ch_trace_event_t Struct Reference
Trace buffer record. More...
#include <chtrace.h>
Collaboration diagram for ch_trace_event_t:
uint32_t type:3
 Record type. More...
uint32_t state:5
 Switched out thread state. More...
uint32_t rtstamp:24
 Accurate time stamp. More...
systime_t time
 System time stamp of the switch event. More...
thread_tntp
 Switched in thread. More...
void * wtobjp
 Object where going to sleep. More...
struct {
   thread_t *   ntp
   void *   wtobjp
sw
 Structure representing a context switch. More...
const char * name
 ISR function name taken using func. More...
struct {
   const char *   name
isr
 Structure representing an ISR enter. More...
const char * reason
 Halt error string. More...
struct {
   const char *   reason
halt
 Structure representing an halt. More...
void * up1
 Trace user parameter 1. More...
void * up2
 Trace user parameter 2. More...
struct {
   void *   up1
   void *   up2
user
 User trace structure. More...
Definition at line 104 of file chtrace.h.
uint32_t ch_trace_event_t::type
Record type.
Definition at line 108 of file chtrace.h.
Referenced by _trace_halt(), _trace_init(), _trace_isr_enter(), _trace_isr_leave(), _trace_switch(), and chDbgWriteTraceI().
uint32_t ch_trace_event_t::state
Definition at line 112 of file chtrace.h.
Referenced by _trace_halt(), _trace_isr_enter(), _trace_isr_leave(), _trace_switch(), and chDbgWriteTraceI().
uint32_t ch_trace_event_t::rtstamp
This field only available if the post supports PORT_SUPPORTS_RT else it is set to zero.
Definition at line 118 of file chtrace.h.
Referenced by trace_next().
systime_t ch_trace_event_t::time
Definition at line 122 of file chtrace.h.
thread_t* ch_trace_event_t::ntp
Switched in thread.
Definition at line 131 of file chtrace.h.
void* ch_trace_event_t::wtobjp
Definition at line 135 of file chtrace.h.
struct { ... } ch_trace_event_t::sw
Referenced by _trace_switch().
const char* ch_trace_event_t::name
Definition at line 144 of file chtrace.h.
struct { ... } ch_trace_event_t::isr
Referenced by _trace_isr_enter(), and _trace_isr_leave().
const char* ch_trace_event_t::reason
Halt error string.
Definition at line 153 of file chtrace.h.
struct { ... } ch_trace_event_t::halt
Referenced by _trace_halt().
void* ch_trace_event_t::up1
Definition at line 162 of file chtrace.h.
void* ch_trace_event_t::up2
Definition at line 166 of file chtrace.h.
struct { ... } ch_trace_event_t::user
Referenced by chDbgWriteTraceI().
