I2C Driver
Generic I2C Driver. More...
Collaboration diagram for I2C Driver:
Generic I2C Driver.
This module implements a generic I2C (Inter-Integrated Circuit) driver.
Precondition
In order to use the I2C driver the HAL_USE_I2C option must be enabled in halconf.h.
Driver State Machine
The driver implements a state machine internally, not all the driver functionalities can be used in any moment, any transition not explicitly shown in the following diagram has to be considered an error and shall be captured by an assertion (if enabled).
The driver is not thread safe for performance reasons, if you need to access the I2C bus from multiple threads then use the i2cAcquireBus() and i2cReleaseBus() APIs in order to gain exclusive access.
#define I2C_USE_MUTUAL_EXCLUSION   TRUE
 Enables the mutual exclusion APIs on the I2C bus. More...
#define _i2c_wakeup_isr(i2cp)
 Wakes up the waiting thread notifying no errors. More...
#define _i2c_wakeup_error_isr(i2cp)
 Wakes up the waiting thread notifying errors. More...
#define i2cMasterTransmit(i2cp, addr, txbuf, txbytes, rxbuf, rxbytes)
 Wrap i2cMasterTransmitTimeout function with TIME_INFINITE timeout. More...
#define i2cMasterReceive(i2cp, addr, rxbuf, rxbytes)   (i2cMasterReceiveTimeout(i2cp, addr, rxbuf, rxbytes, TIME_INFINITE))
 Wrap i2cMasterReceiveTimeout function with TIME_INFINITE timeout. More...
#define i2c_lld_get_errors(i2cp)   ((i2cp)->errors)
 Get errors from I2C driver. More...
I2C bus error conditions
#define I2C_NO_ERROR   0x00
 No error. More...
#define I2C_BUS_ERROR   0x01
 Bus Error. More...
#define I2C_ARBITRATION_LOST   0x02
 Arbitration Lost. More...
#define I2C_ACK_FAILURE   0x04
 Acknowledge Failure. More...
#define I2C_OVERRUN   0x08
 Overrun/Underrun. More...
#define I2C_PEC_ERROR   0x10
 PEC Error in reception. More...
#define I2C_TIMEOUT   0x20
 Hardware timeout. More...
#define I2C_SMB_ALERT   0x40
 SMBus Alert. More...
PLATFORM configuration options
#define PLATFORM_I2C_USE_I2C1   FALSE
 I2C1 driver enable switch. More...
typedef uint16_t i2caddr_t
 Type representing an I2C address. More...
typedef uint32_t i2cflags_t
 Type of I2C Driver condition flags. More...
typedef struct I2CDriver I2CDriver
 Type of a structure representing an I2C driver. More...
struct  I2CConfig
 Type of I2C driver configuration structure. More...
struct  I2CDriver
 Structure representing an I2C driver. More...
void i2cInit (void)
 I2C Driver initialization. More...
void i2cObjectInit (I2CDriver *i2cp)
 Initializes the standard part of a I2CDriver structure. More...
void i2cStart (I2CDriver *i2cp, const I2CConfig *config)
 Configures and activates the I2C peripheral. More...
void i2cStop (I2CDriver *i2cp)
 Deactivates the I2C peripheral. More...
i2cflags_t i2cGetErrors (I2CDriver *i2cp)
 Returns the errors mask associated to the previous operation. More...
msg_t i2cMasterTransmitTimeout (I2CDriver *i2cp, i2caddr_t addr, const uint8_t *txbuf, size_t txbytes, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Sends data via the I2C bus. More...
msg_t i2cMasterReceiveTimeout (I2CDriver *i2cp, i2caddr_t addr, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Receives data from the I2C bus. More...
void i2cAcquireBus (I2CDriver *i2cp)
 Gains exclusive access to the I2C bus. More...
void i2cReleaseBus (I2CDriver *i2cp)
 Releases exclusive access to the I2C bus. More...
void i2c_lld_init (void)
 Low level I2C driver initialization. More...
void i2c_lld_start (I2CDriver *i2cp)
void i2c_lld_stop (I2CDriver *i2cp)
msg_t i2c_lld_master_receive_timeout (I2CDriver *i2cp, i2caddr_t addr, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Receives data via the I2C bus as master. More...
msg_t i2c_lld_master_transmit_timeout (I2CDriver *i2cp, i2caddr_t addr, const uint8_t *txbuf, size_t txbytes, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Transmits data via the I2C bus as master. More...
Enumerations
Variables
I2CDriver I2CD1
 I2C1 driver identifier. More...
No error.
Definition at line 43 of file hal_i2c.h.
Referenced by i2cMasterReceiveTimeout(), and i2cMasterTransmitTimeout().
Bus Error.
Definition at line 44 of file hal_i2c.h.
Arbitration Lost.
Definition at line 45 of file hal_i2c.h.
Definition at line 46 of file hal_i2c.h.
Overrun/Underrun.
Definition at line 47 of file hal_i2c.h.
Definition at line 48 of file hal_i2c.h.
Hardware timeout.
Definition at line 51 of file hal_i2c.h.
SMBus Alert.
