hal_sdc.c
18  * @file hal_sdc.c
19  * @brief SDC Driver code.
21  * @addtogroup SDC
25 #include <string.h>
27 #include "hal.h"
29 #if (HAL_USE_SDC == TRUE) || defined(__DOXYGEN__)
30
32 /* Driver local definitions. */
34
35 /**
36  * @brief MMC switch mode.
37  */
38 typedef enum {
39  MMC_SWITCH_COMMAND_SET = 0,
40  MMC_SWITCH_SET_BITS = 1,
41  MMC_SWITCH_CLEAR_BITS = 2,
42  MMC_SWITCH_WRITE_BYTE = 3
43 } mmc_switch_t;
45 /**
46  * @brief SDC switch mode.
47  */
48 typedef enum {
49  SD_SWITCH_CHECK = 0,
50  SD_SWITCH_SET = 1
51 } sd_switch_t;
52
53 /**
54  * @brief SDC switch function.
55  */
56 typedef enum {
57  SD_SWITCH_FUNCTION_SPEED = 0,
58  SD_SWITCH_FUNCTION_CMD_SYSTEM = 1,
59  SD_SWITCH_FUNCTION_DRIVER_STRENGTH = 2,
60  SD_SWITCH_FUNCTION_CURRENT_LIMIT = 3
62
63 /*===========================================================================*/
64 /* Driver exported variables. */
65 /*===========================================================================*/
66
67 /*===========================================================================*/
68 /* Driver local variables and types. */
69 /*===========================================================================*/
70
71 /**
72  * @brief Virtual methods table.
73  */
74 static const struct SDCDriverVMT sdc_vmt = {
75  (size_t)0,
76  (bool (*)(void *))sdc_lld_is_card_inserted,
77  (bool (*)(void *))sdc_lld_is_write_protected,
78  (bool (*)(void *))sdcConnect,
79  (bool (*)(void *))sdcDisconnect,
80  (bool (*)(void *, uint32_t, uint8_t *, uint32_t))sdcRead,
81  (bool (*)(void *, uint32_t, const uint8_t *, uint32_t))sdcWrite,
82  (bool (*)(void *))sdcSync,
83  (bool (*)(void *, BlockDeviceInfo *))sdcGetInfo
84 };
85
86 /*===========================================================================*/
87 /* Driver local functions. */
88 /*===========================================================================*/
89 /**
90  * @brief Detects card mode.
91  *
92  * @param[in] sdcp pointer to the @p SDCDriver object
93  *
94  * @return The operation status.
95  * @retval HAL_SUCCESS operation succeeded.
96  * @retval HAL_FAILED operation failed.
97  *
98  * @notapi
99  */
100 static bool mode_detect(SDCDriver *sdcp) {
101  uint32_t resp[1];
102
103  /* V2.0 cards detection.*/
104  if (!sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEND_IF_COND,
105  MMCSD_CMD8_PATTERN, resp)) {
106  sdcp->cardmode = SDC_MODE_CARDTYPE_SDV20;
107  /* Voltage verification.*/
108  if (((resp[0] >> 8U) & 0xFU) != 1U) {
109  return HAL_FAILED;
110  }
111  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_APP_CMD, 0, resp) ||
112  MMCSD_R1_ERROR(resp[0])) {
113  return HAL_FAILED;
114  }
115  }
116  else {
117  /* MMC or SD V1.1 detection.*/
118  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_APP_CMD, 0, resp) ||
119  MMCSD_R1_ERROR(resp[0])) {
120  sdcp->cardmode = SDC_MODE_CARDTYPE_MMC;
121  }
122  else {
123  sdcp->cardmode = SDC_MODE_CARDTYPE_SDV11;
124
125  /* Reset error flag illegal command.*/
126  sdc_lld_send_cmd_none(sdcp, MMCSD_CMD_GO_IDLE_STATE, 0);
127  }
128  }
129
130  return HAL_SUCCESS;
131 }
132
133 /**
134  * @brief Init procedure for MMC.
135  *
136  * @param[in] sdcp pointer to the @p SDCDriver object
137  *
138  * @return The operation status.
139  * @retval HAL_SUCCESS operation succeeded.
140  * @retval HAL_FAILED operation failed.
141  *
142  * @notapi
143  */
144 static bool mmc_init(SDCDriver *sdcp) {
145  uint32_t ocr;
146  unsigned i;
147  uint32_t resp[1];
148
149  ocr = 0xC0FF8000U;
150  i = 0;
151  while (true) {
152  if (sdc_lld_send_cmd_short(sdcp, MMCSD_CMD_INIT, ocr, resp)) {
153  return HAL_FAILED;
154  }
155  if ((resp[0] & 0x80000000U) != 0U) {
156  if ((resp[0] & 0x40000000U) != 0U) {
157  sdcp->cardmode |= SDC_MODE_HIGH_CAPACITY;
158  }
159  break;
160  }
161  if (++i >= (unsigned)SDC_INIT_RETRY) {
162  return HAL_FAILED;
163  }
165  }
166
167  return HAL_SUCCESS;
168 }
169
170 /**
171  * @brief Init procedure for SDC.
