Abstract I/O Channel
Collaboration diagram for Abstract I/O Channel:
This module defines an abstract interface for I/O channels by extending the BaseSequentialStream interface.
Note that no code is present, I/O channels are just abstract interface like structures, you should look at the systems as to a set of abstract C++ classes (even if written in C). Specific device drivers can use/extend the interface and implement them.
This system has the advantage to make the access to channels independent from the implementation logic.
#define _base_channel_methods
 BaseChannel specific methods. More...
#define _base_channel_data   _base_sequential_stream_data
 BaseChannel specific data. More...
#define _base_asynchronous_channel_methods   _base_channel_methods \
 BaseAsynchronousChannel specific methods. More...
#define _base_asynchronous_channel_data
 BaseAsynchronousChannel specific data. More...
Default control operation codes.
#define CHN_CTL_INVALID   0 /** @brief Invalid operation code. */
#define CHN_CTL_NOP   1 /** @brief Does nothing. */
#define CHN_CTL_TX_WAIT   2 /** @brief Wait for TX completion. */
Macro Functions (BaseChannel)
#define chnPutTimeout(ip, b, time)   ((ip)->vmt->putt(ip, b, time))
 Channel blocking byte write with timeout. More...
#define chnGetTimeout(ip, time)   ((ip)->vmt->gett(ip, time))
 Channel blocking byte read with timeout. More...
#define chnWrite(ip, bp, n)   streamWrite(ip, bp, n)
 Channel blocking write. More...
#define chnWriteTimeout(ip, bp, n, time)   ((ip)->vmt->writet(ip, bp, n, time))
 Channel blocking write with timeout. More...
#define chnRead(ip, bp, n)   streamRead(ip, bp, n)
 Channel blocking read. More...
#define chnReadTimeout(ip, bp, n, time)   ((ip)->vmt->readt(ip, bp, n, time))
 Channel blocking read with timeout. More...
#define chnControl(ip, operation, arg)   ((ip)->vmt->ctl(ip, operation, arg)
 Control operation on a channel. More...
I/O status flags added to the event listener
#define CHN_NO_ERROR   (eventflags_t)0
 No pending conditions. More...
#define CHN_CONNECTED   (eventflags_t)1
 Connection happened. More...
#define CHN_DISCONNECTED   (eventflags_t)2
 Disconnection happened. More...
#define CHN_INPUT_AVAILABLE   (eventflags_t)4
 Data available in the input queue. More...
#define CHN_OUTPUT_EMPTY   (eventflags_t)8
 Output queue empty. More...
#define CHN_TRANSMISSION_END   (eventflags_t)16
 Transmission end. More...
Macro Functions (BaseAsynchronousChannel)
#define chnGetEventSource(ip)   (&((ip)->event))
 Returns the I/O condition event source. More...
#define chnAddFlagsI(ip, flags)
 Adds status flags to the listeners's flags mask. More...
struct  BaseChannelVMT
 BaseChannel virtual methods table. More...
struct  BaseChannel
 Base channel class. More...
struct  BaseAsynchronousChannelVMT
 BaseAsynchronousChannel virtual methods table. More...
 Base asynchronous channel class. More...
Value:
/* Channel put method with timeout specification.*/ \
msg_t (*putt)(void *instance, uint8_t b, sysinterval_t time); \
/* Channel get method with timeout specification.*/ \
msg_t (*gett)(void *instance, sysinterval_t time); \
/* Channel write method with timeout specification.*/ \
size_t (*writet)(void *instance, const uint8_t *bp, \
size_t n, sysinterval_t time); \
/* Channel read method with timeout specification.*/ \
size_t (*readt)(void *instance, uint8_t *bp, size_t n, \
/* Channel control method.*/ \
msg_t (*ctl)(void *instance, unsigned int operation, void *arg);
uint64_t sysinterval_t
Type of time interval.
Definition: chtime.h:119
#define _base_sequential_stream_methods
BaseSequentialStream specific methods.
Definition: hal_streams.h:50
int32_t msg_t
Definition: chtypes.h:51
Definition at line 51 of file hal_channels.h.
