hal_i2c_lld.h File Reference
PLATFORM I2C subsystem low level driver header. More...
struct  I2CConfig
 Type of I2C driver configuration structure. More...
struct  I2CDriver
 Structure representing an I2C driver. More...
#define i2c_lld_get_errors(i2cp)   ((i2cp)->errors)
 Get errors from I2C driver. More...
PLATFORM configuration options
#define PLATFORM_I2C_USE_I2C1   FALSE
 I2C1 driver enable switch. More...
typedef uint16_t i2caddr_t
 Type representing an I2C address. More...
typedef uint32_t i2cflags_t
 Type of I2C Driver condition flags. More...
typedef struct I2CDriver I2CDriver
 Type of a structure representing an I2C driver. More...
void i2c_lld_init (void)
 Low level I2C driver initialization. More...
void i2c_lld_start (I2CDriver *i2cp)
 Configures and activates the I2C peripheral. More...
void i2c_lld_stop (I2CDriver *i2cp)
 Deactivates the I2C peripheral. More...
msg_t i2c_lld_master_transmit_timeout (I2CDriver *i2cp, i2caddr_t addr, const uint8_t *txbuf, size_t txbytes, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Transmits data via the I2C bus as master. More...
msg_t i2c_lld_master_receive_timeout (I2CDriver *i2cp, i2caddr_t addr, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
 Receives data via the I2C bus as master. More...
Definition in file hal_i2c_lld.h.