172  *
173  * @param[in] sdcp pointer to the @p SDCDriver object
174  *
175  * @return The operation status.
176  * @retval HAL_SUCCESS operation succeeded.
177  * @retval HAL_FAILED operation failed.
178  *
179  * @notapi
180  */
181 static bool sdc_init(SDCDriver *sdcp) {
182  unsigned i;
183  uint32_t ocr;
184  uint32_t resp[1];
185
186  if ((sdcp->cardmode & SDC_MODE_CARDTYPE_MASK) == SDC_MODE_CARDTYPE_SDV20) {
187  ocr = SDC_INIT_OCR_V20;
188  }
189  else {
190  ocr = SDC_INIT_OCR;
191  }
192
193  i = 0;
194  while (true) {
195  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_APP_CMD, 0, resp) ||
196  MMCSD_R1_ERROR(resp[0])) {
197  return HAL_FAILED;
198  }
199  if (sdc_lld_send_cmd_short(sdcp, MMCSD_CMD_APP_OP_COND, ocr, resp)) {
200  return HAL_FAILED;
201  }
202  if ((resp[0] & 0x80000000U) != 0U) {
203  if ((resp[0] & 0x40000000U) != 0U) {
204  sdcp->cardmode |= SDC_MODE_HIGH_CAPACITY;
205  }
206  break;
207  }
208  if (++i >= (unsigned)SDC_INIT_RETRY) {
209  return HAL_FAILED;
210  }
212  }
213
214  return HAL_SUCCESS;
215 }
216
217 /**
218  * @brief Constructs CMD6 argument for MMC.
219  *
220  * @param[in] access EXT_CSD access mode
221  * @param[in] idx EXT_CSD byte number
222  * @param[in] value value to be written in target field
223  * @param[in] cmd_set switch current command set
224  *
225  * @return CMD6 argument.
226  *
227  * @notapi
228  */
229 static uint32_t mmc_cmd6_construct(mmc_switch_t access, uint32_t idx,
230  uint32_t value, uint32_t cmd_set) {
231
232  osalDbgAssert(idx <= 191U, "This field is not writable");
233  osalDbgAssert(cmd_set < 8U, "This field has only 3 bits");
234
235  return ((uint32_t)access << 24U) | (idx << 16U) | (value << 8U) | cmd_set;
236 }
237
238 /**
239  * @brief Constructs CMD6 argument for SDC.
240  *
241  * @param[in] mode switch/test mode
242  * @param[in] function function number to be switched
243  * @param[in] value value to be written in target function
244  *
245  * @return CMD6 argument.
246  *
247  * @notapi
248  */
249 static uint32_t sdc_cmd6_construct(sd_switch_t mode,
250  sd_switch_function_t function,
251  uint32_t value) {
252  uint32_t ret = 0xFFFFFF;
253
254  osalDbgAssert((value < 16U), "This field has only 4 bits");
255
256  ret &= ~((uint32_t)0xFU << ((uint32_t)function * 4U));
257  ret |= value << ((uint32_t)function * 4U);
258  return ret | ((uint32_t)mode << 31U);
259 }
260
261 /**
262  * @brief Extracts information from CMD6 answer.
263  *
264  * @param[in] function function number to be switched
265  * @param[in] buf buffer with answer
266  *
267  * @return extracted answer.
268  *
269  * @notapi
270  */
272  const uint8_t *buf) {
273
274  unsigned start = 12U - ((unsigned)function * 2U);
275
276  return ((uint16_t)buf[start] << 8U) | (uint16_t)buf[start + 1U];
277 }
278
279 /**
280  * @brief Checks status after switching using CMD6.
281  *
282  * @param[in] function function number to be switched
283  * @param[in] buf buffer with answer
284  *
285  * @return The operation status.
286  * @retval HAL_SUCCESS operation succeeded.
287  * @retval HAL_FAILED operation failed.
288  *
289  * @notapi
290  */
292  const uint8_t *buf) {
293
294  uint32_t tmp;
295  uint32_t status;
296
297  tmp = ((uint32_t)buf[14] << 16U) |
298  ((uint32_t)buf[15] << 8U) |
299  (uint32_t)buf[16];
300  status = (tmp >> ((uint32_t)function * 4U)) & 0xFU;
301  if (0xFU != status) {
302  return HAL_SUCCESS;
303  }
304  return HAL_FAILED;
305 }
306
307 /**
308  * @brief Reads supported bus clock and switch SDC to appropriate mode.
309  *
310  * @param[in] sdcp pointer to the @p SDCDriver object
311  * @param[out] clk pointer to clock enum
312  *
313  * @return The operation status.
314  * @retval HAL_SUCCESS operation succeeded.
315  * @retval HAL_FAILED operation failed.
