hal_buffers.c
18  * @file hal_buffers.c
19  * @brief I/O Buffers code.
21  * @addtogroup HAL_BUFFERS
22  * @details Buffers Queues are used when there is the need to exchange
23  * fixed-length data buffers between ISRs and threads.
24  * On the ISR side data can be exchanged only using buffers,
25  * on the thread side data can be exchanged both using buffers and/or
26  * using an emulation of regular byte queues.
27  * There are several kind of buffers queues:<br>
28  * - <b>Input queue</b>, unidirectional queue where the writer is the
29  * ISR side and the reader is the thread side.
30  * - <b>Output queue</b>, unidirectional queue where the writer is the
31  * ISR side and the reader is the thread side.
32  * - <b>Full duplex queue</b>, bidirectional queue. Full duplex queues
33  * are implemented by pairing an input queue and an output queue
34  * together.
35  * .
36  * @{
37  */
38
39 #include <string.h>
41 #include "hal.h"
42
44 /* Driver local definitions. */
46
48 /* Driver exported variables. */
50
52 /* Driver local variables and types. */
54
56 /* Driver local functions. */
58
60 /* Driver exported functions. */
61 /*===========================================================================*/
62
63 /**
64  * @brief Initializes an input buffers queue object.
65  *
66  * @param[out] ibqp pointer to the @p input_buffers_queue_t object
67  * @param[in] suspended initial state of the queue
68  * @param[in] bp pointer to a memory area allocated for buffers
69  * @param[in] size buffers size
70  * @param[in] n number of buffers
71  * @param[in] infy callback called when a buffer is returned to the queue
72  * @param[in] link application defined pointer
73  *
74  * @init
75  */
76 void ibqObjectInit(input_buffers_queue_t *ibqp, bool suspended, uint8_t *bp,
77  size_t size, size_t n, bqnotify_t infy, void *link) {
78
79  osalDbgCheck((ibqp != NULL) && (bp != NULL) && (size >= 2U));
80
82  ibqp->suspended = suspended;
83  ibqp->bcounter = 0;
84  ibqp->brdptr = bp;
85  ibqp->bwrptr = bp;
86  ibqp->btop = bp + ((size + sizeof (size_t)) * n);
87  ibqp->bsize = size + sizeof (size_t);
88  ibqp->bn = n;
89  ibqp->buffers = bp;
90  ibqp->ptr = NULL;
91  ibqp->top = NULL;
92  ibqp->notify = infy;
93  ibqp->link = link;
94 }
95
96 /**
97  * @brief Resets an input buffers queue.
98  * @details All the data in the input buffers queue is erased and lost, any
99  * waiting thread is resumed with status @p MSG_RESET.
100  * @note A reset operation can be used by a low level driver in order to
101  * obtain immediate attention from the high level layers.
102  *
103  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
104  *
105  * @iclass
106  */
108
110
111  ibqp->bcounter = 0;
112  ibqp->brdptr = ibqp->buffers;
113  ibqp->bwrptr = ibqp->buffers;
114  ibqp->ptr = NULL;
115  ibqp->top = NULL;
117 }
118
119 /**
120  * @brief Gets the next empty buffer from the queue.
121  * @note The function always returns the same buffer if called repeatedly.
122  *
123  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
124  * @return A pointer to the next buffer to be filled.
125  * @retval NULL if the queue is full.
126  *
127  * @iclass
128  */
130
132
133  if (ibqIsFullI(ibqp)) {
134  return NULL;
135  }
136
137  return ibqp->bwrptr + sizeof (size_t);
138 }
139
140 /**
141  * @brief Posts a new filled buffer to the queue.
142  *
143  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
144  * @param[in] size used size of the buffer, cannot be zero
145  *
146  * @iclass
147  */
148 void ibqPostFullBufferI(input_buffers_queue_t *ibqp, size_t size) {
149
151
152  osalDbgCheck((size > 0U) && (size <= (ibqp->bsize - sizeof (size_t))));
153  osalDbgAssert(!ibqIsFullI(ibqp), "buffers queue full");
154
155  /* Writing size field in the buffer.*/
156  *((size_t *)ibqp->bwrptr) = size;
157
158  /* Posting the buffer in the queue.*/
159  ibqp->bcounter++;
160  ibqp->bwrptr += ibqp->bsize;
161  if (ibqp->bwrptr >= ibqp->btop) {
162  ibqp->bwrptr = ibqp->buffers;
163  }
164
165  /* Waking up one waiting thread, if any.*/
167 }
168
169 /**
170  * @brief Gets the next filled buffer from the queue.
