hal_mac.c
18  * @file hal_mac.c
19  * @brief MAC Driver code.
21  * @addtogroup MAC
27 #if (HAL_USE_MAC == TRUE) || defined(__DOXYGEN__)
33 #if (MAC_USE_ZERO_COPY == TRUE) && (MAC_SUPPORTS_ZERO_COPY == FALSE)
34 #error "MAC_USE_ZERO_COPY not supported by this implementation"
35 #endif
38 /* Driver exported variables. */
42 /* Driver local variables and types. */
46 /* Driver local functions. */
50 /* Driver interrupt handlers. */
52
54 /* Driver exported functions. */
56
57 /**
58  * @brief MAC Driver initialization.
59  * @note This function is implicitly invoked by @p halInit(), there is
60  * no need to explicitly initialize the driver.
61  *
62  * @init
63  */
64 void macInit(void) {
65
66  mac_lld_init();
67 }
68
69 /**
70  * @brief Initialize the standard part of a @p MACDriver structure.
71  *
72  * @param[out] macp pointer to the @p MACDriver object
73  *
74  * @init
75  */
76 void macObjectInit(MACDriver *macp) {
77
78  macp->state = MAC_STOP;
79  macp->config = NULL;
82 #if MAC_USE_EVENTS == TRUE
84 #endif
85 }
86
87 /**
88  * @brief Configures and activates the MAC peripheral.
89  *
90  * @param[in] macp pointer to the @p MACDriver object
91  * @param[in] config pointer to the @p MACConfig object
92  *
93  * @api
94  */
95 void macStart(MACDriver *macp, const MACConfig *config) {
96
97  osalDbgCheck((macp != NULL) && (config != NULL));
98
99  osalSysLock();
100  osalDbgAssert(macp->state == MAC_STOP,
101  "invalid state");
102  macp->config = config;
103  mac_lld_start(macp);
104  macp->state = MAC_ACTIVE;
105  osalSysUnlock();
106 }
107
108 /**
109  * @brief Deactivates the MAC peripheral.
110  *
111  * @param[in] macp pointer to the @p MACDriver object
112  *
113  * @api
114  */
115 void macStop(MACDriver *macp) {
116
117  osalDbgCheck(macp != NULL);
118
119  osalSysLock();
120
121  osalDbgAssert((macp->state == MAC_STOP) || (macp->state == MAC_ACTIVE),
122  "invalid state");
123
124  mac_lld_stop(macp);
125  macp->config = NULL;
126  macp->state = MAC_STOP;
127
128  osalSysUnlock();
129 }
130
131 /**
132  * @brief Allocates a transmission descriptor.
133  * @details One of the available transmission descriptors is locked and
134  * returned. If a descriptor is not currently available then the
135  * invoking thread is queued until one is freed.
136  *
137  * @param[in] macp pointer to the @p MACDriver object
138  * @param[out] tdp pointer to a @p MACTransmitDescriptor structure
139  * @param[in] timeout the number of ticks before the operation timeouts,
140  * the following special values are allowed:
141  * - @a TIME_IMMEDIATE immediate timeout.
142  * - @a TIME_INFINITE no timeout.
143  * .
144  * @return The operation status.
145  * @retval MSG_OK the descriptor was obtained.
146  * @retval MSG_TIMEOUT the operation timed out, descriptor not initialized.
147  *
148  * @api
149  */
152  sysinterval_t timeout) {
153  msg_t msg;
154
155  osalDbgCheck((macp != NULL) && (tdp != NULL));
156  osalDbgAssert(macp->state == MAC_ACTIVE, "not active");
157
158  while (((msg = mac_lld_get_transmit_descriptor(macp, tdp)) != MSG_OK) &&
159  (timeout > (sysinterval_t)0)) {
160  osalSysLock();
161  msg = osalThreadEnqueueTimeoutS(&macp->tdqueue, timeout);
162  if (msg == MSG_TIMEOUT) {
163  osalSysUnlock();
164  break;
165  }
166  osalSysUnlock();
167  }
168  return msg;
169 }
170
171 /**
172  * @brief Releases a transmit descriptor and starts the transmission of the
173  * enqueued data as a single frame.
174  *
175  * @param[in] tdp the pointer to the @p MACTransmitDescriptor structure
176  *
177  * @api
178  */
180
181  osalDbgCheck(tdp != NULL);
182
184 }
185
186 /**
187  * @brief Waits for a received frame.
188  * @details Stops until a frame is received and buffered. If a frame is
189  * not immediately available then the invoking thread is queued
190  * until one is received.
191  *
192  * @param[in] macp pointer to the @p MACDriver object
193  * @param[out] rdp pointer to a @p MACReceiveDescriptor structure
194  * @param[in] timeout the number of ticks before the operation timeouts,
195  * the following special values are allowed:
196  * - @a TIME_IMMEDIATE immediate timeout.
197  * - @a TIME_INFINITE no timeout.
198  * .
199  * @return The operation status.
200  * @retval MSG_OK the descriptor was obtained.