316  *
317  * @notapi
318  */
319 static bool sdc_detect_bus_clk(SDCDriver *sdcp, sdcbusclk_t *clk) {
320  uint32_t cmdarg;
321  const size_t N = 64;
322  uint8_t tmp[N];
323
324  /* Safe default.*/
325  *clk = SDC_CLK_25MHz;
326
327  /* Looks like only "high capacity" cards produce meaningful results during
328  this clock detection procedure.*/
329  if (0U == _mmcsd_get_slice(sdcp->csd, MMCSD_CSD_10_CSD_STRUCTURE_SLICE)) {
330  *clk = SDC_CLK_25MHz;
331  return HAL_SUCCESS;
332  }
333
334  /* Read switch functions' register.*/
335  if (sdc_lld_read_special(sdcp, tmp, N, MMCSD_CMD_SWITCH, 0)) {
336  return HAL_FAILED;
337  }
338
339  /* Check card capabilities parsing acquired data.*/
340  if ((sdc_cmd6_extract_info(SD_SWITCH_FUNCTION_SPEED, tmp) & 2U) == 2U) {
341  /* Construct command to set the bus speed.*/
342  cmdarg = sdc_cmd6_construct(SD_SWITCH_SET, SD_SWITCH_FUNCTION_SPEED, 1);
343
344  /* Write constructed command and read operation status in single call.*/
345  if (sdc_lld_read_special(sdcp, tmp, N, MMCSD_CMD_SWITCH, cmdarg)) {
346  return HAL_FAILED;
347  }
348
349  /* Check card answer for success status bits.*/
350  if (HAL_SUCCESS == sdc_cmd6_check_status(SD_SWITCH_FUNCTION_SPEED, tmp)) {
351  *clk = SDC_CLK_50MHz;
352  }
353  else {
354  *clk = SDC_CLK_25MHz;
355  }
356  }
357
358  return HAL_SUCCESS;
359 }
360
361 /**
362  * @brief Reads supported bus clock and switch MMC to appropriate mode.
363  *
364  * @param[in] sdcp pointer to the @p SDCDriver object
365  * @param[out] clk pointer to clock enum
366  *
367  * @return The operation status.
368  * @retval HAL_SUCCESS operation succeeded.
369  * @retval HAL_FAILED operation failed.
370  *
371  * @notapi
372  */
373 static bool mmc_detect_bus_clk(SDCDriver *sdcp, sdcbusclk_t *clk) {
374  uint32_t cmdarg;
375  uint32_t resp[1];
376  uint8_t *scratchpad = sdcp->config->scratchpad;
377
378  /* Safe default.*/
379  *clk = SDC_CLK_25MHz;
380
381  /* Use safe default when there is no space for data.*/
382  if (NULL == scratchpad) {
383  return HAL_SUCCESS;
384  }
385
386  cmdarg = mmc_cmd6_construct(MMC_SWITCH_WRITE_BYTE, 185, 1, 0);
387  if (!(sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SWITCH, cmdarg, resp) ||
388  MMCSD_R1_ERROR(resp[0]))) {
389  *clk = SDC_CLK_50MHz;
390  }
391
392  return HAL_SUCCESS;
393 }
394
395 /**
396  * @brief Reads supported bus clock and switch card to appropriate mode.
397  *
398  * @param[in] sdcp pointer to the @p SDCDriver object
399  * @param[out] clk pointer to clock enum
400  *
401  * @return The operation status.
402  * @retval HAL_SUCCESS operation succeeded.
403  * @retval HAL_FAILED operation failed.
404  *
405  * @notapi
406  */
407 static bool detect_bus_clk(SDCDriver *sdcp, sdcbusclk_t *clk) {
408
409  if (SDC_MODE_CARDTYPE_MMC == (sdcp->cardmode & SDC_MODE_CARDTYPE_MASK)) {
410  return mmc_detect_bus_clk(sdcp, clk);
411  }
412  return sdc_detect_bus_clk(sdcp, clk);
413 }
414
415 /**
416  * @brief Sets bus width for SDC.
417  *
418  * @param[in] sdcp pointer to the @p SDCDriver object
419  *
420  * @return The operation status.
421  * @retval HAL_SUCCESS operation succeeded.
422  * @retval HAL_FAILED operation failed.
423  *
424  * @notapi
425  */
426 static bool sdc_set_bus_width(SDCDriver *sdcp) {
427  uint32_t resp[1];
428
429  if (SDC_MODE_1BIT == sdcp->config->bus_width) {
430  /* Nothing to do. Bus is already in 1bit mode.*/
431  return HAL_SUCCESS;
432  }
433  else if (SDC_MODE_4BIT == sdcp->config->bus_width) {
434  sdc_lld_set_bus_mode(sdcp, SDC_MODE_4BIT);
435  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_APP_CMD, sdcp->rca, resp) ||
436  MMCSD_R1_ERROR(resp[0])) {
437  return HAL_FAILED;
438  }
439
440  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SET_BUS_WIDTH, 2, resp) ||
441  MMCSD_R1_ERROR(resp[0])) {
442  return HAL_FAILED;
443  }
444  }
445  else {
446  /* SD card does not support 8bit bus.*/
447  return HAL_FAILED;
448  }
449
450  return HAL_SUCCESS;
451 }
452
453 /**
454  * @brief Sets bus width for MMC.
455  *
456  * @param[in] sdcp pointer to the @p SDCDriver object
457  *
458  * @return The operation status.
