hal_usb.c
18  * @file hal_usb.c
19  * @brief USB Driver code.
21  * @addtogroup USB
25 #include <string.h>
27 #include "hal.h"
29 #if (HAL_USE_USB == TRUE) || defined(__DOXYGEN__)
30
32 /* Driver local definitions. */
34
36 /* Driver exported variables. */
38
40 /* Driver local variables and types. */
42
43 static const uint8_t zero_status[] = {0x00, 0x00};
44 static const uint8_t active_status[] ={0x00, 0x00};
45 static const uint8_t halted_status[] = {0x01, 0x00};
46
48 /* Driver local functions. */
50
51 static uint16_t get_hword(uint8_t *p) {
52  uint16_t hw;
53
54  hw = (uint16_t)*p++;
55  hw |= (uint16_t)*p << 8U;
56  return hw;
57 }
58
59 /**
60  * @brief SET ADDRESS transaction callback.
61  *
62  * @param[in] usbp pointer to the @p USBDriver object
63  */
64 static void set_address(USBDriver *usbp) {
65
66  usbp->address = usbp->setup[2];
67  usb_lld_set_address(usbp);
69  usbp->state = USB_SELECTED;
70 }
71
72 /**
73  * @brief Standard requests handler.
74  * @details This is the standard requests default handler, most standard
75  * requests are handled here, the user can override the standard
76  * handling using the @p requests_hook_cb hook in the
77  * @p USBConfig structure.
78  *
79  * @param[in] usbp pointer to the @p USBDriver object
80  * @return The request handling exit code.
81  * @retval false Request not recognized by the handler or error.
82  * @retval true Request handled.
83  */
84 static bool default_handler(USBDriver *usbp) {
85  const USBDescriptor *dp;
86
87  /* Decoding the request.*/
88  switch ((((uint32_t)usbp->setup[0] & (USB_RTYPE_RECIPIENT_MASK |
89  USB_RTYPE_TYPE_MASK)) |
90  ((uint32_t)usbp->setup[1] << 8U))) {
91  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_STATUS << 8):
92  /* Just returns the current status word.*/
93  usbSetupTransfer(usbp, (uint8_t *)&usbp->status, 2, NULL);
94  return true;
95  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_CLEAR_FEATURE << 8):
96  /* Only the DEVICE_REMOTE_WAKEUP is handled here, any other feature
97  number is handled as an error.*/
98  if (usbp->setup[2] == USB_FEATURE_DEVICE_REMOTE_WAKEUP) {
99  usbp->status &= ~2U;
100  usbSetupTransfer(usbp, NULL, 0, NULL);
101  return true;
102  }
103  return false;
104  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_SET_FEATURE << 8):
105  /* Only the DEVICE_REMOTE_WAKEUP is handled here, any other feature
106  number is handled as an error.*/
107  if (usbp->setup[2] == USB_FEATURE_DEVICE_REMOTE_WAKEUP) {
108  usbp->status |= 2U;
109  usbSetupTransfer(usbp, NULL, 0, NULL);
110  return true;
111  }
112  return false;
113  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_SET_ADDRESS << 8):
114  /* The SET_ADDRESS handling can be performed here or postponed after
115  the status packed depending on the USB_SET_ADDRESS_MODE low
116  driver setting.*/
117 #if USB_SET_ADDRESS_MODE == USB_EARLY_SET_ADDRESS
118  if ((usbp->setup[0] == USB_RTYPE_RECIPIENT_DEVICE) &&
119  (usbp->setup[1] == USB_REQ_SET_ADDRESS)) {
120  set_address(usbp);
121  }
122  usbSetupTransfer(usbp, NULL, 0, NULL);
123 #else
124  usbSetupTransfer(usbp, NULL, 0, set_address);
125 #endif
126  return true;
127  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
128  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_GET_DESCRIPTOR << 8):
129  /* Handling descriptor requests from the host.*/
130  dp = usbp->config->get_descriptor_cb(usbp, usbp->setup[3],
131  usbp->setup[2],
132  get_hword(&usbp->setup[4]));
133  if (dp == NULL) {
134  return false;
135  }
136  /*lint -save -e9005 [11.8] Removing const is fine.*/
137  usbSetupTransfer(usbp, (uint8_t *)dp->ud_string, dp->ud_size, NULL);
138  /*lint -restore*/
139  return true;
140  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_GET_CONFIGURATION << 8):
141  /* Returning the last selected configuration.*/
142  usbSetupTransfer(usbp, &usbp->configuration, 1, NULL);
143  return true;
144  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_SET_CONFIGURATION << 8):
145 #if defined(USB_SET_CONFIGURATION_OLD_BEHAVIOR)
146  /* Handling configuration selection from the host only if it is different
147  from the current configuration.*/
148  if (usbp->configuration != usbp->setup[2])
