_AM_I_A   0x0F
#define LSM303AGR_AD_TEMP_CFG_REG_A   0x1F
#define LSM303AGR_AD_CTRL_REG1_A   0x20
#define LSM303AGR_AD_CTRL_REG2_A   0x21
#define LSM303AGR_AD_CTRL_REG3_A   0x22
#define LSM303AGR_AD_CTRL_REG4_A   0x23
#define LSM303AGR_AD_CTRL_REG5_A   0x24
#define LSM303AGR_AD_CTRL_REG6_A   0x25
#define LSM303AGR_AD_REFERENCE_A   0x26
#define LSM303AGR_AD_STATUS_REG_A   0x27
#define LSM303AGR_AD_OUT_X_L_A   0x28
#define LSM303AGR_AD_OUT_X_H_A   0x29
#define LSM303AGR_AD_OUT_Y_L_A   0x2A
#define LSM303AGR_AD_OUT_Y_H_A   0x2B
#define LSM303AGR_AD_OUT_Z_L_A   0x2C
#define LSM303AGR_AD_OUT_Z_H_A   0x2D
#define LSM303AGR_AD_FIFO_CTRL_REG_A   0x2E
#define LSM303AGR_AD_FIFO_SRC_REG_A   0x2F
#define LSM303AGR_AD_INT1_CFG_A   0x30
#define LSM303AGR_AD_INT1_SRC_A   0x31
#define LSM303AGR_AD_INT1_THS_A   0x32
#define LSM303AGR_AD_INT1_DURATION_A   0x33
#define LSM303AGR_AD_INT2_CFG_A   0x34
#define LSM303AGR_AD_INT2_SRC_A   0x35
#define LSM303AGR_AD_INT2_THS_A   0x36
#define LSM303AGR_AD_INT2_DURATION_A   0x37
#define LSM303AGR_AD_CLICK_CFG_A   0x38
#define LSM303AGR_AD_CLICK_SRC_A   0x39
#define LSM303AGR_AD_CLICK_THS_A   0x3A
#define LSM303AGR_AD_TIME_LIMIT_A   0x3B
#define LSM303AGR_AD_TIME_LATENCY_A   0x3C
#define LSM303AGR_AD_TIME_WINDOW_A   0x3D
#define LSM303AGR_AD_ACT_THS_A   0x3E
#define LSM303AGR_AD_ACT_DUR_A   0x3F
#define LSM303AGR_AD_OFFSET_X_REG_L_M   0x45
#define LSM303AGR_AD_OFFSET_X_REG_H_M   0x46
#define LSM303AGR_AD_OFFSET_Y_REG_L_M   0x47
#define LSM303AGR_AD_OFFSET_Y_REG_H_M   0x48
#define LSM303AGR_AD_OFFSET_Z_REG_L_M   0x49
#define LSM303AGR_AD_OFFSET_Z_REG_H_M   0x4A
#define LSM303AGR_AD_WHO_AM_I_M   0x4F
#define LSM303AGR_AD_CFG_REG_A_M   0x60
#define LSM303AGR_AD_CFG_REG_B_M   0x61
#define LSM303AGR_AD_CFG_REG_C_M   0x62
#define LSM303AGR_AD_INT_CRTL_REG_M   0x63
#define LSM303AGR_AD_INT_SOURCE_REG_M   0x64
#define LSM303AGR_AD_INT_THS_L_REG_M   0x65
#define LSM303AGR_AD_INT_THS_H_REG_M   0x66
#define LSM303AGR_AD_STATUS_REG_M   0x67
#define LSM303AGR_AD_OUTX_L_REG_M   0x68
#define LSM303AGR_AD_OUTX_H_REG_M   0x69
#define LSM303AGR_AD_OUTY_L_REG_M   0x6A
#define LSM303AGR_AD_OUTY_H_REG_M   0x6B
#define LSM303AGR_AD_OUTZ_L_REG_M   0x6C
#define LSM303AGR_AD_OUTZ_H_REG_M   0x6D
LSM303AGR_TEMP_CFG_REG_A register bits definitions
#define LSM303AGR_TEMP_CFG_REG_A_TEMP_EN0   (1 << 0)
#define LSM303AGR_TEMP_CFG_REG_A_TEMP_EN1   (1 << 0)
LSM303AGR_CTRL_REG1_A register bits definitions