171  * @note The function always acquires the same buffer if called repeatedly.
172  * @post After calling the function the fields @p ptr and @p top are set
173  * at beginning and end of the buffer data or @p NULL if the queue
174  * is empty.
175  *
176  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
177  * @param[in] timeout the number of ticks before the operation timeouts,
178  * the following special values are allowed:
179  * - @a TIME_IMMEDIATE immediate timeout.
180  * - @a TIME_INFINITE no timeout.
181  * .
182  * @return The operation status.
183  * @retval MSG_OK if a buffer has been acquired.
184  * @retval MSG_TIMEOUT if the specified time expired.
185  * @retval MSG_RESET if the queue has been reset or has been put in
186  * suspended state.
187  *
188  * @api
189  */
191  sysinterval_t timeout) {
192  msg_t msg;
193
194  osalSysLock();
195  msg = ibqGetFullBufferTimeoutS(ibqp, timeout);
196  osalSysUnlock();
197
198  return msg;
199 }
200
201  /**
202  * @brief Gets the next filled buffer from the queue.
203  * @note The function always acquires the same buffer if called repeatedly.
204  * @post After calling the function the fields @p ptr and @p top are set
205  * at beginning and end of the buffer data or @p NULL if the queue
206  * is empty.
207  *
208  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
209  * @param[in] timeout the number of ticks before the operation timeouts,
210  * the following special values are allowed:
211  * - @a TIME_IMMEDIATE immediate timeout.
212  * - @a TIME_INFINITE no timeout.
213  * .
214  * @return The operation status.
215  * @retval MSG_OK if a buffer has been acquired.
216  * @retval MSG_TIMEOUT if the specified time expired.
217  * @retval MSG_RESET if the queue has been reset or has been put in
218  * suspended state.
219  *
220  * @sclass
221  */
223  sysinterval_t timeout) {
224
226
227  while (ibqIsEmptyI(ibqp)) {
228  if (ibqp->suspended) {
229  return MSG_RESET;
230  }
231  msg_t msg = osalThreadEnqueueTimeoutS(&ibqp->waiting, timeout);
232  if (msg < MSG_OK) {
233  return msg;
234  }
235  }
236
237  osalDbgAssert(!ibqIsEmptyI(ibqp), "still empty");
238
239  /* Setting up the "current" buffer and its boundary.*/
240  ibqp->ptr = ibqp->brdptr + sizeof (size_t);
241  ibqp->top = ibqp->ptr + *((size_t *)ibqp->brdptr);
242
243  return MSG_OK;
244 }
245
246 /**
247  * @brief Releases the buffer back in the queue.
248  * @note The object callback is called after releasing the buffer.
249  *
250  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
251  *
252  * @api
253  */
255
256  osalSysLock();
258  osalSysUnlock();
259 }
260
261  /**
262  * @brief Releases the buffer back in the queue.
263  * @note The object callback is called after releasing the buffer.
264  *
265  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
266  *
267  * @sclass
268  */
270
272  osalDbgAssert(!ibqIsEmptyI(ibqp), "buffers queue empty");
273
274  /* Freeing a buffer slot in the queue.*/
275  ibqp->bcounter--;
276  ibqp->brdptr += ibqp->bsize;
277  if (ibqp->brdptr >= ibqp->btop) {
278  ibqp->brdptr = ibqp->buffers;
279  }
280
281  /* No "current" buffer.*/
282  ibqp->ptr = NULL;
283
284  /* Notifying the buffer release.*/
285  if (ibqp->notify != NULL) {
286  ibqp->notify(ibqp);
287  }
288 }
289
290 /**
291  * @brief Input queue read with timeout.
292  * @details This function reads a byte value from an input queue. If
293  * the queue is empty then the calling thread is suspended until a
294  * new buffer arrives in the queue or a timeout occurs.
295  *
296  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
297  * @param[in] timeout the number of ticks before the operation timeouts,
298  * the following special values are allowed:
299  * - @a TIME_IMMEDIATE immediate timeout.
