hal_icu.c
18  * @file hal_icu.c
19  * @brief ICU Driver code.
21  * @addtogroup ICU
27 #if (HAL_USE_ICU == TRUE) || defined(__DOXYGEN__)
38 /* Driver local variables and types. */
46 /* Driver exported functions. */
49 /**
50  * @brief ICU Driver initialization.
51  * @note This function is implicitly invoked by @p halInit(), there is
52  * no need to explicitly initialize the driver.
53  *
54  * @init
55  */
56 void icuInit(void) {
57
58  icu_lld_init();
59 }
60
61 /**
62  * @brief Initializes the standard part of a @p ICUDriver structure.
63  *
64  * @param[out] icup pointer to the @p ICUDriver object
65  *
66  * @init
67  */
68 void icuObjectInit(ICUDriver *icup) {
69
70  icup->state = ICU_STOP;
71  icup->config = NULL;
72 }
73
74 /**
75  * @brief Configures and activates the ICU peripheral.
76  *
77  * @param[in] icup pointer to the @p ICUDriver object
78  * @param[in] config pointer to the @p ICUConfig object
79  *
80  * @api
81  */
82 void icuStart(ICUDriver *icup, const ICUConfig *config) {
83
84  osalDbgCheck((icup != NULL) && (config != NULL));
85
86  osalSysLock();
87  osalDbgAssert((icup->state == ICU_STOP) || (icup->state == ICU_READY),
88  "invalid state");
89  icup->config = config;
90  icu_lld_start(icup);
91  icup->state = ICU_READY;
92  osalSysUnlock();
93 }
94
95 /**
96  * @brief Deactivates the ICU peripheral.
97  *
98  * @param[in] icup pointer to the @p ICUDriver object
99  *
100  * @api
101  */
102 void icuStop(ICUDriver *icup) {
103
104  osalDbgCheck(icup != NULL);
105
106  osalSysLock();
107
108  osalDbgAssert((icup->state == ICU_STOP) || (icup->state == ICU_READY),
109  "invalid state");
110
111  icu_lld_stop(icup);
112  icup->config = NULL;
113  icup->state = ICU_STOP;
114
115  osalSysUnlock();
116 }
117
118 /**
119  * @brief Starts the input capture.
120  *
121  * @param[in] icup pointer to the @p ICUDriver object
122  *
123  * @api
124  */
126
127  osalDbgCheck(icup != NULL);
128
129  osalSysLock();
130  osalDbgAssert(icup->state == ICU_READY, "invalid state");
131  icuStartCaptureI(icup);
132  osalSysUnlock();
133 }
134
135 /**
136  * @brief Waits for a completed capture.
137  * @note The operation could be performed in polled mode depending on.
138  * @note In order to use this function notifications must be disabled.
139  * @pre The driver must be in @p ICU_WAITING or @p ICU_ACTIVE states.
140  * @post After the capture is available the driver is in @p ICU_ACTIVE
141  * state. If a capture fails then the driver is in @p ICU_WAITING
142  * state.
143  *
144  * @param[in] icup pointer to the @p ICUDriver object
145  * @return The capture status.
146  * @retval false if the capture is successful.
147  * @retval true if a timer overflow occurred.
148  *
149  * @api
150  */
152  bool result;
153
154  osalDbgCheck(icup != NULL);
155
156  osalSysLock();
157  osalDbgAssert((icup->state == ICU_WAITING) || (icup->state == ICU_ACTIVE),
158  "invalid state");
160  "notifications enabled");
161  result = icu_lld_wait_capture(icup);
162  icup->state = result ? ICU_WAITING : ICU_ACTIVE;
163  osalSysUnlock();
164
165  return result;
166 }
167
168 /**
169  * @brief Stops the input capture.
170  *
171  * @param[in] icup pointer to the @p ICUDriver object
172  *
173  * @api
174  */
176
177  osalDbgCheck(icup != NULL);
178
179  osalSysLock();
180  osalDbgAssert((icup->state == ICU_READY) || (icup->state == ICU_WAITING) ||
181  (icup->state == ICU_ACTIVE),
182  "invalid state");
183  icuStopCaptureI(icup);
184  osalSysUnlock();
185 }
186
187 /**
188  * @brief Enables notifications.
189  * @pre The ICU unit must have been activated using @p icuStart() and the
190  * capture started using @p icuStartCapture().
191  * @note If the notification is already enabled then the call has no effect.
192  *
193  * @param[in] icup pointer to the @p ICUDriver object
194  *
195  * @api
196  */
198
199  osalDbgCheck(icup != NULL);
200
201  osalSysLock();
202  osalDbgAssert((icup->state == ICU_WAITING) || (icup->state == ICU_ACTIVE),
203  "invalid state");
205  osalSysUnlock();
206 }
207
208 /**
209  * @brief Disables notifications.
210  * @pre The ICU unit must have been activated using @p icuStart() and the
211  * capture started using @p icuStartCapture().
212  * @note If the notification is already disabled then the call has no effect.
213  *
214  * @param[in] icup pointer to the @p ICUDriver object
215  *
216  * @api
217  */
219
220  osalDbgCheck(icup != NULL);
221
222  osalSysLock();
223  osalDbgAssert((icup->state == ICU_WAITING) || (icup->state == ICU_ACTIVE),
224  "invalid state");
226  osalSysUnlock();
227 }
228
229 #endif /* HAL_USE_ICU == TRUE */
230
231 /** @} */
Initializes the standard part of a ICUDriver structure.
Definition: hal_icu.c:68
void icu_lld_start(ICUDriver *icup)
Definition: hal_icu_lld.c:81
void icuInit(void)
Definition: hal_icu.c:56
bool icu_lld_wait_capture(ICUDriver *icup)
Definition: hal_icu_lld.c:136
#define icuDisableNotificationsI(icup)
Definition: hal_icu.h:125
#define icuEnableNotificationsI(icup)
Definition: hal_icu.h:113
Definition: osal.h:540
Definition: hal_icu_lld.h:82
Structure representing an ICU driver.
Definition: hal_icu_lld.h:111
#define icuAreNotificationsEnabledX(icup)
Check on notifications status.
Definition: hal_icu.h:137
void icu_lld_stop(ICUDriver *icup)
Definition: hal_icu_lld.c:100
void icuStopCapture(ICUDriver *icup)
Definition: hal_icu.c:175
void icuStartCapture(ICUDriver *icup)
Definition: hal_icu.c:125
bool icuWaitCapture(ICUDriver *icup)
Definition: hal_icu.c:151
const ICUConfig * config
Current configuration data.
Definition: hal_icu_lld.h:119
void icuDisableNotifications(ICUDriver *icup)
Definition: hal_icu.c:218
Definition: hal_icu.c:82
void icuEnableNotifications(ICUDriver *icup)
Definition: hal_icu.c:197
#define icuStopCaptureI(icup)
Definition: hal_icu.h:98
Definition: hal_icu.c:102
#define icuStartCaptureI(icup)
Definition: hal_icu.h:86
static void osalSysLock(void)
Definition: osal.h:530
icustate_t state
Definition: hal_icu_lld.h:115
void icu_lld_init(void)
Low level ICU driver initialization.
Definition: hal_icu_lld.c:66