149 #endif
150  {
151  /* If the USB device is already active then we have to perform the clear
152  procedure on the current configuration.*/
153  if (usbp->state == USB_ACTIVE) {
154  /* Current configuration cleared.*/
156  usbDisableEndpointsI(usbp);
158  usbp->configuration = 0U;
159  usbp->state = USB_SELECTED;
161  }
162  if (usbp->setup[2] != 0U) {
163  /* New configuration.*/
164  usbp->configuration = usbp->setup[2];
165  usbp->state = USB_ACTIVE;
167  }
168  }
169  usbSetupTransfer(usbp, NULL, 0, NULL);
170  return true;
171  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_GET_STATUS << 8):
172  case (uint32_t)USB_RTYPE_RECIPIENT_ENDPOINT | ((uint32_t)USB_REQ_SYNCH_FRAME << 8):
173  /* Just sending two zero bytes, the application can change the behavior
174  using a hook..*/
175  /*lint -save -e9005 [11.8] Removing const is fine.*/
176  usbSetupTransfer(usbp, (uint8_t *)zero_status, 2, NULL);
177  /*lint -restore*/
178  return true;
179  case (uint32_t)USB_RTYPE_RECIPIENT_ENDPOINT | ((uint32_t)USB_REQ_GET_STATUS << 8):
180  /* Sending the EP status.*/
181  if ((usbp->setup[4] & 0x80U) != 0U) {
182  switch (usb_lld_get_status_in(usbp, usbp->setup[4] & 0x0FU)) {
183  case EP_STATUS_STALLED:
184  /*lint -save -e9005 [11.8] Removing const is fine.*/
185  usbSetupTransfer(usbp, (uint8_t *)halted_status, 2, NULL);
186  /*lint -restore*/
187  return true;
188  case EP_STATUS_ACTIVE:
189  /*lint -save -e9005 [11.8] Removing const is fine.*/
190  usbSetupTransfer(usbp, (uint8_t *)active_status, 2, NULL);
191  /*lint -restore*/
192  return true;
193  case EP_STATUS_DISABLED:
194  default:
195  return false;
196  }
197  }
198  else {
199  switch (usb_lld_get_status_out(usbp, usbp->setup[4] & 0x0FU)) {
200  case EP_STATUS_STALLED:
201  /*lint -save -e9005 [11.8] Removing const is fine.*/
202  usbSetupTransfer(usbp, (uint8_t *)halted_status, 2, NULL);
203  /*lint -restore*/
204  return true;
205  case EP_STATUS_ACTIVE:
206  /*lint -save -e9005 [11.8] Removing const is fine.*/
207  usbSetupTransfer(usbp, (uint8_t *)active_status, 2, NULL);
208  /*lint -restore*/
209  return true;
210  case EP_STATUS_DISABLED:
211  default:
212  return false;
213  }
214  }
215  case (uint32_t)USB_RTYPE_RECIPIENT_ENDPOINT | ((uint32_t)USB_REQ_CLEAR_FEATURE << 8):
216  /* Only ENDPOINT_HALT is handled as feature.*/
217  if (usbp->setup[2] != USB_FEATURE_ENDPOINT_HALT) {
218  return false;
219  }
220  /* Clearing the EP status, not valid for EP0, it is ignored in that case.*/
221  if ((usbp->setup[4] & 0x0FU) != 0U) {
222  if ((usbp->setup[4] & 0x80U) != 0U) {
223  usb_lld_clear_in(usbp, usbp->setup[4] & 0x0FU);
224  }
225  else {
226  usb_lld_clear_out(usbp, usbp->setup[4] & 0x0FU);
227  }
228  }
229  usbSetupTransfer(usbp, NULL, 0, NULL);
230  return true;
231  case (uint32_t)USB_RTYPE_RECIPIENT_ENDPOINT | ((uint32_t)USB_REQ_SET_FEATURE << 8):
232  /* Only ENDPOINT_HALT is handled as feature.*/
233  if (usbp->setup[2] != USB_FEATURE_ENDPOINT_HALT) {
234  return false;
235  }
236  /* Stalling the EP, not valid for EP0, it is ignored in that case.*/
237  if ((usbp->setup[4] & 0x0FU) != 0U) {
238  if ((usbp->setup[4] & 0x80U) != 0U) {
239  usb_lld_stall_in(usbp, usbp->setup[4] & 0x0FU);
240  }
241  else {
242  usb_lld_stall_out(usbp, usbp->setup[4] & 0x0FU);
243  }
244  }
245  usbSetupTransfer(usbp, NULL, 0, NULL);
246  return true;
247  case (uint32_t)USB_RTYPE_RECIPIENT_DEVICE | ((uint32_t)USB_REQ_SET_DESCRIPTOR << 8):
248  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_CLEAR_FEATURE << 8):
249  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_SET_FEATURE << 8):
250  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_GET_INTERFACE << 8):
251  case (uint32_t)USB_RTYPE_RECIPIENT_INTERFACE | ((uint32_t)USB_REQ_SET_INTERFACE << 8):
252  /* All the above requests are not handled here, if you need them then
253  use the hook mechanism and provide handling.*/
254  default:
255  return false;
256  }
257 }
258
259 /*===========================================================================*/
260 /* Driver exported functions. */
261 /*===========================================================================*/
262
263 /**
264  * @brief USB Driver initialization.