459  * @retval HAL_SUCCESS operation succeeded.
460  * @retval HAL_FAILED operation failed.
461  *
462  * @notapi
463  */
464 static bool mmc_set_bus_width(SDCDriver *sdcp) {
465  uint32_t resp[1];
466  uint32_t cmdarg = mmc_cmd6_construct(MMC_SWITCH_WRITE_BYTE, 183, 0, 0);
467
468  switch (sdcp->config->bus_width) {
469  case SDC_MODE_1BIT:
470  /* Nothing to do. Bus is already in 1bit mode.*/
471  return HAL_SUCCESS;
472  case SDC_MODE_4BIT:
473  cmdarg = mmc_cmd6_construct(MMC_SWITCH_WRITE_BYTE, 183, 1, 0);
474  break;
475  case SDC_MODE_8BIT:
476  cmdarg = mmc_cmd6_construct(MMC_SWITCH_WRITE_BYTE, 183, 2, 0);
477  break;
478  default:
479  osalDbgAssert(false, "unexpected case");
480  break;
481  }
482
483  sdc_lld_set_bus_mode(sdcp, sdcp->config->bus_width);
484  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SWITCH, cmdarg, resp) ||
485  MMCSD_R1_ERROR(resp[0])) {
486  return HAL_FAILED;
487  }
488
489  return HAL_SUCCESS;
490 }
491
492 /**
493  * @brief Wait for the card to complete pending operations.
494  *
495  * @param[in] sdcp pointer to the @p SDCDriver object
496  *
497  * @return The operation status.
498  * @retval HAL_SUCCESS operation succeeded.
499  * @retval HAL_FAILED operation failed.
500  *
501  * @notapi
502  */
504  uint32_t resp[1];
505
506  while (true) {
507  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEND_STATUS,
508  sdcp->rca, resp) ||
509  MMCSD_R1_ERROR(resp[0])) {
510  return HAL_FAILED;
511  }
512
513  switch (MMCSD_R1_STS(resp[0])) {
514  case MMCSD_STS_TRAN:
515  return HAL_SUCCESS;
516  case MMCSD_STS_DATA:
517  case MMCSD_STS_RCV:
518  case MMCSD_STS_PRG:
519 #if SDC_NICE_WAITING == TRUE
521 #endif
522  continue;
523  default:
524  /* The card should have been initialized so any other state is not
525  valid and is reported as an error.*/
526  return HAL_FAILED;
527  }
528  }
529 }
530
531 /*===========================================================================*/
532 /* Driver exported functions. */
533 /*===========================================================================*/
534
535 /**
536  * @brief SDC Driver initialization.
537  * @note This function is implicitly invoked by @p halInit(), there is
538  * no need to explicitly initialize the driver.
539  *
540  * @init
541  */
542 void sdcInit(void) {
543
544  sdc_lld_init();
545 }
546
547 /**
548  * @brief Initializes the standard part of a @p SDCDriver structure.
549  *
550  * @param[out] sdcp pointer to the @p SDCDriver object
551  *
552  * @init
553  */
555
556  sdcp->vmt = &sdc_vmt;
557  sdcp->state = BLK_STOP;
558  sdcp->errors = SDC_NO_ERROR;
559  sdcp->config = NULL;
560  sdcp->capacity = 0;
561 }
562
563 /**
564  * @brief Configures and activates the SDC peripheral.
565  *
566  * @param[in] sdcp pointer to the @p SDCDriver object
567  * @param[in] config pointer to the @p SDCConfig object, can be @p NULL if
568  * the driver supports a default configuration or
569  * requires no configuration
570  *
571  * @api
572  */
573 void sdcStart(SDCDriver *sdcp, const SDCConfig *config) {
574
575  osalDbgCheck(sdcp != NULL);
576
577  osalSysLock();
578  osalDbgAssert((sdcp->state == BLK_STOP) || (sdcp->state == BLK_ACTIVE),
579  "invalid state");
580  sdcp->config = config;
581  sdc_lld_start(sdcp);
582  sdcp->state = BLK_ACTIVE;
583  osalSysUnlock();
584 }
585
586 /**
587  * @brief Deactivates the SDC peripheral.
588  *
589  * @param[in] sdcp pointer to the @p SDCDriver object
590  *
591  * @api
592  */
593 void sdcStop(SDCDriver *sdcp) {
594
595  osalDbgCheck(sdcp != NULL);
596
597  osalSysLock();
598
599  osalDbgAssert((sdcp->state == BLK_STOP) || (sdcp->state == BLK_ACTIVE),
600  "invalid state");
601
602  sdc_lld_stop(sdcp);
603  sdcp->config = NULL;
604  sdcp->state = BLK_STOP;
605
606  osalSysUnlock();
607 }
608
609 /**
610  * @brief Performs the initialization procedure on the inserted card.
611  * @details This function should be invoked when a card is inserted and
612  * brings the driver in the @p BLK_READY state where it is possible
613  * to perform read and write operations.
614  *
615  * @param[in] sdcp pointer to the @p SDCDriver object
616  *
617  * @return The operation status.
618  * @retval HAL_SUCCESS operation succeeded.