300  * - @a TIME_INFINITE no timeout.
301  * .
302  * @return A byte value from the queue.
303  * @retval MSG_TIMEOUT if the specified time expired.
304  * @retval MSG_RESET if the queue has been reset or has been put in
305  * suspended state.
306  *
307  * @api
308  */
310  msg_t msg;
311
312  osalSysLock();
313
314  /* This condition indicates that a new buffer must be acquired.*/
315  if (ibqp->ptr == NULL) {
316  msg = ibqGetFullBufferTimeoutS(ibqp, timeout);
317  if (msg != MSG_OK) {
318  osalSysUnlock();
319  return msg;
320  }
321  }
322
323  /* Next byte from the buffer.*/
324  msg = (msg_t)*ibqp->ptr;
325  ibqp->ptr++;
326
327  /* If the current buffer has been fully read then it is returned as
328  empty in the queue.*/
329  if (ibqp->ptr >= ibqp->top) {
331  }
332
333  osalSysUnlock();
334  return msg;
335 }
336
337 /**
338  * @brief Input queue read with timeout.
339  * @details The function reads data from an input queue into a buffer.
340  * The operation completes when the specified amount of data has been
341  * transferred or after the specified timeout or if the queue has
342  * been reset.
343  *
344  * @param[in] ibqp pointer to the @p input_buffers_queue_t object
345  * @param[out] bp pointer to the data buffer
346  * @param[in] n the maximum amount of data to be transferred, the
347  * value 0 is reserved
348  * @param[in] timeout the number of ticks before the operation timeouts,
349  * the following special values are allowed:
350  * - @a TIME_IMMEDIATE immediate timeout.
351  * - @a TIME_INFINITE no timeout.
352  * .
353  * @return The number of bytes effectively transferred.
354  * @retval 0 if a timeout occurred.
355  *
356  * @api
357  */
358 size_t ibqReadTimeout(input_buffers_queue_t *ibqp, uint8_t *bp,
359  size_t n, sysinterval_t timeout) {
360  size_t r = 0;
361  systime_t deadline;
362
363  osalDbgCheck(n > 0U);
364
365  osalSysLock();
366
367  /* Time window for the whole operation.*/
368  deadline = osalTimeAddX(osalOsGetSystemTimeX(), timeout);
369
370  while (true) {
371  size_t size;
372
373  /* This condition indicates that a new buffer must be acquired.*/
374  if (ibqp->ptr == NULL) {
375  msg_t msg;
376
377  /* TIME_INFINITE and TIME_IMMEDIATE are handled differently, no
378  deadline.*/
379  if ((timeout == TIME_INFINITE) || (timeout == TIME_IMMEDIATE)) {
380  msg = ibqGetFullBufferTimeoutS(ibqp, timeout);
381  }
382  else {
384  deadline);
385
386  /* Handling the case where the system time went past the deadline,
387  in this case next becomes a very high number because the system
388  time is an unsigned type.*/
389  if (next_timeout > timeout) {
390  osalSysUnlock();
391  return r;
392  }
393  msg = ibqGetFullBufferTimeoutS(ibqp, next_timeout);
394  }
395
396  /* Anything except MSG_OK interrupts the operation.*/
397  if (msg != MSG_OK) {
398  osalSysUnlock();
399  return r;
400  }
401  }
402
403  /* Size of the data chunk present in the current buffer.*/
404  size = (size_t)ibqp->top - (size_t)ibqp->ptr;
405  if (size > (n - r)) {
406  size = n - r;
407  }
408
409  /* Smaller chunks in order to not make the critical zone too long,
410  this impacts throughput however.*/
411  if (size > 64U) {
412  /* Giving the compiler a chance to optimize for a fixed size move.*/
413  memcpy(bp, ibqp->ptr, 64U);
414  bp += 64U;
415  ibqp->ptr += 64U;
416  r += 64U;
417  }
418  else {
419  memcpy(bp, ibqp->ptr, size);
420  bp += size;
421  ibqp->ptr += size;
422  r += size;
423  }
424
425  /* Has the current data buffer been finished? if so then release it.*/
426  if (ibqp->ptr >= ibqp->top) {
428  }
429
430  /* Giving a preemption chance.*/
431  osalSysUnlock();
432  if (r >= n) {
433  return r;
434  }
435  osalSysLock();
436  }
437 }
438
439 /**
440  * @brief Initializes an output buffers queue object.
