SDC Driver
Generic SD Card Driver. More...
Collaboration diagram for SDC Driver:
This module implements a generic SDC (Secure Digital Card) driver.
Precondition
In order to use the SDC driver the HAL_USE_SDC option must be enabled in halconf.h.
Driver State Machine
This driver implements a state machine internally, see the Abstract I/O Block Device module documentation for details.
Driver Operations
This driver allows to read or write single or multiple 512 bytes blocks on a SD Card.
#define _sdc_driver_methods   _mmcsd_block_device_methods
 SDCDriver specific methods. More...
SD card types
#define SDC_MODE_CARDTYPE_MASK   0xFU
#define SDC_MODE_CARDTYPE_SDV11   0U
#define SDC_MODE_CARDTYPE_SDV20   1U
#define SDC_MODE_CARDTYPE_MMC   2U
#define SDC_MODE_HIGH_CAPACITY   0x10U
SDC bus error conditions
#define SDC_NO_ERROR   0U
#define SDC_CMD_CRC_ERROR   1U
#define SDC_DATA_CRC_ERROR   2U
#define SDC_DATA_TIMEOUT   4U
#define SDC_COMMAND_TIMEOUT   8U
#define SDC_TX_UNDERRUN   16U
#define SDC_RX_OVERRUN   32U
#define SDC_STARTBIT_ERROR   64U
#define SDC_OVERFLOW_ERROR   128U
#define SDC_UNHANDLED_ERROR   0xFFFFFFFFU
SDC configuration options
#define SDC_INIT_RETRY   100
 Number of initialization attempts before rejecting the card. More...
#define SDC_MMC_SUPPORT   FALSE
 Include support for MMC cards. More...
#define SDC_NICE_WAITING   TRUE
 Delays insertions. More...
#define SDC_INIT_OCR_V20   0x50FF8000U
 OCR initialization constant for V20 cards. More...
#define SDC_INIT_OCR   0x80100000U
 OCR initialization constant for non-V20 cards. More...
Macro Functions
#define sdcIsCardInserted(sdcp)   (sdc_lld_is_card_inserted(sdcp))
 Returns the card insertion status. More...
#define sdcIsWriteProtected(sdcp)   (sdc_lld_is_write_protected(sdcp))
 Returns the write protect status. More...
PLATFORM configuration options
#define PLATFORM_SDC_USE_SDC1   FALSE
 PWMD1 driver enable switch. More...
typedef uint32_t sdcmode_t
 Type of card flags. More...
typedef uint32_t sdcflags_t
 SDC Driver condition flags type. More...
typedef struct SDCDriver SDCDriver
 Type of a structure representing an SDC driver. More...
struct  SDCConfig
 Driver configuration structure. More...
struct  SDCDriverVMT
 SDCDriver virtual methods table. More...
struct  SDCDriver
 Structure representing an SDC driver. More...
static bool mode_detect (SDCDriver *sdcp)
 Detects card mode. More...
static bool mmc_init (SDCDriver *sdcp)
 Init procedure for MMC. More...
static bool sdc_init (SDCDriver *sdcp)
 Init procedure for SDC. More...
static uint32_t mmc_cmd6_construct (mmc_switch_t access, uint32_t idx, uint32_t value, uint32_t cmd_set)
 Constructs CMD6 argument for MMC. More...
static uint32_t sdc_cmd6_construct (sd_switch_t mode, sd_switch_function_t function, uint32_t value)
 Constructs CMD6 argument for SDC. More...
static uint16_t sdc_cmd6_extract_info (sd_switch_function_t function, const uint8_t *buf)
 Extracts information from CMD6 answer. More...
static bool sdc_cmd6_check_status (sd_switch_function_t function, const uint8_t *buf)
 Checks status after switching using CMD6. More...
static bool sdc_detect_bus_clk (SDCDriver *sdcp, sdcbusclk_t *clk)
 Reads supported bus clock and switch SDC to appropriate mode. More...
static bool mmc_detect_bus_clk (SDCDriver *sdcp, sdcbusclk_t *clk)
 Reads supported bus clock and switch MMC to appropriate mode. More...