619  * @retval HAL_FAILED operation failed.
620  *
621  * @api
622  */
623 bool sdcConnect(SDCDriver *sdcp) {
624  uint32_t resp[1];
625  sdcbusclk_t clk = SDC_CLK_25MHz;
626
627  osalDbgCheck(sdcp != NULL);
628  osalDbgAssert((sdcp->state == BLK_ACTIVE) || (sdcp->state == BLK_READY),
629  "invalid state");
630
631  /* Connection procedure in progress.*/
632  sdcp->state = BLK_CONNECTING;
633
634  /* Card clock initialization.*/
635  sdc_lld_start_clk(sdcp);
636
637  /* Enforces the initial card state.*/
638  sdc_lld_send_cmd_none(sdcp, MMCSD_CMD_GO_IDLE_STATE, 0);
639
640  /* Detect card type.*/
641  if (HAL_FAILED == mode_detect(sdcp)) {
642  goto failed;
643  }
644
645  /* Perform specific initialization procedure.*/
646  if ((sdcp->cardmode & SDC_MODE_CARDTYPE_MASK) == SDC_MODE_CARDTYPE_MMC) {
647  if (HAL_FAILED == mmc_init(sdcp)) {
648  goto failed;
649  }
650  }
651  else {
652  if (HAL_FAILED == sdc_init(sdcp)) {
653  goto failed;
654  }
655  }
656
657  /* Reads CID.*/
658  if (sdc_lld_send_cmd_long_crc(sdcp, MMCSD_CMD_ALL_SEND_CID, 0, sdcp->cid)) {
659  goto failed;
660  }
661
662  /* Asks for the RCA.*/
663  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEND_RELATIVE_ADDR,
664  0, &sdcp->rca)) {
665  goto failed;
666  }
667
668  /* Reads CSD.*/
669  if (sdc_lld_send_cmd_long_crc(sdcp, MMCSD_CMD_SEND_CSD,
670  sdcp->rca, sdcp->csd)) {
671  goto failed;
672  }
673
674  /* Selects the card for operations.*/
675  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SEL_DESEL_CARD,
676  sdcp->rca, resp)) {
677  goto failed;
678  }
679
680  /* Switches to high speed.*/
681  if (HAL_SUCCESS != detect_bus_clk(sdcp, &clk)) {
682  goto failed;
683  }
684  sdc_lld_set_data_clk(sdcp, clk);
685
686  /* Reads extended CSD if needed and possible.*/
687  if (SDC_MODE_CARDTYPE_MMC == (sdcp->cardmode & SDC_MODE_CARDTYPE_MASK)) {
688
689  /* The card is a MMC, checking if it is a large device.*/
691  uint8_t *ext_csd = sdcp->config->scratchpad;
692
693  /* Size detection requires the buffer.*/
694  if (NULL == ext_csd) {
695  goto failed;
696  }
697
698  if(sdc_lld_read_special(sdcp, ext_csd, 512, MMCSD_CMD_SEND_EXT_CSD, 0)) {
699  goto failed;
700  }
701
702  /* Capacity from the EXT_CSD.*/
703  sdcp->capacity = _mmcsd_get_capacity_ext(ext_csd);
704  }
705  else {
706  /* Capacity from the normal CSD.*/
707  sdcp->capacity = _mmcsd_get_capacity(sdcp->csd);
708  }
709  }
710  else {
711  /* The card is an SDC, capacity from the normal CSD.*/
712  sdcp->capacity = _mmcsd_get_capacity(sdcp->csd);
713  }
714
715  /* Block length fixed at 512 bytes.*/
716  if (sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_SET_BLOCKLEN,
717  MMCSD_BLOCK_SIZE, resp) ||
718  MMCSD_R1_ERROR(resp[0])) {
719  goto failed;
720  }
721
722  /* Switches to wide bus mode.*/
723  switch (sdcp->cardmode & SDC_MODE_CARDTYPE_MASK) {
724  case SDC_MODE_CARDTYPE_SDV11:
725  case SDC_MODE_CARDTYPE_SDV20:
726  if (HAL_FAILED == sdc_set_bus_width(sdcp)) {
727  goto failed;
728  }
729  break;
730  case SDC_MODE_CARDTYPE_MMC:
731  if (HAL_FAILED == mmc_set_bus_width(sdcp)) {
732  goto failed;
733  }
734  break;
735  default:
736  /* Unknown type.*/
737  goto failed;
738  }
739
740  /* Initialization complete.*/
741  sdcp->state = BLK_READY;
742  return HAL_SUCCESS;
743
744  /* Connection failed, state reset to BLK_ACTIVE.*/
745 failed:
746  sdc_lld_stop_clk(sdcp);
747  sdcp->state = BLK_ACTIVE;
748  return HAL_FAILED;
749 }
750
751 /**
752  * @brief Brings the driver in a state safe for card removal.
753  *
754  * @param[in] sdcp pointer to the @p SDCDriver object
755  *
756  * @return The operation status.
757  * @retval HAL_SUCCESS operation succeeded.
758  * @retval HAL_FAILED operation failed.