#define LSM303AGR_CTRL_REG1_A_XEN   (1 << 0)
#define LSM303AGR_CTRL_REG1_A_YEN   (1 << 1)
#define LSM303AGR_CTRL_REG1_A_ZEN   (1 << 2)
#define LSM303AGR_CTRL_REG1_A_LPEN   (1 << 3)
#define LSM303AGR_CTRL_REG1_A_ODR0   (1 << 4)
#define LSM303AGR_CTRL_REG1_A_ODR1   (1 << 5)
#define LSM303AGR_CTRL_REG1_A_ODR2   (1 << 6)
#define LSM303AGR_CTRL_REG1_A_ODR3   (1 << 7)
LSM303AGR_CTRL_REG2_A register bits definitions
#define LSM303AGR_CTRL_REG2_A_HPIS1   (1 << 0)
#define LSM303AGR_CTRL_REG2_A_HPIS2   (1 << 1)
#define LSM303AGR_CTRL_REG2_A_HPCLICK   (1 << 2)
#define LSM303AGR_CTRL_REG2_A_FDS   (1 << 3)
#define LSM303AGR_CTRL_REG2_A_HPCF1   (1 << 4)
#define LSM303AGR_CTRL_REG2_A_HPCF2   (1 << 5)
#define LSM303AGR_CTRL_REG2_A_HPM0   (1 << 6)
#define LSM303AGR_CTRL_REG2_A_HPM1   (1 << 7)
LSM303AGR_CTRL_REG3_A register bits definitions
#define LSM303AGR_CTRL_REG3_A_I1_OVERRUN   (1 << 1)
#define LSM303AGR_CTRL_REG3_A_I1_WTM   (1 << 2)
#define LSM303AGR_CTRL_REG3_A_I1_DRDY2   (1 << 3)
#define LSM303AGR_CTRL_REG3_A_I1_DRDY1   (1 << 4)
#define LSM303AGR_CTRL_REG3_A_I1_AOI2   (1 << 5)
#define LSM303AGR_CTRL_REG3_A_I1_AOI1   (1 << 6)
#define LSM303AGR_CTRL_REG3_A_I1_CLICK   (1 << 7)
LSM303AGR_CTRL_REG4_A register bits definitions
#define LSM303AGR_CTRL_REG4_A_SPI_ENABLE   (1 << 0)
#define LSM303AGR_CTRL_REG4_A_ST0   (1 << 1)
#define LSM303AGR_CTRL_REG4_A_ST1   (1 << 2)
#define LSM303AGR_CTRL_REG4_A_HR   (1 << 3)
#define LSM303AGR_CTRL_REG4_A_FS_MASK   0x30
#define LSM303AGR_CTRL_REG4_A_FS0   (1 << 4)
#define LSM303AGR_CTRL_REG4_A_FS1   (1 << 5)
#define LSM303AGR_CTRL_REG4_A_BLE   (1 << 6)
#define LSM303AGR_CTRL_REG4_A_BDU   (1 << 7)
LSM303AGR_CTRL_REG5_A register bits definitions
#define LSM303AGR_CTRL_REG5_A_D4D_INT2   (1 << 0)
#define LSM303AGR_CTRL_REG5_A_LIR_INT2   (1 << 1)
#define LSM303AGR_CTRL_REG5_A_D4D_INT1   (1 << 2)
#define LSM303AGR_CTRL_REG5_A_LIR_INT1   (1 << 3)
#define LSM303AGR_CTRL_REG5_A_FIFO_EN   (1 << 6)
#define LSM303AGR_CTRL_REG5_A_BOOT   (1 << 7)
LSM303AGR_CTRL_REG6_A register bits definitions
#define LSM303AGR_CTRL_REG6_A_H_LACTIVE   (1 << 1)
#define LSM303AGR_CTRL_REG6_A_P2_ACT   (1 << 3)
#define LSM303AGR_CTRL_REG6_A_BOOT_I2   (1 << 4)
#define LSM303AGR_CTRL_REG6_A_I2_INT2   (1 << 5)
#define LSM303AGR_CTRL_REG6_A_I2_INT1   (1 << 6)
#define LSM303AGR_CTRL_REG6_A_I2_CLICKEN   (1 << 7)
LSM303AGR_CFG_REG_A register bits definitions