Definition at line 52 of file hal_i2c.h.
Definition at line 63 of file hal_i2c.h.
#define _i2c_wakeup_isr (   i2cp)
Value:
do { \
osalThreadResumeI(&(i2cp)->thread, MSG_OK); \
} while(0)
static void osalSysLockFromISR(void)
Enters a critical zone from ISR context.
Definition: osal.h:550
static void osalSysUnlockFromISR(void)
Leaves a critical zone from ISR context.
Definition: osal.h:560
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
void osalThreadResumeI(thread_reference_t *trp, msg_t msg)
Wakes up a thread waiting on a thread reference object.
Definition: osal.c:230
Parameters
[in]i2cppointer to the I2CDriver object
Function Class:Not an API, this function is for internal use only.
Definition at line 99 of file hal_i2c.h.
#define _i2c_wakeup_error_isr (   i2cp)
Value:
do { \
osalThreadResumeI(&(i2cp)->thread, MSG_RESET); \
} while(0)
#define MSG_RESET
Definition: chschd.h:43
Parameters
Definition at line 112 of file hal_i2c.h.
#define i2cMasterTransmit (   i2cp,
  addr,
  txbuf,
  txbytes,
  rxbuf,
  rxbytes
Value:
(i2cMasterTransmitTimeout(i2cp, addr, txbuf, txbytes, rxbuf, rxbytes, \
msg_t i2cMasterTransmitTimeout(I2CDriver *i2cp, i2caddr_t addr, const uint8_t *txbuf, size_t txbytes, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
Definition: hal_i2c.c:170
#define TIME_INFINITE
Infinite interval specification for all functions with a timeout specification.
Definition: chtime.h:55
Definition at line 122 of file hal_i2c.h.
#define i2cMasterReceive (   i2cp,
  addr,
  rxbuf,
  rxbytes
Definition at line 130 of file hal_i2c.h.
If set to TRUE the support for I2C1 is included.
The default is FALSE.
Definition at line 48 of file hal_i2c_lld.h.
#define i2c_lld_get_errors (   i2cp)    ((i2cp)->errors)
Parameters
Definition at line 121 of file hal_i2c_lld.h.
Referenced by i2cGetErrors().
Typedef Documentation
Definition at line 63 of file hal_i2c_lld.h.
Definition at line 68 of file hal_i2c_lld.h.
Definition at line 83 of file hal_i2c_lld.h.
Enumeration Type Documentation
enum i2cstate_t
Enumerator
I2C_UNINIT
Not initialized.
I2C_STOP
Stopped.
I2C_READY
Ready.
I2C_ACTIVE_TX
Transmitting.
I2C_ACTIVE_RX
Receiving.
Definition at line 77 of file hal_i2c.h.
Function Documentation
void i2cInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 59 of file hal_i2c.c.
References i2c_lld_init().
Referenced by halInit().
void i2cObjectInit ( I2CDriver i2cp)
Parameters
[out]i2cppointer to the I2CDriver object
Definition at line 71 of file hal_i2c.c.
References I2CDriver::config, I2C_STOP, osalMutexObjectInit(), and I2CDriver::state.
Referenced by i2c_lld_init().
void i2cStart ( I2CDriver i2cp,
const I2CConfig config
Parameters
[in]configpointer to the I2CConfig object
Definition at line 93 of file hal_i2c.c.
References I2CDriver::config, i2c_lld_start(), I2C_READY, I2C_STOP, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and I2CDriver::state.
Referenced by acc_read_raw(), acc_set_full_scale(), baro_read_raw(), bmp085Start(), bmp085Stop(), comp_read_raw(), comp_set_full_scale(), gyro_read_raw(), gyro_set_full_scale(), hts221Calibrate(), hts221Start(), hts221Stop(), hygro_read_raw(), lis3mdlStart(), lis3mdlStop(), lps22hbStart(), lps22hbStop(), lps25hStart(), lps25hStop(), lsm303agrStart(), lsm303agrStop(), lsm303dlhcStart(), lsm303dlhcStop(), lsm6ds0Start(), lsm6ds0Stop(), lsm6dslStart(), lsm6dslStop(), and thermo_read_raw().
void i2cStop ( I2CDriver i2cp)
Parameters
Definition at line 113 of file hal_i2c.c.
References I2CDriver::config, i2c_lld_stop(), I2C_READY, I2C_STOP, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and I2CDriver::state.
Referenced by hts221Stop(), lis3mdlStop(), lps22hbStop(), lps25hStop(), lsm303agrStop(), lsm303dlhcStop(), lsm6ds0Stop(), and lsm6dslStop().
i2cflags_t i2cGetErrors ( I2CDriver i2cp)
Parameters
Returns
The errors mask.
Definition at line 137 of file hal_i2c.c.
References i2c_lld_get_errors, and osalDbgCheck.
msg_t i2cMasterTransmitTimeout ( I2CDriver i2cp,
i2caddr_t  addr,
const uint8_t *  txbuf,
size_t  txbytes,
uint8_t *  rxbuf,
size_t  rxbytes,
Function designed to realize "read-through-write" transfer paradigm. If you want transmit data without any further read, than set rxbytes field to 0.