759  *
760  * @api
761  */
763
764  osalDbgCheck(sdcp != NULL);
765
766  osalSysLock();
767  osalDbgAssert((sdcp->state == BLK_ACTIVE) || (sdcp->state == BLK_READY),
768  "invalid state");
769  if (sdcp->state == BLK_ACTIVE) {
770  osalSysUnlock();
771  return HAL_SUCCESS;
772  }
773  sdcp->state = BLK_DISCONNECTING;
774  osalSysUnlock();
775
776  /* Waits for eventual pending operations completion.*/
777  if (_sdc_wait_for_transfer_state(sdcp)) {
778  sdc_lld_stop_clk(sdcp);
779  sdcp->state = BLK_ACTIVE;
780  return HAL_FAILED;
781  }
782
783  /* Card clock stopped.*/
784  sdc_lld_stop_clk(sdcp);
785  sdcp->state = BLK_ACTIVE;
786  return HAL_SUCCESS;
787 }
788
789 /**
790  * @brief Reads one or more blocks.
791  * @pre The driver must be in the @p BLK_READY state after a successful
792  * sdcConnect() invocation.
793  *
794  * @param[in] sdcp pointer to the @p SDCDriver object
795  * @param[in] startblk first block to read
796  * @param[out] buf pointer to the read buffer
797  * @param[in] n number of blocks to read
798  *
799  * @return The operation status.
800  * @retval HAL_SUCCESS operation succeeded.
801  * @retval HAL_FAILED operation failed.
802  *
803  * @api
804  */
805 bool sdcRead(SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n) {
806  bool status;
807
808  osalDbgCheck((sdcp != NULL) && (buf != NULL) && (n > 0U));
809  osalDbgAssert(sdcp->state == BLK_READY, "invalid state");
810
811  if ((startblk + n - 1U) > sdcp->capacity) {
812  sdcp->errors |= SDC_OVERFLOW_ERROR;
813  return HAL_FAILED;
814  }
815
816  /* Read operation in progress.*/
817  sdcp->state = BLK_READING;
818
819  status = sdc_lld_read(sdcp, startblk, buf, n);
820
821  /* Read operation finished.*/
822  sdcp->state = BLK_READY;
823  return status;
824 }
825
826 /**
827  * @brief Writes one or more blocks.
828  * @pre The driver must be in the @p BLK_READY state after a successful
829  * sdcConnect() invocation.
830  *
831  * @param[in] sdcp pointer to the @p SDCDriver object
832  * @param[in] startblk first block to write
833  * @param[out] buf pointer to the write buffer
834  * @param[in] n number of blocks to write
835  *
836  * @return The operation status.
837  * @retval HAL_SUCCESS operation succeeded.
838  * @retval HAL_FAILED operation failed.
839  *
840  * @api
841  */
842 bool sdcWrite(SDCDriver *sdcp, uint32_t startblk,
843  const uint8_t *buf, uint32_t n) {
844  bool status;
845
846  osalDbgCheck((sdcp != NULL) && (buf != NULL) && (n > 0U));
847  osalDbgAssert(sdcp->state == BLK_READY, "invalid state");
848
849  if ((startblk + n - 1U) > sdcp->capacity) {
850  sdcp->errors |= SDC_OVERFLOW_ERROR;
851  return HAL_FAILED;
852  }
853
854  /* Write operation in progress.*/
855  sdcp->state = BLK_WRITING;
856
857  status = sdc_lld_write(sdcp, startblk, buf, n);
858
859  /* Write operation finished.*/
860  sdcp->state = BLK_READY;
861  return status;
862 }
863
864 /**
865  * @brief Returns the errors mask associated to the previous operation.
866  *
867  * @param[in] sdcp pointer to the @p SDCDriver object
868  * @return The errors mask.
869  *
870  * @api
871  */
873  sdcflags_t flags;
874
875  osalDbgCheck(sdcp != NULL);
876  osalDbgAssert(sdcp->state == BLK_READY, "invalid state");
877
878  osalSysLock();
879  flags = sdcp->errors;
880  sdcp->errors = SDC_NO_ERROR;
881  osalSysUnlock();
882  return flags;
883 }
884
885 /**
886  * @brief Waits for card idle condition.
887  *
888  * @param[in] sdcp pointer to the @p SDCDriver object
889  *
890  * @return The operation status.
891  * @retval HAL_SUCCESS the operation succeeded.
892  * @retval HAL_FAILED the operation failed.
893  *
894  * @api
895  */
896 bool sdcSync(SDCDriver *sdcp) {
897  bool result;
898
899  osalDbgCheck(sdcp != NULL);
900
901  if (sdcp->state != BLK_READY) {
902  return HAL_FAILED;
903  }
904
905  /* Synchronization operation in progress.*/
906  sdcp->state = BLK_SYNCING;
907
908  result = sdc_lld_sync(sdcp);
909
910  /* Synchronization operation finished.*/
911  sdcp->state = BLK_READY;
912  return result;
913 }
914
915 /**
916  * @brief Returns the media info.
917  *
918  * @param[in] sdcp pointer to the @p SDCDriver object
919  * @param[out] bdip pointer to a @p BlockDeviceInfo structure
920  *
921  * @return The operation status.
