hal_pwm_lld.c
18  * @file hal_pwm_lld.c
19  * @brief PLATFORM PWM subsystem low level driver source.
21  * @addtogroup PWM
27 #if (HAL_USE_PWM == TRUE) || defined(__DOXYGEN__)
37 /**
38  * @brief PWMD1 driver identifier.
39  * @note The driver PWMD1 allocates the complex timer TIM1 when enabled.
40  */
41 #if (PLATFORM_PWM_USE_PWM1 == TRUE) || defined(__DOXYGEN__)
43 #endif
46 /* Driver local variables and types. */
50 /* Driver local functions. */
52
54 /* Driver interrupt handlers. */
56
58 /* Driver exported functions. */
60
61 /**
62  * @brief Low level PWM driver initialization.
63  *
64  * @notapi
65  */
66 void pwm_lld_init(void) {
67
68 #if PLATFORM_PWM_USE_PWM1 == TRUE
69  /* Driver initialization.*/
70  pwmObjectInit(&PWMD1);
71 #endif
72 }
73
74 /**
75  * @brief Configures and activates the PWM peripheral.
76  * @note Starting a driver that is already in the @p PWM_READY state
77  * disables all the active channels.
78  *
79  * @param[in] pwmp pointer to a @p PWMDriver object
80  *
81  * @notapi
82  */
83 void pwm_lld_start(PWMDriver *pwmp) {
84
85  if (pwmp->state == PWM_STOP) {
86  /* Clock activation and timer reset.*/
87 #if PLATFORM_PWM_USE_PWM1 == TRUE
88  if (&PWMD1 == pwmp) {
89
90  }
91 #endif
92  }
93 }
94
95 /**
96  * @brief Deactivates the PWM peripheral.
97  *
98  * @param[in] pwmp pointer to a @p PWMDriver object
99  *
100  * @notapi
101  */
102 void pwm_lld_stop(PWMDriver *pwmp) {
103
104  /* If in ready state then disables the PWM clock.*/
105  if (pwmp->state == PWM_READY) {
106 #if PLATFORM_PWM_USE_PWM1 == TRUE
107  if (&PWMD1 == pwmp) {
108
109  }
110 #endif
111  }
112 }
113
114 /**
115  * @brief Enables a PWM channel.
116  * @pre The PWM unit must have been activated using @p pwmStart().
117  * @post The channel is active using the specified configuration.
118  * @note The function has effect at the next cycle start.
119  * @note Channel notification is not enabled.
120  *
121  * @param[in] pwmp pointer to a @p PWMDriver object
122  * @param[in] channel PWM channel identifier (0...channels-1)
123  * @param[in] width PWM pulse width as clock pulses number
124  *
125  * @notapi
126  */
128  pwmchannel_t channel,
129  pwmcnt_t width) {
130
131  (void)pwmp;
132  (void)channel;
133  (void)width;
134 }
135
136 /**
137  * @brief Disables a PWM channel and its notification.
138  * @pre The PWM unit must have been activated using @p pwmStart().
139  * @post The channel is disabled and its output line returned to the
140  * idle state.
141  * @note The function has effect at the next cycle start.
142  *
143  * @param[in] pwmp pointer to a @p PWMDriver object
144  * @param[in] channel PWM channel identifier (0...channels-1)
145  *
146  * @notapi
147  */
149
150  (void)pwmp;
151  (void)channel;
152 }
153
154 /**
155  * @brief Enables the periodic activation edge notification.
156  * @pre The PWM unit must have been activated using @p pwmStart().
157  * @note If the notification is already enabled then the call has no effect.
158  *
159  * @param[in] pwmp pointer to a @p PWMDriver object
160  *
161  * @notapi
162  */
164
165  (void)pwmp;
166 }
167
168 /**
169  * @brief Disables the periodic activation edge notification.
170  * @pre The PWM unit must have been activated using @p pwmStart().
171  * @note If the notification is already disabled then the call has no effect.
172  *
173  * @param[in] pwmp pointer to a @p PWMDriver object
174  *
175  * @notapi
176  */
178
179  (void)pwmp;
180 }
181
182 /**
183  * @brief Enables a channel de-activation edge notification.
184  * @pre The PWM unit must have been activated using @p pwmStart().
185  * @pre The channel must have been activated using @p pwmEnableChannel().
186  * @note If the notification is already enabled then the call has no effect.
187  *
188  * @param[in] pwmp pointer to a @p PWMDriver object
189  * @param[in] channel PWM channel identifier (0...channels-1)
190  *
191  * @notapi
192  */
194  pwmchannel_t channel) {
195
196  (void)pwmp;
197  (void)channel;
198 }
199
200 /**
201  * @brief Disables a channel de-activation edge notification.
202  * @pre The PWM unit must have been activated using @p pwmStart().
203  * @pre The channel must have been activated using @p pwmEnableChannel().
204  * @note If the notification is already disabled then the call has no effect.
205  *
206  * @param[in] pwmp pointer to a @p PWMDriver object
207  * @param[in] channel PWM channel identifier (0...channels-1)
208  *
209  * @notapi
210  */
212  pwmchannel_t channel) {
213
214  (void)pwmp;
215  (void)channel;
216 }
217
218 #endif /* HAL_USE_PWM == TRUE */
219
220 /** @} */
void pwm_lld_enable_periodic_notification(PWMDriver *pwmp)
Definition: hal_pwm_lld.c:163
pwmstate_t state
Definition: hal_pwm_lld.h:138
void pwm_lld_disable_channel_notification(PWMDriver *pwmp, pwmchannel_t channel)
Definition: hal_pwm_lld.c:211
uint32_t pwmcnt_t
Type of a PWM counter.
Definition: hal_pwm_lld.h:83
Structure representing a PWM driver.
Definition: hal_pwm_lld.h:134
void pwm_lld_enable_channel(PWMDriver *pwmp, pwmchannel_t channel, pwmcnt_t width)
Definition: hal_pwm_lld.c:127
void pwm_lld_disable_channel(PWMDriver *pwmp, pwmchannel_t channel)
Definition: hal_pwm_lld.c:148
void pwm_lld_enable_channel_notification(PWMDriver *pwmp, pwmchannel_t channel)
Definition: hal_pwm_lld.c:193
void pwm_lld_disable_periodic_notification(PWMDriver *pwmp)
Definition: hal_pwm_lld.c:177
PWMDriver PWMD1
Definition: hal_pwm_lld.c:42
Definition: hal_pwm_lld.c:102
Definition: hal_pwm_lld.c:83
uint8_t pwmchannel_t
Type of a PWM channel.
Definition: hal_pwm_lld.h:73
void pwmObjectInit(PWMDriver *pwmp)
Initializes the standard part of a PWMDriver structure.
Definition: hal_pwm.c:68
Definition: hal_pwm_lld.c:66