It is empty because BaseChannel is only an interface without implementation.
Definition at line 71 of file hal_channels.h.
#define chnPutTimeout (   ip,
  b,
  time
This function writes a byte value to a channel. If the channel is not ready to accept data then the calling thread is suspended.
Parameters
[in]ippointer to a BaseChannel or derived class
[in]bthe byte value to be written to the channel
[in]timethe number of ticks before the operation timeouts, the following special values are allowed:
  • TIME_IMMEDIATE immediate timeout.
  • TIME_INFINITE no timeout.
Returns
The operation status.
Return values
STM_OKif the operation succeeded.
STM_TIMEOUTif the specified time expired.
STM_RESETif the channel associated queue (if any) was reset.
Definition at line 119 of file hal_channels.h.
#define chnGetTimeout (   ip,
  time
This function reads a byte value from a channel. If the data is not available then the calling thread is suspended.
Parameters
Returns
A byte value from the queue.
Return values
STM_RESETif the channel associated queue (if any) has been reset.
Definition at line 139 of file hal_channels.h.
#define chnWrite (   ip,
  bp,
The function writes data from a buffer to a channel. If the channel is not ready to accept data then the calling thread is suspended.
Parameters
[out]bppointer to the data buffer
[in]nthe maximum amount of data to be transferred
Returns
The number of bytes transferred.
Definition at line 154 of file hal_channels.h.
#define chnWriteTimeout (   ip,
  bp,
  n,
  time
Parameters
Returns
Definition at line 173 of file hal_channels.h.
#define chnRead (   ip,
  bp,
The function reads data from a channel into a buffer. If the data is not available then the calling thread is suspended.
Parameters
[in]bppointer to the data buffer
Returns
Definition at line 188 of file hal_channels.h.
#define chnReadTimeout (   ip,
  bp,
  n,
  time
Parameters
Returns
Definition at line 207 of file hal_channels.h.
#define chnControl (   ip,
  operation,
  arg
Parameters
[in]operationcontrol operation code
[in,out]argoperation argument
Returns
The control operation status.
Return values
MSG_OKin case of success.
MSG_TIMEOUTin case of operation timeout.
MSG_RESETin case of operation reset.
Definition at line 223 of file hal_channels.h.
Definition at line 231 of file hal_channels.h.
Definition at line 233 of file hal_channels.h.
Referenced by sduConfigureHookI(), and sduWakeupHookI().
Definition at line 235 of file hal_channels.h.
Referenced by sduStop(), and sduSuspendHookI().
Definition at line 237 of file hal_channels.h.
Referenced by sdIncomingDataI(), and sduDataReceived().
Output queue empty.
Definition at line 239 of file hal_channels.h.
Referenced by sdRequestDataI(), and sduDataTransmitted().
Transmission end.
Definition at line 241 of file hal_channels.h.
Definition at line 247 of file hal_channels.h.
Value:
/* I/O condition event source.*/ \
Definition: hal_channels.h:71
struct event_source event_source_t
Event Source structure.
Definition at line 253 of file hal_channels.h.
#define chnGetEventSource (   ip)    (&((ip)->event))
The event source is broadcasted when an I/O condition happens.
Parameters
[in]ippointer to a BaseAsynchronousChannel or derived class
Returns
A pointer to an EventSource object.
Definition at line 294 of file hal_channels.h.
#define chnAddFlagsI (   ip,
  flags
Value:
osalEventBroadcastFlagsI(&(ip)->event, flags); \
void osalEventBroadcastFlagsI(event_source_t *esp, eventflags_t flags)
Add flags to an event source object.
Definition: osal.c:323
This function is usually called from the I/O ISRs in order to notify I/O conditions such as data events, errors, signal changes etc.
Parameters
[in]flagscondition flags to be added to the listener flags mask
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 308 of file hal_channels.h.
Referenced by sdIncomingDataI(), sdRequestDataI(), sduConfigureHookI(), sduDataReceived(), sduDataTransmitted(), sduStop(), sduSuspendHookI(), and sduWakeupHookI().