441  *
442  * @param[out] obqp pointer to the @p output_buffers_queue_t object
443  * @param[in] suspended initial state of the queue
444  * @param[in] bp pointer to a memory area allocated for buffers
445  * @param[in] size buffers size
446  * @param[in] n number of buffers
447  * @param[in] onfy callback called when a buffer is posted in the queue
448  * @param[in] link application defined pointer
449  *
450  * @init
451  */
452 void obqObjectInit(output_buffers_queue_t *obqp, bool suspended, uint8_t *bp,
453  size_t size, size_t n, bqnotify_t onfy, void *link) {
454
455  osalDbgCheck((obqp != NULL) && (bp != NULL) && (size >= 2U));
456
458  obqp->suspended = suspended;
459  obqp->bcounter = n;
460  obqp->brdptr = bp;
461  obqp->bwrptr = bp;
462  obqp->btop = bp + ((size + sizeof (size_t)) * n);
463  obqp->bsize = size + sizeof (size_t);
464  obqp->bn = n;
465  obqp->buffers = bp;
466  obqp->ptr = NULL;
467  obqp->top = NULL;
468  obqp->notify = onfy;
469  obqp->link = link;
470 }
471
472 /**
473  * @brief Resets an output buffers queue.
474  * @details All the data in the output buffers queue is erased and lost, any
475  * waiting thread is resumed with status @p MSG_RESET.
476  * @note A reset operation can be used by a low level driver in order to
477  * obtain immediate attention from the high level layers.
478  *
479  * @param[in] obqp pointer to the @p output_buffers_queue_t object
480  *
481  * @iclass
482  */
484
486
487  obqp->bcounter = bqSizeX(obqp);
488  obqp->brdptr = obqp->buffers;
489  obqp->bwrptr = obqp->buffers;
490  obqp->ptr = NULL;
491  obqp->top = NULL;
493 }
494
495 /**
496  * @brief Gets the next filled buffer from the queue.
497  * @note The function always returns the same buffer if called repeatedly.
498  *
499  * @param[in] obqp pointer to the @p output_buffers_queue_t object
500  * @param[out] sizep pointer to the filled buffer size
501  * @return A pointer to the filled buffer.
502  * @retval NULL if the queue is empty.
503  *
504  * @iclass
505  */
507  size_t *sizep) {
508
510
511  if (obqIsEmptyI(obqp)) {
512  return NULL;
513  }
514
515  /* Buffer size.*/
516  *sizep = *((size_t *)obqp->brdptr);
517
518  return obqp->brdptr + sizeof (size_t);
519 }
520
521 /**
522  * @brief Releases the next filled buffer back in the queue.
523  *
524  * @param[in] obqp pointer to the @p output_buffers_queue_t object
525  *
526  * @iclass
527  */
529
531  osalDbgAssert(!obqIsEmptyI(obqp), "buffers queue empty");
532
533  /* Freeing a buffer slot in the queue.*/
534  obqp->bcounter++;
535  obqp->brdptr += obqp->bsize;
536  if (obqp->brdptr >= obqp->btop) {
537  obqp->brdptr = obqp->buffers;
538  }
539
540  /* Waking up one waiting thread, if any.*/
542 }
543
544 /**
545  * @brief Gets the next empty buffer from the queue.
546  * @note The function always acquires the same buffer if called repeatedly.
547  * @post After calling the function the fields @p ptr and @p top are set
548  * at beginning and end of the buffer data or @p NULL if the queue
549  * is empty.
550  *
551  * @param[in] obqp pointer to the @p output_buffers_queue_t object
552  * @param[in] timeout the number of ticks before the operation timeouts,
553  * the following special values are allowed:
554  * - @a TIME_IMMEDIATE immediate timeout.
555  * - @a TIME_INFINITE no timeout.
556  * .
557  * @return The operation status.
558  * @retval MSG_OK if a buffer has been acquired.
559  * @retval MSG_TIMEOUT if the specified time expired.
560  * @retval MSG_RESET if the queue has been reset or has been put in
561  * suspended state.