Parameters
[in]addrslave device address (7 bits) without R/W bit
[in]txbufpointer to transmit buffer
[in]txbytesnumber of bytes to be transmitted
[out]rxbufpointer to receive buffer
[in]rxbytesnumber of bytes to be received, set it to 0 if you want transmit only
[in]timeoutthe number of ticks before the operation timeouts, the following special values are allowed:
  • TIME_INFINITE no timeout.
Returns
The operation status.
Return values
MSG_OKif the function succeeded.
MSG_RESETif one or more I2C errors occurred, the errors can be retrieved using i2cGetErrors().
MSG_TIMEOUTif a timeout occurred before operation end.
Definition at line 170 of file hal_i2c.c.
References I2CDriver::errors, I2C_ACTIVE_TX, i2c_lld_master_transmit_timeout(), I2C_NO_ERROR, I2C_READY, MSG_TIMEOUT, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), I2CDriver::state, and TIME_IMMEDIATE.
Referenced by bmp085I2CReadRegister(), bmp085I2CWriteRegister(), hts221I2CReadRegister(), hts221I2CWriteRegister(), lis3mdlI2CReadRegister(), lis3mdlI2CWriteRegister(), lps22hbI2CReadRegister(), lps25hI2CReadRegister(), lps25hI2CWriteRegister(), lsm303agrI2CReadRegister(), lsm303agrI2CWriteRegister(), lsm303dlhcI2CReadRegister(), lsm303dlhcI2CWriteRegister(), lsm6ds0I2CReadRegister(), and lsm6dslI2CReadRegister().
msg_t i2cMasterReceiveTimeout ( I2CDriver i2cp,
i2caddr_t  addr,
uint8_t *  rxbuf,
size_t  rxbytes,
Parameters
Returns
Return values
Definition at line 221 of file hal_i2c.c.
References I2CDriver::errors, I2C_ACTIVE_RX, i2c_lld_master_receive_timeout(), I2C_NO_ERROR, I2C_READY, MSG_TIMEOUT, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), I2CDriver::state, and TIME_IMMEDIATE.
void i2cAcquireBus ( I2CDriver i2cp)
This function tries to gain ownership to the I2C bus, if the bus is already being used then the invoking thread is queued.
Precondition
In order to use this function the option I2C_USE_MUTUAL_EXCLUSION must be enabled.
Parameters
Definition at line 261 of file hal_i2c.c.
References osalDbgCheck, and osalMutexLock().
Referenced by acc_read_raw(), acc_set_full_scale(), acquire_up(), acquire_ut(), baro_read_raw(), bmp085ReadCoefficient(), bmp085Start(), bmp085Stop(), comp_read_raw(), comp_set_full_scale(), gyro_read_raw(), gyro_set_full_scale(), hts221Calibrate(), hts221Start(), hts221Stop(), hygro_read_raw(), lis3mdlStart(), lis3mdlStop(), lps22hbStart(), lps22hbStop(), lps25hStart(), lps25hStop(), lsm303agrStart(), lsm303agrStop(), lsm303dlhcStart(), lsm303dlhcStop(), lsm6ds0Start(), lsm6ds0Stop(), lsm6dslStart(), lsm6dslStop(), start_p_measurement(), start_t_measurement(), and thermo_read_raw().
void i2cReleaseBus ( I2CDriver i2cp)
Precondition
Parameters
Definition at line 277 of file hal_i2c.c.
References osalDbgCheck, and osalMutexUnlock().
void i2c_lld_init ( void  )
Definition at line 65 of file hal_i2c_lld.c.
References i2cObjectInit().
Referenced by i2cInit().
void i2c_lld_start ( I2CDriver i2cp)
Parameters
Definition at line 79 of file hal_i2c_lld.c.
References I2C_STOP, and I2CDriver::state.
Referenced by i2cStart().
void i2c_lld_stop ( I2CDriver i2cp)
Parameters
Definition at line 99 of file hal_i2c_lld.c.
Referenced by i2cStop().
msg_t i2c_lld_master_receive_timeout ( I2CDriver i2cp,
i2caddr_t  addr,
uint8_t *  rxbuf,
size_t  rxbytes,
Parameters
[out]rxbufpointer to the receive buffer
Returns
Return values
MSG_TIMEOUTif a timeout occurred before operation end. After a timeout the driver must be stopped and restarted because the bus is in an uncertain state.
Definition at line 133 of file hal_i2c_lld.c.
References MSG_OK.
Referenced by i2cMasterReceiveTimeout().
msg_t i2c_lld_master_transmit_timeout ( I2CDriver i2cp,
i2caddr_t  addr,
size_t  txbytes,
uint8_t *  rxbuf,
size_t  rxbytes,
Parameters
[in]txbufpointer to the transmit buffer
Returns
Return values
Definition at line 169 of file hal_i2c_lld.c.
References MSG_OK.
Referenced by i2cMasterTransmitTimeout().
Variable Documentation
I2CDriver I2CD1
Definition at line 41 of file hal_i2c_lld.c.
