hal_sdc.h
18  * @file hal_sdc.h
19  * @brief SDC Driver macros and structures.
21  * @addtogroup SDC
25 #ifndef HAL_SDC_H
26 #define HAL_SDC_H
28 #if (HAL_USE_SDC == TRUE) || defined(__DOXYGEN__)
31 /* Driver constants. */
34 /**
35  * @name SD card types
36  * @{
37  */
38 #define SDC_MODE_CARDTYPE_MASK 0xFU
39 #define SDC_MODE_CARDTYPE_SDV11 0U
40 #define SDC_MODE_CARDTYPE_SDV20 1U
41 #define SDC_MODE_CARDTYPE_MMC 2U
42 #define SDC_MODE_HIGH_CAPACITY 0x10U
43 /** @} */
45 /**
46  * @name SDC bus error conditions
47  * @{
48  */
49 #define SDC_NO_ERROR 0U
50 #define SDC_CMD_CRC_ERROR 1U
51 #define SDC_DATA_CRC_ERROR 2U
52 #define SDC_DATA_TIMEOUT 4U
53 #define SDC_COMMAND_TIMEOUT 8U
54 #define SDC_TX_UNDERRUN 16U
55 #define SDC_RX_OVERRUN 32U
56 #define SDC_STARTBIT_ERROR 64U
57 #define SDC_OVERFLOW_ERROR 128U
58 #define SDC_UNHANDLED_ERROR 0xFFFFFFFFU
59 /** @} */
60
61 /*===========================================================================*/
62 /* Driver pre-compile time settings. */
63 /*===========================================================================*/
64
65 /**
66  * @name SDC configuration options
67  * @{
68  */
69 /**
70  * @brief Number of initialization attempts before rejecting the card.
71  * @note Attempts are performed at 10mS intervals.
72  */
73 #if !defined(SDC_INIT_RETRY) || defined(__DOXYGEN__)
74 #define SDC_INIT_RETRY 100
75 #endif
76
77 /**
78  * @brief Include support for MMC cards.
79  * @note MMC support is not yet implemented so this option must be kept
80  * at @p FALSE.
81  */
82 #if !defined(SDC_MMC_SUPPORT) || defined(__DOXYGEN__)
83 #define SDC_MMC_SUPPORT FALSE
84 #endif
85
86 /**
87  * @brief Delays insertions.
88  * @details If enabled this options inserts delays into the MMC waiting
89  * routines releasing some extra CPU time for the threads with
90  * lower priority, this may slow down the driver a bit however.
91  */
92 #if !defined(SDC_NICE_WAITING) || defined(__DOXYGEN__)
93 #define SDC_NICE_WAITING TRUE
94 #endif
95
96 /**
97  * @brief OCR initialization constant for V20 cards.
98  */
99 #if !defined(SDC_INIT_OCR_V20) || defined(__DOXYGEN__)
100 #define SDC_INIT_OCR_V20 0x50FF8000U
101 #endif
102
103 /**
104  * @brief OCR initialization constant for non-V20 cards.
105  */
106 #if !defined(SDC_INIT_OCR) || defined(__DOXYGEN__)
107 #define SDC_INIT_OCR 0x80100000U
108 #endif
109 /** @} */
110
111 /*===========================================================================*/
112 /* Derived constants and error checks. */
113 /*===========================================================================*/
114
115 /*===========================================================================*/
116 /* Driver data structures and types. */
117 /*===========================================================================*/
118
119 /**
120  * @brief Type of SDIO bus mode.
121  */
122 typedef enum {
123  SDC_MODE_1BIT = 0,
124  SDC_MODE_4BIT,
125  SDC_MODE_8BIT
126 } sdcbusmode_t;
127
128 /**
129  * @brief Max supported clock.
130  */
131 typedef enum {
132  SDC_CLK_25MHz = 0,
133  SDC_CLK_50MHz
134 } sdcbusclk_t;
135
136 #include "hal_sdc_lld.h"
137
138 /*===========================================================================*/
139 /* Driver macros. */
140 /*===========================================================================*/
141
142 /**
143  * @name Macro Functions
144  * @{
145  */
146 /**
147  * @brief Returns the card insertion status.