562  *
563  * @api
564  */
566  sysinterval_t timeout) {
567  msg_t msg;
568
569  osalSysLock();
570  msg = obqGetEmptyBufferTimeoutS(obqp, timeout);
571  osalSysUnlock();
572
573  return msg;
574 }
575
576 /**
577  * @brief Gets the next empty buffer from the queue.
578  * @note The function always acquires the same buffer if called repeatedly.
579  * @post After calling the function the fields @p ptr and @p top are set
580  * at beginning and end of the buffer data or @p NULL if the queue
581  * is empty.
582  *
583  * @param[in] obqp pointer to the @p output_buffers_queue_t object
584  * @param[in] timeout the number of ticks before the operation timeouts,
585  * the following special values are allowed:
586  * - @a TIME_IMMEDIATE immediate timeout.
587  * - @a TIME_INFINITE no timeout.
588  * .
589  * @return The operation status.
590  * @retval MSG_OK if a buffer has been acquired.
591  * @retval MSG_TIMEOUT if the specified time expired.
592  * @retval MSG_RESET if the queue has been reset or has been put in
593  * suspended state.
594  *
595  * @sclass
596  */
598  sysinterval_t timeout) {
599
601
602  while (obqIsFullI(obqp)) {
603  if (obqp->suspended) {
604  return MSG_RESET;
605  }
606  msg_t msg = osalThreadEnqueueTimeoutS(&obqp->waiting, timeout);
607  if (msg < MSG_OK) {
608  return msg;
609  }
610  }
611
612  osalDbgAssert(!obqIsFullI(obqp), "still full");
613
614  /* Setting up the "current" buffer and its boundary.*/
615  obqp->ptr = obqp->bwrptr + sizeof (size_t);
616  obqp->top = obqp->bwrptr + obqp->bsize;
617
618  return MSG_OK;
619 }
620
621 /**
622  * @brief Posts a new filled buffer to the queue.
623  * @note The object callback is called after releasing the buffer.
624  *
625  * @param[in] obqp pointer to the @p output_buffers_queue_t object
626  * @param[in] size used size of the buffer, cannot be zero
627  *
628  * @api
629  */
630 void obqPostFullBuffer(output_buffers_queue_t *obqp, size_t size) {
631
632  osalSysLock();
633  obqPostFullBufferS(obqp, size);
634  osalSysUnlock();
635 }
636
637 /**
638  * @brief Posts a new filled buffer to the queue.
639  * @note The object callback is called after releasing the buffer.
640  *
641  * @param[in] obqp pointer to the @p output_buffers_queue_t object
642  * @param[in] size used size of the buffer, cannot be zero
643  *
644  * @sclass
645  */
646 void obqPostFullBufferS(output_buffers_queue_t *obqp, size_t size) {
647
649  osalDbgCheck((size > 0U) && (size <= (obqp->bsize - sizeof (size_t))));
650  osalDbgAssert(!obqIsFullI(obqp), "buffers queue full");
651
652  /* Writing size field in the buffer.*/
653  *((size_t *)obqp->bwrptr) = size;
654
655  /* Posting the buffer in the queue.*/
656  obqp->bcounter--;
657  obqp->bwrptr += obqp->bsize;
658  if (obqp->bwrptr >= obqp->btop) {
659  obqp->bwrptr = obqp->buffers;
660  }
661
662  /* No "current" buffer.*/
663  obqp->ptr = NULL;
664
665  /* Notifying the buffer release.*/
666  if (obqp->notify != NULL) {
667  obqp->notify(obqp);
668  }
669 }
670
671 /**
672  * @brief Output queue write with timeout.
673  * @details This function writes a byte value to an output queue. If
674  * the queue is full then the calling thread is suspended until a
675  * new buffer is freed in the queue or a timeout occurs.
676  *
677  * @param[in] obqp pointer to the @p output_buffers_queue_t object
678  * @param[in] b byte value to be transferred
679  * @param[in] timeout the number of ticks before the operation timeouts,
680  * the following special values are allowed:
681  * - @a TIME_IMMEDIATE immediate timeout.
682  * - @a TIME_INFINITE no timeout.
683  * .
684  * @return A byte value from the queue.
685  * @retval MSG_TIMEOUT if the specified time expired.
686  * @retval MSG_RESET if the queue has been reset or has been put in
687  * suspended state.
