hal_wdg.c
18  * @file hal_wdg.c
19  * @brief WDG Driver code.
21  * @addtogroup WDG
27 #if (HAL_USE_WDG == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables. */
46 /* Driver exported functions. */
49 /**
50  * @brief WDG Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void wdgInit(void) {
57
58  wdg_lld_init();
59 }
60
61 /**
62  * @brief Configures and activates the WDG peripheral.
63  *
64  * @param[in] wdgp pointer to the @p WDGDriver object
65  * @param[in] config pointer to the @p WDGConfig object
66  *
67  * @api
68  */
69 void wdgStart(WDGDriver *wdgp, const WDGConfig *config) {
70
71  osalDbgCheck((wdgp != NULL) && (config != NULL));
72
73  osalSysLock();
74  osalDbgAssert((wdgp->state == WDG_STOP) || (wdgp->state == WDG_READY),
75  "invalid state");
76  wdgp->config = config;
77  wdg_lld_start(wdgp);
78  wdgp->state = WDG_READY;
79  osalSysUnlock();
80 }
81
82 /**
83  * @brief Deactivates the WDG peripheral.
84  *
85  * @param[in] wdgp pointer to the @p WDGDriver object
86  *
87  * @api
88  */
89 void wdgStop(WDGDriver *wdgp) {
90
91  osalDbgCheck(wdgp != NULL);
92
93  osalSysLock();
94
95  osalDbgAssert((wdgp->state == WDG_STOP) || (wdgp->state == WDG_READY),
96  "invalid state");
97
98  wdg_lld_stop(wdgp);
99  wdgp->config = NULL;
100  wdgp->state = WDG_STOP;
101
102  osalSysUnlock();
103 }
104
105 /**
106  * @brief Resets WDG's counter.
107  *
108  * @param[in] wdgp pointer to the @p WDGDriver object
109  *
110  * @api
111  */
112 void wdgReset(WDGDriver *wdgp) {
113
114  osalDbgCheck(wdgp != NULL);
115
116  osalSysLock();
117  osalDbgAssert(wdgp->state == WDG_READY, "not ready");
118  wdgResetI(wdgp);
119  osalSysUnlock();
120 }
121
122 #endif /* HAL_USE_WDG == TRUE */
123
124 /** @} */
#define wdgResetI(wdgp)
Definition: hal_wdg.h:68
void wdg_lld_start(WDGDriver *wdgp)
Definition: hal_wdg_lld.c:73
void wdg_lld_stop(WDGDriver *wdgp)
Definition: hal_wdg_lld.c:85
Definition: osal.h:540
wdgstate_t state
Definition: hal_wdg_lld.h:78
const WDGConfig * config
Current configuration data.
Definition: hal_wdg_lld.h:82
Definition: hal_wdg.c:89
void wdgInit(void)
Definition: hal_wdg.c:56
static void osalSysLock(void)
Definition: osal.h:530
Structure representing an WDG driver.
Definition: hal_wdg_lld.h:74
Definition: hal_wdg.c:69
Definition: hal_wdg.c:112
void wdg_lld_init(void)
Low level WDG driver initialization.
Definition: hal_wdg_lld.c:62
Definition: hal_wdg_lld.h:68