static bool detect_bus_clk (SDCDriver *sdcp, sdcbusclk_t *clk)
 Reads supported bus clock and switch card to appropriate mode. More...
static bool sdc_set_bus_width (SDCDriver *sdcp)
 Sets bus width for SDC. More...
static bool mmc_set_bus_width (SDCDriver *sdcp)
 Sets bus width for MMC. More...
bool _sdc_wait_for_transfer_state (SDCDriver *sdcp)
 Wait for the card to complete pending operations. More...
void sdcInit (void)
 SDC Driver initialization. More...
void sdcObjectInit (SDCDriver *sdcp)
 Initializes the standard part of a SDCDriver structure. More...
void sdcStart (SDCDriver *sdcp, const SDCConfig *config)
 Configures and activates the SDC peripheral. More...
void sdcStop (SDCDriver *sdcp)
 Deactivates the SDC peripheral. More...
bool sdcConnect (SDCDriver *sdcp)
 Performs the initialization procedure on the inserted card. More...
bool sdcDisconnect (SDCDriver *sdcp)
 Brings the driver in a state safe for card removal. More...
bool sdcRead (SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
 Reads one or more blocks. More...
bool sdcWrite (SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
 Writes one or more blocks. More...
sdcflags_t sdcGetAndClearErrors (SDCDriver *sdcp)
 Returns the errors mask associated to the previous operation. More...
bool sdcSync (SDCDriver *sdcp)
 Waits for card idle condition. More...
bool sdcGetInfo (SDCDriver *sdcp, BlockDeviceInfo *bdip)
 Returns the media info. More...
bool sdcErase (SDCDriver *sdcp, uint32_t startblk, uint32_t endblk)
 Erases the supplied blocks. More...
void sdc_lld_init (void)
 Low level SDC driver initialization. More...
void sdc_lld_start (SDCDriver *sdcp)
void sdc_lld_stop (SDCDriver *sdcp)
void sdc_lld_start_clk (SDCDriver *sdcp)
 Starts the SDIO clock and sets it to init mode (400kHz or less). More...
void sdc_lld_set_data_clk (SDCDriver *sdcp, sdcbusclk_t clk)
 Sets the SDIO clock to data mode (25MHz or less). More...
void sdc_lld_stop_clk (SDCDriver *sdcp)
 Stops the SDIO clock. More...
void sdc_lld_set_bus_mode (SDCDriver *sdcp, sdcbusmode_t mode)
 Switches the bus to 4 bits mode. More...
void sdc_lld_send_cmd_none (SDCDriver *sdcp, uint8_t cmd, uint32_t arg)
 Sends an SDIO command with no response expected. More...
bool sdc_lld_send_cmd_short (SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
 Sends an SDIO command with a short response expected. More...
bool sdc_lld_send_cmd_short_crc (SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
 Sends an SDIO command with a short response expected and CRC. More...
bool sdc_lld_send_cmd_long_crc (SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
 Sends an SDIO command with a long response expected and CRC. More...
bool sdc_lld_read (SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
bool sdc_lld_write (SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
bool sdc_lld_sync (SDCDriver *sdcp)
Enumerations
Variables
static const struct SDCDriverVMT sdc_vmt
 Virtual methods table. More...
SDCDriver SDCD1
 SDCD1 driver identifier. More...
Attempts are performed at 10mS intervals.
Definition at line 74 of file hal_sdc.h.
Referenced by mmc_init(), and sdc_init().
MMC support is not yet implemented so this option must be kept at FALSE.
Definition at line 83 of file hal_sdc.h.
Delays insertions.
If enabled this options inserts delays into the MMC waiting routines releasing some extra CPU time for the threads with lower priority, this may slow down the driver a bit however.
Definition at line 93 of file hal_sdc.h.
Definition at line 100 of file hal_sdc.h.
Referenced by sdc_init().
Definition at line 107 of file hal_sdc.h.
#define sdcIsCardInserted (   sdcp)    (sdc_lld_is_card_inserted(sdcp))
This macro wraps a low level function named sdc_lld_is_card_inserted(), this function must be provided by the application because it is not part of the SDC driver.