688  *
689  * @api
690  */
692  sysinterval_t timeout) {
693  msg_t msg;
694
695  osalSysLock();
696
697  /* This condition indicates that a new buffer must be acquired.*/
698  if (obqp->ptr == NULL) {
699  msg = obqGetEmptyBufferTimeoutS(obqp, timeout);
700  if (msg != MSG_OK) {
701  osalSysUnlock();
702  return msg;
703  }
704  }
705
706  /* Writing the byte to the buffer.*/
707  *obqp->ptr = b;
708  obqp->ptr++;
709
710  /* If the current buffer has been fully written then it is posted as
711  full in the queue.*/
712  if (obqp->ptr >= obqp->top) {
713  obqPostFullBufferS(obqp, obqp->bsize - sizeof (size_t));
714  }
715
716  osalSysUnlock();
717  return MSG_OK;
718 }
719
720 /**
721  * @brief Output queue write with timeout.
722  * @details The function writes data from a buffer to an output queue. The
723  * operation completes when the specified amount of data has been
724  * transferred or after the specified timeout or if the queue has
725  * been reset.
726  *
727  * @param[in] obqp pointer to the @p output_buffers_queue_t object
728  * @param[in] bp pointer to the data buffer
729  * @param[in] n the maximum amount of data to be transferred, the
730  * value 0 is reserved
731  * @param[in] timeout the number of ticks before the operation timeouts,
732  * the following special values are allowed:
733  * - @a TIME_IMMEDIATE immediate timeout.
734  * - @a TIME_INFINITE no timeout.
735  * .
736  * @return The number of bytes effectively transferred.
737  * @retval 0 if a timeout occurred.
738  *
739  * @api
740  */
741 size_t obqWriteTimeout(output_buffers_queue_t *obqp, const uint8_t *bp,
742  size_t n, sysinterval_t timeout) {
743  size_t w = 0;
744  systime_t deadline;
745
746  osalDbgCheck(n > 0U);
747
748  osalSysLock();
749
750  /* Time window for the whole operation.*/
751  deadline = osalTimeAddX(osalOsGetSystemTimeX(), timeout);
752
753  while (true) {
754  size_t size;
755
756  /* This condition indicates that a new buffer must be acquired.*/
757  if (obqp->ptr == NULL) {
758  msg_t msg;
759
760  /* TIME_INFINITE and TIME_IMMEDIATE are handled differently, no
761  deadline.*/
762  if ((timeout == TIME_INFINITE) || (timeout == TIME_IMMEDIATE)) {
763  msg = obqGetEmptyBufferTimeoutS(obqp, timeout);
764  }
765  else {
767  deadline);
768
769  /* Handling the case where the system time went past the deadline,
770  in this case next becomes a very high number because the system
771  time is an unsigned type.*/
772  if (next_timeout > timeout) {
773  osalSysUnlock();
774  return w;
775  }
776  msg = obqGetEmptyBufferTimeoutS(obqp, next_timeout);
777  }
778
779  /* Anything except MSG_OK interrupts the operation.*/
780  if (msg != MSG_OK) {
781  osalSysUnlock();
782  return w;
783  }
784  }
785
786  /* Size of the space available in the current buffer.*/
787  size = (size_t)obqp->top - (size_t)obqp->ptr;
788  if (size > (n - w)) {
789  size = n - w;
790  }
791
792  /* Smaller chunks in order to not make the critical zone too long,
793  this impacts throughput however.*/
794  if (size > 64U) {
795  /* Giving the compiler a chance to optimize for a fixed size move.*/
796  memcpy(obqp->ptr, bp, 64U);
797  bp += 64U;
798  obqp->ptr += 64U;
799  w += 64U;
800  }
801  else {
802  memcpy(obqp->ptr, bp, size);
803  bp += size;
804  obqp->ptr += size;
805  w += size;
806  }
807
808  /* Has the current data buffer been finished? if so then release it.*/
809  if (obqp->ptr >= obqp->top) {
810  obqPostFullBufferS(obqp, obqp->bsize - sizeof (size_t));
811  }
812
813  /* Giving a preemption chance.*/
814  osalSysUnlock();
815  if (w >= n) {
816  return w;
817  }
818  osalSysLock();
819  }
820 }
821
822 /**
823  * @brief Flushes the current, partially filled, buffer to the queue.
