hal_i2s.c
18  * @file hal_i2s.c
19  * @brief I2S Driver code.
21  * @addtogroup I2S
27 #if (HAL_USE_I2S == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 /**
50  * @brief I2S Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void i2sInit(void) {
57
58  i2s_lld_init();
59 }
60
61 /**
62  * @brief Initializes the standard part of a @p I2SDriver structure.
63  *
64  * @param[out] i2sp pointer to the @p I2SDriver object
65  *
66  * @init
67  */
68 void i2sObjectInit(I2SDriver *i2sp) {
69
70  i2sp->state = I2S_STOP;
71  i2sp->config = NULL;
72 }
73
74 /**
75  * @brief Configures and activates the I2S peripheral.
76  *
77  * @param[in] i2sp pointer to the @p I2SDriver object
78  * @param[in] config pointer to the @p I2SConfig object
79  *
80  * @api
81  */
82 void i2sStart(I2SDriver *i2sp, const I2SConfig *config) {
83
84  osalDbgCheck((i2sp != NULL) && (config != NULL));
85
86  osalSysLock();
87  osalDbgAssert((i2sp->state == I2S_STOP) || (i2sp->state == I2S_READY),
88  "invalid state");
89  i2sp->config = config;
90  i2s_lld_start(i2sp);
91  i2sp->state = I2S_READY;
92  osalSysUnlock();
93 }
94
95 /**
96  * @brief Deactivates the I2S peripheral.
97  *
98  * @param[in] i2sp pointer to the @p I2SDriver object
99  *
100  * @api
101  */
102 void i2sStop(I2SDriver *i2sp) {
103
104  osalDbgCheck(i2sp != NULL);
105
106  osalSysLock();
107
108  osalDbgAssert((i2sp->state == I2S_STOP) || (i2sp->state == I2S_READY),
109  "invalid state");
110
111  i2s_lld_stop(i2sp);
112  i2sp->config = NULL;
113  i2sp->state = I2S_STOP;
114
115  osalSysUnlock();
116 }
117
118 /**
119  * @brief Starts a I2S data exchange.
120  *
121  * @param[in] i2sp pointer to the @p I2SDriver object
122  *
123  * @api
124  */
126
127  osalDbgCheck(i2sp != NULL);
128
129  osalSysLock();
130  osalDbgAssert(i2sp->state == I2S_READY, "not ready");
131  i2sStartExchangeI(i2sp);
132  osalSysUnlock();
133 }
134
135 /**
136  * @brief Stops the ongoing data exchange.
137  * @details The ongoing data exchange, if any, is stopped, if the driver
138  * was not active the function does nothing.
139  *
140  * @param[in] i2sp pointer to the @p I2SDriver object
141  *
142  * @api
143  */
145
146  osalDbgCheck((i2sp != NULL));
147
148  osalSysLock();
149  osalDbgAssert((i2sp->state == I2S_READY) ||
150  (i2sp->state == I2S_ACTIVE) ||
151  (i2sp->state == I2S_COMPLETE),
152  "invalid state");
153  i2sStopExchangeI(i2sp);
154  osalSysUnlock();
155 }
156
157 #endif /* HAL_USE_I2S == TRUE */
158
159 /** @} */
void i2s_lld_init(void)
Low level I2S driver initialization.
Definition: hal_i2s_lld.c:63
void i2sInit(void)
Definition: hal_i2s.c:56
void i2s_lld_stop(I2SDriver *i2sp)
Definition: hal_i2s_lld.c:97
Definition: hal_i2s_lld.h:78
Definition: hal_i2s.c:102
Definition: osal.h:540
Initializes the standard part of a I2SDriver structure.
Definition: hal_i2s.c:68
void i2sStartExchange(I2SDriver *i2sp)
Definition: hal_i2s.c:125
Structure representing an I2S driver.
Definition: hal_i2s_lld.h:103
#define i2sStopExchangeI(i2sp)
Definition: hal_i2s.h:96
#define i2sStartExchangeI(i2sp)
Definition: hal_i2s.h:82
i2sstate_t state
Definition: hal_i2s_lld.h:107
Definition: hal_i2s.c:82
void i2sStopExchange(I2SDriver *i2sp)
Definition: hal_i2s.c:144
static void osalSysLock(void)
Definition: osal.h:530
const I2SConfig * config
Current configuration data.
Definition: hal_i2s_lld.h:111
void i2s_lld_start(I2SDriver *i2sp)
Definition: hal_i2s_lld.c:77