Parameters
[in]sdcppointer to the SDCDriver object
Returns
The card state.
Return values
falsecard not inserted.
truecard inserted.
Definition at line 160 of file hal_sdc.h.
#define sdcIsWriteProtected (   sdcp)    (sdc_lld_is_write_protected(sdcp))
This macro wraps a low level function named sdc_lld_is_write_protected(), this function must be provided by the application because it is not part of the SDC driver.
Parameters
Returns
The card state.
Return values
falsenot write protected.
truewrite protected.
Definition at line 176 of file hal_sdc.h.
If set to TRUE the support for PWM1 is included.
The default is FALSE.
Definition at line 48 of file hal_sdc_lld.h.
Definition at line 98 of file hal_sdc_lld.h.
Typedef Documentation
Type of card flags.
Definition at line 63 of file hal_sdc_lld.h.
Definition at line 68 of file hal_sdc_lld.h.
Definition at line 73 of file hal_sdc_lld.h.
Enumeration Type Documentation
MMC switch mode.
Definition at line 38 of file hal_sdc.c.
SDC switch mode.
Definition at line 48 of file hal_sdc.c.
SDC switch function.
Definition at line 56 of file hal_sdc.c.
Type of SDIO bus mode.
Definition at line 122 of file hal_sdc.h.
Max supported clock.
Definition at line 131 of file hal_sdc.h.
Function Documentation
static bool mode_detect ( SDCDriver sdcp)
static
Detects card mode.
Parameters
Returns
The operation status.
Return values
HAL_SUCCESSoperation succeeded.
HAL_FAILEDoperation failed.
Function Class:Not an API, this function is for internal use only.
Definition at line 100 of file hal_sdc.c.
References SDCDriver::cardmode, MMCSD_CMD8_PATTERN, MMCSD_R1_ERROR, sdc_lld_send_cmd_none(), and sdc_lld_send_cmd_short_crc().
Referenced by sdcConnect().
static bool mmc_init ( SDCDriver sdcp)
static
Parameters
Returns
Return values
Definition at line 144 of file hal_sdc.c.
References SDCDriver::cardmode, osalThreadSleepMilliseconds, SDC_INIT_RETRY, and sdc_lld_send_cmd_short().
static bool sdc_init ( SDCDriver sdcp)
static
Parameters
Returns
Return values
Definition at line 181 of file hal_sdc.c.
References SDCDriver::cardmode, MMCSD_R1_ERROR, osalThreadSleepMilliseconds, SDC_INIT_OCR, SDC_INIT_OCR_V20, SDC_INIT_RETRY, sdc_lld_send_cmd_short(), and sdc_lld_send_cmd_short_crc().
static uint32_t mmc_cmd6_construct ( mmc_switch_t  access,
uint32_t  idx,
uint32_t  value,
uint32_t  cmd_set
static
Parameters
[in]accessEXT_CSD access mode
[in]idxEXT_CSD byte number
[in]valuevalue to be written in target field
[in]cmd_setswitch current command set
Returns
CMD6 argument.
Definition at line 229 of file hal_sdc.c.
References osalDbgAssert.
Referenced by mmc_detect_bus_clk(), and mmc_set_bus_width().
static uint32_t sdc_cmd6_construct ( sd_switch_t  mode,
uint32_t  value
static
Parameters
[in]modeswitch/test mode
[in]functionfunction number to be switched
[in]valuevalue to be written in target function
Returns
CMD6 argument.
Definition at line 249 of file hal_sdc.c.
Referenced by sdc_detect_bus_clk().
static uint16_t sdc_cmd6_extract_info ( sd_switch_function_t  function,
const uint8_t *  buf
static
Parameters
[in]bufbuffer with answer
Returns
extracted answer.
Definition at line 271 of file hal_sdc.c.
static bool sdc_cmd6_check_status ( sd_switch_function_t  function,
const uint8_t *  buf
static
Parameters
Returns
Return values
Definition at line 291 of file hal_sdc.c.
static bool sdc_detect_bus_clk ( SDCDriver sdcp,
sdcbusclk_t clk
static
Parameters
[out]clkpointer to clock enum
Returns
Return values
Definition at line 319 of file hal_sdc.c.