824  * @note The notification callback is not invoked because the function
825  * is meant to be called from ISR context. An operation status is
826  * returned instead.
827  *
828  * @param[in] obqp pointer to the @p output_buffers_queue_t object
829  * @return The operation status.
830  * @retval false if no new filled buffer has been posted to the queue.
831  * @retval true if a new filled buffer has been posted to the queue.
832  *
833  * @iclass
834  */
836
838
839  /* If queue is empty and there is a buffer partially filled and
840  it is not being written.*/
841  if (obqIsEmptyI(obqp) && (obqp->ptr != NULL)) {
842  size_t size = (size_t)obqp->ptr - ((size_t)obqp->bwrptr + sizeof (size_t));
843
844  if (size > 0U) {
845
846  /* Writing size field in the buffer.*/
847  *((size_t *)obqp->bwrptr) = size;
848
849  /* Posting the buffer in the queue.*/
850  obqp->bcounter--;
851  obqp->bwrptr += obqp->bsize;
852  if (obqp->bwrptr >= obqp->btop) {
853  obqp->bwrptr = obqp->buffers;
854  }
855
856  /* No "current" buffer.*/
857  obqp->ptr = NULL;
858
859  return true;
860  }
861  }
862  return false;
863 }
864
865 /**
866  * @brief Flushes the current, partially filled, buffer to the queue.
867  *
868  * @param[in] obqp pointer to the @p output_buffers_queue_t object
869  *
870  * @api
871  */
873
874  osalSysLock();
875
876  /* If there is a buffer partially filled and not being written.*/
877  if (obqp->ptr != NULL) {
878  size_t size = ((size_t)obqp->ptr - (size_t)obqp->bwrptr) - sizeof (size_t);
879
880  if (size > 0U) {
881  obqPostFullBufferS(obqp, size);
882  }
883  }
884
885  osalSysUnlock();
886 }
887 /** @} */
#define ibqIsFullI(ibqp)
Evaluates to true if the specified input buffers queue is full.
Definition: hal_buffers.h:241
void obqFlush(output_buffers_queue_t *obqp)
Definition: hal_buffers.c:872
uint8_t * ibqGetEmptyBufferI(input_buffers_queue_t *ibqp)
Definition: hal_buffers.c:129
uint8_t * obqGetFullBufferI(output_buffers_queue_t *obqp, size_t *sizep)
Definition: hal_buffers.c:506
msg_t obqGetEmptyBufferTimeoutS(output_buffers_queue_t *obqp, sysinterval_t timeout)
Definition: hal_buffers.c:597
void obqReleaseEmptyBufferI(output_buffers_queue_t *obqp)
Definition: hal_buffers.c:528
void osalThreadDequeueAllI(threads_queue_t *tqp, msg_t msg)
Dequeues and wakes up all threads from the queue.
Definition: osal.c:309
uint64_t systime_t
Type of system time.
Definition: chtime.h:107
uint64_t sysinterval_t
Type of time interval.
Definition: chtime.h:119
static sysinterval_t osalTimeDiffX(systime_t start, systime_t end)
Subtracts two system times returning an interval.
Definition: osal.h:620
volatile size_t bcounter
Active buffers counter.
Definition: hal_buffers.h:71
#define ibqIsEmptyI(ibqp)
Evaluates to true if the specified input buffers queue is empty.
Definition: hal_buffers.h:229
msg_t ibqGetFullBufferTimeout(input_buffers_queue_t *ibqp, sysinterval_t timeout)
Definition: hal_buffers.c:190
#define obqIsEmptyI(obqp)
Evaluates to true if the specified output buffers queue is empty.
Definition: hal_buffers.h:256
#define osalDbgCheckClassI()
I-Class state check.
Definition: osal.h:292
#define obqIsFullI(obqp)
Evaluates to true if the specified output buffers queue is full.
Definition: hal_buffers.h:271
uint8_t * btop
Pointer to the buffers boundary.
Definition: hal_buffers.h:83
void ibqResetI(input_buffers_queue_t *ibqp)
Definition: hal_buffers.c:107
Definition: osal.h:540
void * link
Application defined field.
Definition: hal_buffers.h:115
bqnotify_t notify
Data notification callback.