922  * @retval HAL_SUCCESS the operation succeeded.
923  * @retval HAL_FAILED the operation failed.
924  *
925  * @api
926  */
928
929  osalDbgCheck((sdcp != NULL) && (bdip != NULL));
930
931  if (sdcp->state != BLK_READY) {
932  return HAL_FAILED;
933  }
934
935  bdip->blk_num = sdcp->capacity;
936  bdip->blk_size = MMCSD_BLOCK_SIZE;
937
938  return HAL_SUCCESS;
939 }
940
941 /**
942  * @brief Erases the supplied blocks.
943  *
944  * @param[in] sdcp pointer to the @p SDCDriver object
945  * @param[in] startblk starting block number
946  * @param[in] endblk ending block number
947  *
948  * @return The operation status.
949  * @retval HAL_SUCCESS the operation succeeded.
950  * @retval HAL_FAILED the operation failed.
951  *
952  * @api
953  */
954 bool sdcErase(SDCDriver *sdcp, uint32_t startblk, uint32_t endblk) {
955  uint32_t resp[1];
956
957  osalDbgCheck((sdcp != NULL));
958  osalDbgAssert(sdcp->state == BLK_READY, "invalid state");
959
960  /* Erase operation in progress.*/
961  sdcp->state = BLK_WRITING;
962
963  /* Handling command differences between HC and normal cards.*/
964  if ((sdcp->cardmode & SDC_MODE_HIGH_CAPACITY) != 0U) {
965  startblk *= MMCSD_BLOCK_SIZE;
966  endblk *= MMCSD_BLOCK_SIZE;
967  }
968
969  if (_sdc_wait_for_transfer_state(sdcp)) {
970  goto failed;
971  }
972
973  if ((sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_ERASE_RW_BLK_START,
974  startblk, resp) != HAL_SUCCESS) ||
975  MMCSD_R1_ERROR(resp[0])) {
976  goto failed;
977  }
978
979  if ((sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_ERASE_RW_BLK_END,
980  endblk, resp) != HAL_SUCCESS) ||
981  MMCSD_R1_ERROR(resp[0])) {
982  goto failed;
983  }
984
985  if ((sdc_lld_send_cmd_short_crc(sdcp, MMCSD_CMD_ERASE,
986  0, resp) != HAL_SUCCESS) ||
987  MMCSD_R1_ERROR(resp[0])) {
988  goto failed;
989  }
990
991  /* Quick sleep to allow it to transition to programming or receiving state */
992  /* TODO: ??????????????????????????? */
993
994  /* Wait for it to return to transfer state to indicate it has finished erasing */
995  if (_sdc_wait_for_transfer_state(sdcp)) {
996  goto failed;
997  }
998
999  sdcp->state = BLK_READY;
1000  return HAL_SUCCESS;
1001
1002 failed:
1003  sdcp->state = BLK_READY;
1004  return HAL_FAILED;
1005 }
1006
1007 #endif /* HAL_USE_SDC == TRUE */
1008
1009 /** @} */
1010
bool sdc_lld_sync(SDCDriver *sdcp)
Definition: hal_sdc_lld.c:319
bool sdc_lld_send_cmd_short_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Sends an SDIO command with a short response expected and CRC.
Definition: hal_sdc_lld.c:222
Definition: hal_sdc.c:319
bool sdc_lld_send_cmd_short(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Sends an SDIO command with a short response expected.
Definition: hal_sdc_lld.c:197
bool _sdc_wait_for_transfer_state(SDCDriver *sdcp)
Definition: hal_sdc.c:503
static uint32_t mmc_cmd6_construct(mmc_switch_t access, uint32_t idx, uint32_t value, uint32_t cmd_set)
Definition: hal_sdc.c:229
Definition: hal_sdc.c:623
static uint32_t sdc_cmd6_construct(sd_switch_t mode, sd_switch_function_t function, uint32_t value)
Definition: hal_sdc.c:249
uint32_t _mmcsd_get_capacity_ext(const uint8_t *ext_csd)
Extract MMC card capacity from EXT_CSD.
Definition: hal_mmcsd.c:125
mmc_switch_t
MMC switch mode.
Definition: hal_sdc.c:38
const struct SDCDriverVMT * vmt
Virtual Methods Table.
Definition: hal_sdc_lld.h:117
sdcbusmode_t bus_width
Bus width.
Definition: hal_sdc_lld.h:91
#define MMCSD_BLOCK_SIZE
Fixed block size for MMC/SD block devices.
Definition: hal_mmcsd.h:39
Definition: hal_sdc.c:144
Definition: hal_sdc.c:373
Definition: osal.h:540
void sdcInit(void)
Definition: hal_sdc.c:542
uint32_t rca
Card RCA.
Definition: hal_sdc_lld.h:134
bool sdcDisconnect(SDCDriver *sdcp)
Definition: hal_sdc.c:762
#define MMCSD_CMD8_PATTERN
Fixed pattern for CMD8.
Definition: hal_mmcsd.h:49
Definition: hal_sdc.c:954
#define SDC_INIT_OCR_V20
OCR initialization constant for V20 cards.
