Collaboration diagram for Pipes:
#define _PIPE_DATA(name, buffer, size)
 Data part of a static pipe initializer. More...
#define PIPE_DECL(name, buffer, size)   pipe_t name = _PIPE_DATA(name, buffer, size)
 Static pipe initializer. More...
struct  pipe_t
 Structure representing a pipe object. More...
void chPipeObjectInit (pipe_t *pp, uint8_t *buf, size_t n)
 Initializes a mailbox_t object. More...
void chPipeReset (pipe_t *pp)
 Resets a pipe_t object. More...
size_t chPipeWriteTimeout (pipe_t *pp, const uint8_t *bp, size_t n, sysinterval_t timeout)
 Pipe write with timeout. More...
size_t chPipeReadTimeout (pipe_t *pp, uint8_t *bp, size_t n, sysinterval_t timeout)
 Pipe read with timeout. More...
static size_t chPipeGetSizeI (const pipe_t *pp)
 Returns the pipe buffer size as number of bytes. More...
static size_t chPipeGetUsedCountI (const pipe_t *pp)
 Returns the number of used byte slots into a pipe. More...
static size_t chPipeGetFreeCountI (const pipe_t *pp)
 Returns the number of free byte slots into a pipe. More...
static uint8_t chPipePeekI (const pipe_t *pp)
 Returns the next byte in the queue without removing it. More...
static void chPipeResumeX (pipe_t *pp)
 Terminates the reset state. More...
#define _PIPE_DATA (   name,
  buffer,
  size
Value:
(uint8_t *)(buffer), \
(uint8_t *)(buffer) + size, \
(size_t)0, \
false, \
_MUTEX_DATA(name.mtx), \
#define _THREADS_QUEUE_DATA(name)
Data part of a static threads queue object initializer.
Definition: chthreads.h:98
#define _MUTEX_DATA(name)
Data part of a static mutex initializer.
Definition: chmtx.h:81
This macro should be used when statically initializing a pipe that is part of a bigger structure.
Parameters
[in]namethe name of the pipe variable
[in]bufferpointer to the pipe buffer array of uint8_t
[in]sizenumber of uint8_t elements in the buffer array
Definition at line 84 of file chpipes.h.
#define PIPE_DECL (   name,
  buffer,
  size
Statically initialized pipes require no explicit initialization using chPipeObjectInit().
Parameters
Definition at line 118 of file chpipes.h.
Function Documentation
void chPipeObjectInit ( pipe_t pp,
uint8_t *  buf,
size_t  n
Parameters
[out]ppthe pointer to the pipe_t structure to be initialized
[in]bufpointer to the pipe buffer as an array of uint8_t
[in]nnumber of elements in the buffer array
Definition at line 89 of file chpipes.c.
References pipe_t::buffer, chDbgCheck, chThdQueueObjectInit, pipe_t::cnt, pipe_t::qr, pipe_t::qw, pipe_t::rdptr, pipe_t::reset, pipe_t::top, and pipe_t::wrptr.
void chPipeReset ( pipe_t pp)
All the waiting threads are resumed with status MSG_RESET and the queued data is lost.
Postcondition
The pipe is in reset state, all operations will fail and return MSG_RESET until the mailbox is enabled again using chPipeResumeX().
Parameters
[in]ppthe pointer to an initialized pipe_t object
Definition at line 115 of file chpipes.c.
References pipe_t::buffer, chDbgCheck, chSchRescheduleS(), chSysLock, chSysUnlock, chThdDequeueAllI(), pipe_t::cnt, MSG_RESET, pipe_t::qr, pipe_t::qw, pipe_t::rdptr, pipe_t::reset, and pipe_t::wrptr.
size_t chPipeWriteTimeout ( pipe_t pp,
const uint8_t *  bp,
size_t  n,
The function writes data from a buffer to a pipe. The operation completes when the specified amount of data has been transferred or after the specified timeout or if the pipe has been reset.
Parameters
[in]bppointer to the data buffer
[in]nthe maximum amount of data to be transferred, the value 0 is reserved
[in]timeoutthe number of ticks before the operation timeouts, the following special values are allowed:
  • TIME_IMMEDIATE immediate timeout.
  • TIME_INFINITE no timeout.
Returns
The number of bytes effectively transferred.
Return values
MSG_RESETif the mailbox has been reset.
MSG_TIMEOUTif the operation has timed out.
Definition at line 154 of file chpipes.c.
size_t chPipeReadTimeout ( pipe_t pp,
uint8_t *  bp,
size_t  n,
The function reads data from a pipe into a buffer. The operation completes when the specified amount of data has been transferred or after the specified timeout or if the pipe has been reset.
Parameters
[out]bppointer to the data buffer
Returns
Return values
Definition at line 181 of file chpipes.c.
static size_t chPipeGetSizeI ( const pipe_t pp)
inlinestatic
Parameters
Returns
The size of the pipe.
Function Class:This is an I-Class API, this function can be invoked from within a system lock zone by both threads and interrupt handlers.
Definition at line 150 of file chpipes.h.
References pipe_t::buffer, and pipe_t::top.
Referenced by chPipeGetFreeCountI().
static size_t chPipeGetUsedCountI ( const pipe_t pp)
inlinestatic
Parameters
Returns
The number of queued bytes.
Definition at line 166 of file chpipes.h.
References pipe_t::cnt.
static size_t chPipeGetFreeCountI ( const pipe_t pp)
inlinestatic
Parameters
Returns
The number of empty byte slots.
Definition at line 181 of file chpipes.h.
References chPipeGetSizeI(), and chPipeGetUsedCountI().
static uint8_t chPipePeekI ( const pipe_t pp)
inlinestatic
Precondition
A byte must be present in the queue for this function to work or it would return garbage. The correct way to use this macro is to use chPipeGetFullCountI() and then use this macro, all within a lock state.
Parameters
Returns
The next byte in queue.
Definition at line 200 of file chpipes.h.
References pipe_t::rdptr.
static void chPipeResumeX ( pipe_t pp)
inlinestatic
Parameters
Function Class:This is an X-Class API, this function can be invoked from any context.
Definition at line 214 of file chpipes.h.
References pipe_t::reset.