#define LSM303AGR_CFG_REG_A_M_MD0   (1 << 0)
#define LSM303AGR_CFG_REG_A_M_MD1   (1 << 1)
#define LSM303AGR_CFG_REG_A_M_ODR0   (1 << 2)
#define LSM303AGR_CFG_REG_A_M_ODR1   (1 << 3)
#define LSM303AGR_CFG_REG_A_M_LP   (1 << 4)
#define LSM303AGR_CFG_REG_A_M_SOFT_RST   (1 << 5)
#define LSM303AGR_CFG_REG_A_M_REBOOT   (1 << 6)
#define LSM303AGR_CFG_REG_A_M_COMP_TEMP_EN   (1 << 7)
LSM303AGR_CFG_REG_B register bits definitions
#define LSM303AGR_CFG_REG_B_M_LPF   (1 << 0)
#define LSM303AGR_CFG_REG_B_M_OFF_CANC   (1 << 1)
#define LSM303AGR_CFG_REG_B_M_SET_FREQ   (1 << 2)
#define LSM303AGR_CFG_REG_B_M_INT_ON   (1 << 3)
#define LSM303AGR_CFG_REG_B_M_OFF_CANC_OS   (1 << 4)
LSM303AGR_CFG_REG_C register bits definitions
#define LSM303AGR_CFG_REG_C_M_INT_MAG   (1 << 0)
#define LSM303AGR_CFG_REG_C_M_SELF_TEST   (1 << 1)
#define LSM303AGR_CFG_REG_C_M_BLE   (1 << 3)
#define LSM303AGR_CFG_REG_C_M_BDU   (1 << 4)
#define LSM303AGR_CFG_REG_C_M_I2C_DIS   (1 << 5)
#define LSM303AGR_CFG_REG_C_M_INT_MAG_PIN   (1 << 6)
Configuration options
#define LSM303AGR_USE_SPI   FALSE
 LSM303AGR SPI interface switch. More...
#define LSM303AGR_SHARED_SPI   FALSE
 LSM303AGR shared SPI switch. More...
#define LSM303AGR_USE_I2C   TRUE
 LSM303AGR I2C interface switch. More...
#define LSM303AGR_SHARED_I2C   FALSE
 LSM303AGR shared I2C switch. More...
#define LSM303AGR_ACC_USE_ADVANCED   FALSE
 LSM303AGR accelerometer subsystem advanced configurations switch. More...
#define LSM303AGR_COMP_USE_ADVANCED   FALSE
 LSM303AGR compass subsystem advanced configurations switch. More...
Enumerations
LSM303AGR compass subsystem data structures and types.
void lsm303agrObjectInit (LSM303AGRDriver *devp)
 Initializes an instance. More...
void lsm303agrStart (LSM303AGRDriver *devp, const LSM303AGRConfig *config)
 Configures and activates LSM303AGR Complex Driver peripheral. More...
void lsm303agrStop (LSM303AGRDriver *devp)
 Deactivates the LSM303AGR Complex Driver peripheral. More...
LSM303AGR accelerometer subsystem data structures and types.
Todo:
Add support for LSM303AGR over SPI.
typedef struct LSM303AGRDriver LSM303AGRDriver
 Structure representing a LSM303AGR driver. More...
LSM303AGR main system data structures and types.
#define _lsm303agr_methods_alone
 LSM303AGR specific methods. More...
 LSM303AGR specific methods with inherited ones. More...
#define _lsm303agr_data
 LSM303AGRDriver specific data. More...
Definition in file lsm303agr.h.