201  * @retval MSG_TIMEOUT the operation timed out, descriptor not initialized.
202  *
203  * @api
204  */
207  sysinterval_t timeout) {
208  msg_t msg;
209
210  osalDbgCheck((macp != NULL) && (rdp != NULL));
211  osalDbgAssert(macp->state == MAC_ACTIVE, "not active");
212
213  while (((msg = mac_lld_get_receive_descriptor(macp, rdp)) != MSG_OK)) {
214  osalSysLock();
215  msg = osalThreadEnqueueTimeoutS(&macp->rdqueue, timeout);
216  if (msg == MSG_TIMEOUT) {
217  osalSysUnlock();
218  break;
219  }
220  osalSysUnlock();
221  }
222  return msg;
223 }
224
225 /**
226  * @brief Releases a receive descriptor.
227  * @details The descriptor and its buffer are made available for more incoming
228  * frames.
229  *
230  * @param[in] rdp the pointer to the @p MACReceiveDescriptor structure
231  *
232  * @api
233  */
235
236  osalDbgCheck(rdp != NULL);
237
239 }
240
241 /**
242  * @brief Updates and returns the link status.
243  *
244  * @param[in] macp pointer to the @p MACDriver object
245  * @return The link status.
246  * @retval true if the link is active.
247  * @retval false if the link is down.
248  *
249  * @api
250  */
252
253  osalDbgCheck(macp != NULL);
254  osalDbgAssert(macp->state == MAC_ACTIVE, "not active");
255
256  return mac_lld_poll_link_status(macp);
257 }
258
259 #endif /* HAL_USE_MAC == TRUE */
260
261 /** @} */
void macReleaseReceiveDescriptor(MACReceiveDescriptor *rdp)
Definition: hal_mac.c:234
msg_t macWaitTransmitDescriptor(MACDriver *macp, MACTransmitDescriptor *tdp, sysinterval_t timeout)
Definition: hal_mac.c:150
uint64_t sysinterval_t
Type of time interval.
Definition: chtime.h:119
threads_queue_t tdqueue
Transmit semaphore.
Definition: hal_mac_lld.h:91
void mac_lld_init(void)
Low level MAC initialization.
Definition: hal_mac_lld.c:69
Definition: hal_mac.c:95
Definition: osal.h:540
static void osalEventObjectInit(event_source_t *esp)
Initializes an event source object.
Definition: osal.h:665
event_source_t rdevent
Receive event.
Definition: hal_mac_lld.h:100
void mac_lld_release_receive_descriptor(MACReceiveDescriptor *rdp)
Definition: hal_mac_lld.c:184
#define MSG_TIMEOUT
Wakeup caused by a timeout condition.
Definition: chschd.h:40
macstate_t state
Definition: hal_mac_lld.h:83
msg_t macWaitReceiveDescriptor(MACDriver *macp, MACReceiveDescriptor *rdp, sysinterval_t timeout)
Definition: hal_mac.c:205
bool mac_lld_poll_link_status(MACDriver *macp)
Definition: hal_mac_lld.c:200
Structure representing a MAC driver.
Definition: hal_mac_lld.h:79
Initialize the standard part of a MACDriver structure.
Definition: hal_mac.c:76
msg_t mac_lld_get_receive_descriptor(MACDriver *macp, MACReceiveDescriptor *rdp)
Returns a receive descriptor.
Definition: hal_mac_lld.c:166
Structure representing a transmit descriptor.
Definition: hal_mac_lld.h:108
msg_t mac_lld_get_transmit_descriptor(MACDriver *macp, MACTransmitDescriptor *tdp)
Returns a transmission descriptor.
Definition: hal_mac_lld.c:132
void macReleaseTransmitDescriptor(MACTransmitDescriptor *tdp)
Releases a transmit descriptor and starts the transmission of the enqueued data as a single frame...
Definition: hal_mac.c:179
bool macPollLinkStatus(MACDriver *macp)
Definition: hal_mac.c:251
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
const MACConfig * config
Current configuration data.
Definition: hal_mac_lld.h:87
void mac_lld_release_transmit_descriptor(MACTransmitDescriptor *tdp)
Definition: hal_mac_lld.c:149
msg_t osalThreadEnqueueTimeoutS(threads_queue_t *tqp, sysinterval_t timeout)
Enqueues the caller thread.
Definition: osal.c:277
void mac_lld_start(MACDriver *macp)
Definition: hal_mac_lld.c:84
void mac_lld_stop(MACDriver *macp)
Definition: hal_mac_lld.c:105
threads_queue_t rdqueue
Receive semaphore.
Definition: hal_mac_lld.h:95
static void osalSysLock(void)
Definition: osal.h:530
Definition: hal_mac_lld.h:68
Structure representing a receive descriptor.
Definition: hal_mac_lld.h:123
void macInit(void)
Definition: hal_mac.c:64
Definition: hal_mac.c:115
static void osalThreadQueueObjectInit(threads_queue_t *tqp)
Initializes a threads queue object.
Definition: osal.h:653
int32_t msg_t
Definition: chtypes.h:51