Definition: hal_buffers.h:111
Definition: hal_buffers.c:646
uint8_t * ptr
Pointer for R/W sequential access.
Definition: hal_buffers.h:103
size_t ibqReadTimeout(input_buffers_queue_t *ibqp, uint8_t *bp, size_t n, sysinterval_t timeout)
Definition: hal_buffers.c:358
uint8_t * bwrptr
Buffer write pointer.
Definition: hal_buffers.h:75
Definition: hal_buffers.c:630
size_t bn
Number of buffers.
Definition: hal_buffers.h:94
Definition: hal_buffers.c:148
msg_t ibqGetFullBufferTimeoutS(input_buffers_queue_t *ibqp, sysinterval_t timeout)
Definition: hal_buffers.c:222
size_t obqWriteTimeout(output_buffers_queue_t *obqp, const uint8_t *bp, size_t n, sysinterval_t timeout)
Definition: hal_buffers.c:741
bool obqTryFlushI(output_buffers_queue_t *obqp)
Definition: hal_buffers.c:835
void(* bqnotify_t)(io_buffers_queue_t *bqp)
Double buffer notification callback type.
Definition: hal_buffers.h:54
msg_t obqGetEmptyBufferTimeout(output_buffers_queue_t *obqp, sysinterval_t timeout)
Definition: hal_buffers.c:565
void obqObjectInit(output_buffers_queue_t *obqp, bool suspended, uint8_t *bp, size_t size, size_t n, bqnotify_t onfy, void *link)
Definition: hal_buffers.c:452
static systime_t osalTimeAddX(systime_t systime, sysinterval_t interval)
Adds an interval to a system time returning a system time.
Definition: osal.h:605
#define TIME_INFINITE
Infinite interval specification for all functions with a timeout specification.
Definition: chtime.h:55
uint8_t * buffers
Queue of buffer objects.
Definition: hal_buffers.h:98
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
systime_t osalOsGetSystemTimeX(void)
Current system time.
Definition: osal.c:136
void osalThreadDequeueNextI(threads_queue_t *tqp, msg_t msg)
Dequeues and wakes up one thread from the queue, if any.
Definition: osal.c:294
msg_t obqPutTimeout(output_buffers_queue_t *obqp, uint8_t b, sysinterval_t timeout)
Definition: hal_buffers.c:691
msg_t osalThreadEnqueueTimeoutS(threads_queue_t *tqp, sysinterval_t timeout)
Enqueues the caller thread.
Definition: osal.c:277
size_t bsize
Size of buffers.
Definition: hal_buffers.h:90
Structure of a generic buffers queue.
Definition: hal_buffers.h:59
threads_queue_t waiting
Queue of waiting threads.
Definition: hal_buffers.h:63
#define bqSizeX(bqp)
Returns the queue&#39;s number of buffers.
Definition: hal_buffers.h:153
bool suspended
Queue suspended state flag.
Definition: hal_buffers.h:67
static void osalSysLock(void)
Definition: osal.h:530
msg_t ibqGetTimeout(input_buffers_queue_t *ibqp, sysinterval_t timeout)
Definition: hal_buffers.c:309
void obqResetI(output_buffers_queue_t *obqp)
Definition: hal_buffers.c:483
#define TIME_IMMEDIATE
Zero interval specification for some functions with a timeout specification.
Definition: chtime.h:47
#define osalDbgCheckClassS()
S-Class state check.
Definition: osal.h:298
uint8_t * top
Boundary for R/W sequential access.
Definition: hal_buffers.h:107
void ibqReleaseEmptyBufferS(input_buffers_queue_t *ibqp)
Definition: hal_buffers.c:269
void ibqObjectInit(input_buffers_queue_t *ibqp, bool suspended, uint8_t *bp, size_t size, size_t n, bqnotify_t infy, void *link)
Definition: hal_buffers.c:76
static void osalThreadQueueObjectInit(threads_queue_t *tqp)
Initializes a threads queue object.
Definition: osal.h:653
uint8_t * brdptr
Buffer read pointer.
Definition: hal_buffers.h:79
int32_t msg_t
Definition: chtypes.h:51
#define MSG_RESET
Definition: chschd.h:43
void ibqReleaseEmptyBuffer(input_buffers_queue_t *ibqp)
Definition: hal_buffers.c:254