References _mmcsd_get_slice(), sdc_cmd6_check_status(), sdc_cmd6_construct(), and sdc_cmd6_extract_info().
Referenced by detect_bus_clk().
static bool mmc_detect_bus_clk ( SDCDriver sdcp,
sdcbusclk_t clk
static
Parameters
Returns
Return values
Definition at line 373 of file hal_sdc.c.
References SDCDriver::config, mmc_cmd6_construct(), MMCSD_R1_ERROR, SDCConfig::scratchpad, and sdc_lld_send_cmd_short_crc().
static bool detect_bus_clk ( SDCDriver sdcp,
sdcbusclk_t clk
static
Parameters
Returns
Return values
Definition at line 407 of file hal_sdc.c.
References SDCDriver::cardmode, mmc_detect_bus_clk(), and sdc_detect_bus_clk().
static bool sdc_set_bus_width ( SDCDriver sdcp)
static
Parameters
Returns
Return values
Definition at line 426 of file hal_sdc.c.
References SDCConfig::bus_width, SDCDriver::config, MMCSD_R1_ERROR, SDCDriver::rca, sdc_lld_send_cmd_short_crc(), and sdc_lld_set_bus_mode().
static bool mmc_set_bus_width ( SDCDriver sdcp)
static
Parameters
Returns
Return values
Definition at line 464 of file hal_sdc.c.
References SDCConfig::bus_width, SDCDriver::config, mmc_cmd6_construct(), MMCSD_R1_ERROR, osalDbgAssert, sdc_lld_send_cmd_short_crc(), and sdc_lld_set_bus_mode().
bool _sdc_wait_for_transfer_state ( SDCDriver sdcp)
Parameters
Returns
Return values
Definition at line 503 of file hal_sdc.c.
References MMCSD_R1_ERROR, MMCSD_R1_STS, osalThreadSleepMilliseconds, SDCDriver::rca, and sdc_lld_send_cmd_short_crc().
Referenced by sdcDisconnect(), and sdcErase().
void sdcInit ( void  )
This function is implicitly invoked by halInit(), there is no need to explicitly initialize the driver.
Definition at line 542 of file hal_sdc.c.
References sdc_lld_init().
Referenced by halInit().
void sdcObjectInit ( SDCDriver sdcp)
Parameters
[out]sdcppointer to the SDCDriver object
Definition at line 554 of file hal_sdc.c.
References BLK_STOP, SDCDriver::config, SDCDriver::errors, sdc_vmt, and SDCDriver::vmt.
Referenced by sdc_lld_init().
void sdcStart ( SDCDriver sdcp,
const SDCConfig config
Parameters
[in]configpointer to the SDCConfig object, can be NULL if the driver supports a default configuration or requires no configuration
Definition at line 573 of file hal_sdc.c.
References BLK_ACTIVE, BLK_STOP, SDCDriver::config, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and sdc_lld_start().
void sdcStop ( SDCDriver sdcp)
Parameters
Definition at line 593 of file hal_sdc.c.
References BLK_ACTIVE, BLK_STOP, SDCDriver::config, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and sdc_lld_stop().
bool sdcConnect ( SDCDriver sdcp)
This function should be invoked when a card is inserted and brings the driver in the BLK_READY state where it is possible to perform read and write operations.
Parameters
Returns
Return values
Definition at line 623 of file hal_sdc.c.
References _mmcsd_get_capacity(), _mmcsd_get_capacity_ext(), _mmcsd_get_slice(), BLK_ACTIVE, BLK_CONNECTING, BLK_READY, SDCDriver::cardmode, SDCDriver::config, detect_bus_clk(), mmc_init(), mmc_set_bus_width(), MMCSD_BLOCK_SIZE, MMCSD_CSD_MMC_CSD_STRUCTURE_SLICE, MMCSD_R1_ERROR, mode_detect(), osalDbgAssert, osalDbgCheck, SDCDriver::rca, SDCConfig::scratchpad, sdc_init(), sdc_lld_send_cmd_long_crc(), sdc_lld_send_cmd_none(), sdc_lld_send_cmd_short_crc(), sdc_lld_set_data_clk(), sdc_lld_start_clk(), sdc_lld_stop_clk(), and sdc_set_bus_width().
bool sdcDisconnect ( SDCDriver sdcp)
Parameters
Returns
Return values
Definition at line 762 of file hal_sdc.c.