Definition: hal_sdc.h:100
void sdc_lld_stop_clk(SDCDriver *sdcp)
Stops the SDIO clock.
Definition: hal_sdc_lld.c:133
bool sdc_lld_send_cmd_long_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Sends an SDIO command with a long response expected and CRC.
Definition: hal_sdc_lld.c:247
#define osalThreadSleepMilliseconds(msecs)
Delays the invoking thread for the specified number of milliseconds.
Definition: osal.h:451
Definition: hal_sdc.c:56
Definition: hal_sdc.c:805
void sdc_lld_start(SDCDriver *sdcp)
Definition: hal_sdc_lld.c:79
void sdc_lld_init(void)
Low level SDC driver initialization.
Definition: hal_sdc_lld.c:65
Block device info.
Definition: hal_ioblock.h:55
SDCDriver virtual methods table.
Definition: hal_sdc_lld.h:106
uint32_t blk_num
Total number of blocks.
Definition: hal_ioblock.h:57
sdcflags_t sdcGetAndClearErrors(SDCDriver *sdcp)
Definition: hal_sdc.c:872
void sdcObjectInit(SDCDriver *sdcp)
Initializes the standard part of a SDCDriver structure.
Definition: hal_sdc.c:554
void sdc_lld_set_data_clk(SDCDriver *sdcp, sdcbusclk_t clk)
Sets the SDIO clock to data mode (25MHz or less).
Definition: hal_sdc_lld.c:120
void sdc_lld_send_cmd_none(SDCDriver *sdcp, uint8_t cmd, uint32_t arg)
Sends an SDIO command with no response expected.
Definition: hal_sdc_lld.c:175
Definition: hal_sdc.c:181
uint32_t _mmcsd_get_slice(const uint32_t *data, uint32_t end, uint32_t start)
Gets a bit field from a words array.
Definition: hal_mmcsd.c:61
sdcflags_t errors
Errors flags.
Definition: hal_sdc_lld.h:130
Definition: hal_sdc.c:74
#define MMCSD_R1_STS(r1)
Returns the status field of an R1 response.
Definition: hal_mmcsd.h:442
sdcmode_t cardmode
Various flags regarding the mounted card.
Definition: hal_sdc_lld.h:126
Definition: hal_sdc.c:464
sdcbusclk_t
Max supported clock.
Definition: hal_sdc.h:131
Definition: hal_sdc.c:896
Definition: hal_sdc.c:426
bool sdc_lld_write(SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
Definition: hal_sdc_lld.c:297
#define SDC_INIT_RETRY
Number of initialization attempts before rejecting the card.
Definition: hal_sdc.h:74
static uint16_t sdc_cmd6_extract_info(sd_switch_function_t function, const uint8_t *buf)
Definition: hal_sdc.c:271
bool sdcGetInfo(SDCDriver *sdcp, BlockDeviceInfo *bdip)
Definition: hal_sdc.c:927
bool sdc_lld_read(SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
Definition: hal_sdc_lld.c:272
static void osalSysLock(void)
Definition: osal.h:530
uint32_t sdcflags_t
SDC Driver condition flags type.
Definition: hal_sdc_lld.h:68
bool sdcWrite(SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
Definition: hal_sdc.c:842
sd_switch_t
SDC switch mode.
Definition: hal_sdc.c:48
Structure representing an SDC driver.
Definition: hal_sdc_lld.h:113
Definition: hal_sdc.c:407
uint32_t blk_size
Block size in bytes.
Definition: hal_ioblock.h:56
Definition: hal_sdc.c:573
#define MMCSD_CSD_MMC_CSD_STRUCTURE_SLICE
Slice position of values in CSD register.
Definition: hal_mmcsd.h:105
uint32_t _mmcsd_get_capacity(const uint32_t *csd)
Extract card capacity from a CSD.
Definition: hal_mmcsd.c:93
void sdc_lld_start_clk(SDCDriver *sdcp)
Starts the SDIO clock and sets it to init mode (400kHz or less).
Definition: hal_sdc_lld.c:107
Definition: hal_sdc.c:593
_mmcsd_block_device_data const SDCConfig * config
Current configuration data.
Definition: hal_sdc_lld.h:122
Detects card mode.
Definition: hal_sdc.c:100
OCR initialization constant for non-V20 cards.
Definition: hal_sdc.h:107
void sdc_lld_set_bus_mode(SDCDriver *sdcp, sdcbusmode_t mode)
Switches the bus to 4 bits mode.
Definition: hal_sdc_lld.c:146
void sdc_lld_stop(SDCDriver *sdcp)
Definition: hal_sdc_lld.c:93
static bool sdc_cmd6_check_status(sd_switch_function_t function, const uint8_t *buf)
Definition: hal_sdc.c:291
uint8_t * scratchpad
Working area for memory consuming operations.
Definition: hal_sdc_lld.h:87
Definition: hal_sdc_lld.h:79
#define MMCSD_R1_ERROR(r1)
Evaluates to true if the R1 response contains error flags.
Definition: hal_mmcsd.h:435