148  * @note This macro wraps a low level function named
149  * @p sdc_lld_is_card_inserted(), this function must be
150  * provided by the application because it is not part of the
151  * SDC driver.
152  *
153  * @param[in] sdcp pointer to the @p SDCDriver object
154  * @return The card state.
155  * @retval false card not inserted.
156  * @retval true card inserted.
157  *
158  * @api
159  */
160 #define sdcIsCardInserted(sdcp) (sdc_lld_is_card_inserted(sdcp))
161
162 /**
163  * @brief Returns the write protect status.
164  * @note This macro wraps a low level function named
165  * @p sdc_lld_is_write_protected(), this function must be
166  * provided by the application because it is not part of the
167  * SDC driver.
168  *
169  * @param[in] sdcp pointer to the @p SDCDriver object
170  * @return The card state.
171  * @retval false not write protected.
172  * @retval true write protected.
173  *
174  * @api
175  */
176 #define sdcIsWriteProtected(sdcp) (sdc_lld_is_write_protected(sdcp))
177 /** @} */
178
179 /*===========================================================================*/
180 /* External declarations. */
181 /*===========================================================================*/
182
183 #ifdef __cplusplus
184 extern "C" {
185 #endif
186  void sdcInit(void);
187  void sdcObjectInit(SDCDriver *sdcp);
188  void sdcStart(SDCDriver *sdcp, const SDCConfig *config);
189  void sdcStop(SDCDriver *sdcp);
190  bool sdcConnect(SDCDriver *sdcp);
191  bool sdcDisconnect(SDCDriver *sdcp);
192  bool sdcRead(SDCDriver *sdcp, uint32_t startblk,
193  uint8_t *buf, uint32_t n);
194  bool sdcWrite(SDCDriver *sdcp, uint32_t startblk,
195  const uint8_t *buf, uint32_t n);
197  bool sdcSync(SDCDriver *sdcp);
198  bool sdcGetInfo(SDCDriver *sdcp, BlockDeviceInfo *bdip);
199  bool sdcErase(SDCDriver *sdcp, uint32_t startblk, uint32_t endblk);
201 #ifdef __cplusplus
202 }
203 #endif
204
205 #endif /* HAL_USE_SDC == TRUE */
206
207 #endif /* HAL_SDC_H */
208
209 /** @} */
PLATFORM SDC subsystem low level driver header.
bool _sdc_wait_for_transfer_state(SDCDriver *sdcp)
Wait for the card to complete pending operations.
Definition: hal_sdc.c:503
Performs the initialization procedure on the inserted card.
Definition: hal_sdc.c:623
void sdcInit(void)
SDC Driver initialization.
Definition: hal_sdc.c:542
Brings the driver in a state safe for card removal.
Definition: hal_sdc.c:762
Erases the supplied blocks.
Definition: hal_sdc.c:954
bool sdcRead(SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
Reads one or more blocks.
Definition: hal_sdc.c:805
Block device info.
Definition: hal_ioblock.h:55
sdcflags_t sdcGetAndClearErrors(SDCDriver *sdcp)
Returns the errors mask associated to the previous operation.
Definition: hal_sdc.c:872
Initializes the standard part of a SDCDriver structure.
Definition: hal_sdc.c:554
sdcbusclk_t
Definition: hal_sdc.h:131
Waits for card idle condition.
Definition: hal_sdc.c:896
Returns the media info.
Definition: hal_sdc.c:927
sdcbusmode_t
Definition: hal_sdc.h:122
uint32_t sdcflags_t
SDC Driver condition flags type.
Definition: hal_sdc_lld.h:68
bool sdcWrite(SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
Writes one or more blocks.
Definition: hal_sdc.c:842
Structure representing an SDC driver.
Definition: hal_sdc_lld.h:113
Configures and activates the SDC peripheral.
Definition: hal_sdc.c:573
Deactivates the SDC peripheral.
Definition: hal_sdc.c:593
Definition: hal_sdc_lld.h:79