References _sdc_wait_for_transfer_state(), BLK_ACTIVE, BLK_DISCONNECTING, BLK_READY, osalDbgAssert, osalDbgCheck, osalSysLock(), osalSysUnlock(), and sdc_lld_stop_clk().
bool sdcRead ( SDCDriver sdcp,
uint32_t  startblk,
uint8_t *  buf,
uint32_t  n
Precondition
The driver must be in the BLK_READY state after a successful sdcConnect() invocation.
Parameters
[in]startblkfirst block to read
[out]bufpointer to the read buffer
[in]nnumber of blocks to read
Returns
Return values
Definition at line 805 of file hal_sdc.c.
References BLK_READING, BLK_READY, SDCDriver::errors, osalDbgAssert, osalDbgCheck, and sdc_lld_read().
bool sdcWrite ( SDCDriver sdcp,
uint32_t  startblk,
const uint8_t *  buf,
uint32_t  n
Precondition
Parameters
[in]startblkfirst block to write
[out]bufpointer to the write buffer
[in]nnumber of blocks to write
Returns
Return values
Definition at line 842 of file hal_sdc.c.
References BLK_READY, BLK_WRITING, SDCDriver::errors, osalDbgAssert, osalDbgCheck, and sdc_lld_write().
sdcflags_t sdcGetAndClearErrors ( SDCDriver sdcp)
Parameters
Returns
The errors mask.
Definition at line 872 of file hal_sdc.c.
References BLK_READY, SDCDriver::errors, osalDbgAssert, osalDbgCheck, osalSysLock(), and osalSysUnlock().
bool sdcSync ( SDCDriver sdcp)
Parameters
Returns
Return values
HAL_SUCCESSthe operation succeeded.
HAL_FAILEDthe operation failed.
Definition at line 896 of file hal_sdc.c.
References BLK_READY, BLK_SYNCING, osalDbgCheck, and sdc_lld_sync().
bool sdcGetInfo ( SDCDriver sdcp,
BlockDeviceInfo bdip
Parameters
[out]bdippointer to a BlockDeviceInfo structure
Returns
Return values
Definition at line 927 of file hal_sdc.c.
References BlockDeviceInfo::blk_num, BLK_READY, BlockDeviceInfo::blk_size, MMCSD_BLOCK_SIZE, and osalDbgCheck.
bool sdcErase ( SDCDriver sdcp,
uint32_t  startblk,
uint32_t  endblk
Parameters
[in]startblkstarting block number
[in]endblkending block number
Returns
Return values
Definition at line 954 of file hal_sdc.c.
References _sdc_wait_for_transfer_state(), BLK_READY, BLK_WRITING, SDCDriver::cardmode, MMCSD_BLOCK_SIZE, MMCSD_R1_ERROR, osalDbgAssert, osalDbgCheck, and sdc_lld_send_cmd_short_crc().
void sdc_lld_init ( void  )
Definition at line 65 of file hal_sdc_lld.c.
References sdcObjectInit().
Referenced by sdcInit().
void sdc_lld_start ( SDCDriver sdcp)
Parameters
Definition at line 79 of file hal_sdc_lld.c.
References BLK_STOP.
Referenced by sdcStart().
void sdc_lld_stop ( SDCDriver sdcp)
Parameters
Definition at line 93 of file hal_sdc_lld.c.
Referenced by sdcStop().
void sdc_lld_start_clk ( SDCDriver sdcp)
Parameters
Definition at line 107 of file hal_sdc_lld.c.
void sdc_lld_set_data_clk ( SDCDriver sdcp,
sdcbusclk_t  clk
Parameters
[in]clkthe clock mode
Definition at line 120 of file hal_sdc_lld.c.
void sdc_lld_stop_clk ( SDCDriver sdcp)
Parameters
Definition at line 133 of file hal_sdc_lld.c.
Referenced by sdcConnect(), and sdcDisconnect().
void sdc_lld_set_bus_mode ( SDCDriver sdcp,
sdcbusmode_t  mode
Parameters
[in]modebus mode
Definition at line 146 of file hal_sdc_lld.c.
Referenced by mmc_set_bus_width(), and sdc_set_bus_width().
void sdc_lld_send_cmd_none ( SDCDriver sdcp,
uint8_t  cmd,
uint32_t  arg
Parameters
[in]cmdcard command
[in]argcommand argument
Definition at line 175 of file hal_sdc_lld.c.
Referenced by mode_detect(), and sdcConnect().
bool sdc_lld_send_cmd_short ( SDCDriver sdcp,
uint8_t  cmd,
uint32_t  arg,
uint32_t *  resp
The CRC is not verified.
Parameters
[in]cmdcard command
[out]resppointer to the response buffer (one word)
Returns
Return values
Definition at line 197 of file hal_sdc_lld.c.
bool sdc_lld_send_cmd_short_crc ( SDCDriver sdcp,
uint8_t  cmd,
uint32_t  arg,
uint32_t *  resp
Parameters
[in]cmdcard command
Returns
Return values
Definition at line 222 of file hal_sdc_lld.c.
Referenced by _sdc_wait_for_transfer_state(), mmc_detect_bus_clk(), mmc_set_bus_width(), mode_detect(), sdc_init(), sdc_set_bus_width(), sdcConnect(), and sdcErase().
bool sdc_lld_send_cmd_long_crc ( SDCDriver sdcp,
uint8_t  cmd,
uint32_t  arg,
uint32_t *  resp
Parameters
[in]cmdcard command
[out]resppointer to the response buffer (four words)
Returns
Return values
Definition at line 247 of file hal_sdc_lld.c.
bool sdc_lld_read ( SDCDriver sdcp,
uint32_t  startblk,
uint8_t *  buf,
uint32_t  n
Parameters
Returns
Return values
Definition at line 272 of file hal_sdc_lld.c.
Referenced by sdcRead().
bool sdc_lld_write ( SDCDriver sdcp,
uint32_t  startblk,
uint32_t  n
Parameters
Returns
Return values
Definition at line 297 of file hal_sdc_lld.c.
Referenced by sdcWrite().
bool sdc_lld_sync ( SDCDriver sdcp)
Parameters
Returns
Return values
Definition at line 319 of file hal_sdc_lld.c.
Referenced by sdcSync().
Variable Documentation
static
Initial value:
(size_t)0,
(bool (*)(void *))sdc_lld_is_card_inserted,
(bool (*)(void *))sdc_lld_is_write_protected,
(bool (*)(void *))sdcConnect,
(bool (*)(void *))sdcDisconnect,
(bool (*)(void *, uint32_t, uint8_t *, uint32_t))sdcRead,
(bool (*)(void *, uint32_t, const uint8_t *, uint32_t))sdcWrite,
(bool (*)(void *))sdcSync,
(bool (*)(void *, BlockDeviceInfo *))sdcGetInfo
bool sdcConnect(SDCDriver *sdcp)
Definition: hal_sdc.c:623
bool sdcDisconnect(SDCDriver *sdcp)
Definition: hal_sdc.c:762
bool sdcRead(SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
Definition: hal_sdc.c:805
Block device info.
Definition: hal_ioblock.h:55
bool sdcSync(SDCDriver *sdcp)
Definition: hal_sdc.c:896
bool sdcGetInfo(SDCDriver *sdcp, BlockDeviceInfo *bdip)
Definition: hal_sdc.c:927
bool sdcWrite(SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
Definition: hal_sdc.c:842
Definition at line 74 of file hal_sdc.c.
Referenced by sdcObjectInit().
SDCDriver SDCD1
Definition at line 41 of file hal_sdc_lld.c.