265  * @note This function is implicitly invoked by @p halInit(), there is
266  * no need to explicitly initialize the driver.
267  *
268  * @init
269  */
270 void usbInit(void) {
271
272  usb_lld_init();
273 }
274
275 /**
276  * @brief Initializes the standard part of a @p USBDriver structure.
277  *
278  * @param[out] usbp pointer to the @p USBDriver object
279  *
280  * @init
281  */
283  unsigned i;
284
285  usbp->state = USB_STOP;
286  usbp->config = NULL;
287  for (i = 0; i < (unsigned)USB_MAX_ENDPOINTS; i++) {
288  usbp->in_params[i] = NULL;
289  usbp->out_params[i] = NULL;
290  }
291  usbp->transmitting = 0;
292  usbp->receiving = 0;
293 }
294
295 /**
296  * @brief Configures and activates the USB peripheral.
297  *
298  * @param[in] usbp pointer to the @p USBDriver object
299  * @param[in] config pointer to the @p USBConfig object
300  *
301  * @api
302  */
303 void usbStart(USBDriver *usbp, const USBConfig *config) {
304  unsigned i;
305
306  osalDbgCheck((usbp != NULL) && (config != NULL));
307
308  osalSysLock();
309  osalDbgAssert((usbp->state == USB_STOP) || (usbp->state == USB_READY),
310  "invalid state");
311  usbp->config = config;
312  for (i = 0; i <= (unsigned)USB_MAX_ENDPOINTS; i++) {
313  usbp->epc[i] = NULL;
314  }
315  usb_lld_start(usbp);
316  usbp->state = USB_READY;
317  osalSysUnlock();
318 }
319
320 /**
321  * @brief Deactivates the USB peripheral.
322  *
323  * @param[in] usbp pointer to the @p USBDriver object
324  *
325  * @api
326  */
327 void usbStop(USBDriver *usbp) {
328  unsigned i;
329
330  osalDbgCheck(usbp != NULL);
331
332  osalSysLock();
333
334  osalDbgAssert((usbp->state == USB_STOP) || (usbp->state == USB_READY) ||
335  (usbp->state == USB_SELECTED) || (usbp->state == USB_ACTIVE) ||
336  (usbp->state == USB_SUSPENDED),
337  "invalid state");
338
339  usb_lld_stop(usbp);
340  usbp->config = NULL;
341  usbp->state = USB_STOP;
342
343  /* Resetting all ongoing synchronous operations.*/
344  for (i = 0; i <= (unsigned)USB_MAX_ENDPOINTS; i++) {
345 #if USB_USE_WAIT == TRUE
346  if (usbp->epc[i] != NULL) {
347  if (usbp->epc[i]->in_state != NULL) {
349  }
350  if (usbp->epc[i]->out_state != NULL) {
352  }
353  }
354 #endif
355  usbp->epc[i] = NULL;
356  }
358
359  osalSysUnlock();
360 }
361
362 /**
363  * @brief Enables an endpoint.
364  * @details This function enables an endpoint, both IN and/or OUT directions
365  * depending on the configuration structure.
366  * @note This function must be invoked in response of a SET_CONFIGURATION
367  * or SET_INTERFACE message.
368  *
369  * @param[in] usbp pointer to the @p USBDriver object
370  * @param[in] ep endpoint number
371  * @param[in] epcp the endpoint configuration
372  *
373  * @iclass
374  */
376  const USBEndpointConfig *epcp) {
377
379  osalDbgCheck((usbp != NULL) && (epcp != NULL));
380  osalDbgAssert(usbp->state == USB_ACTIVE,
381  "invalid state");
382  osalDbgAssert(usbp->epc[ep] == NULL, "already initialized");
383
384  /* Logically enabling the endpoint in the USBDriver structure.*/
385  usbp->epc[ep] = epcp;
386
387  /* Clearing the state structures, custom fields as well.*/
388  if (epcp->in_state != NULL) {
389  memset(epcp->in_state, 0, sizeof(USBInEndpointState));
390  }
391  if (epcp->out_state != NULL) {
392  memset(epcp->out_state, 0, sizeof(USBOutEndpointState));
393  }
394
395  /* Low level endpoint activation.*/
396  usb_lld_init_endpoint(usbp, ep);
397 }
398
399 /**
400  * @brief Disables all the active endpoints.
401  * @details This function disables all the active endpoints except the
402  * endpoint zero.
403  * @note This function must be invoked in response of a SET_CONFIGURATION
404  * message with configuration number zero.
405  *
406  * @param[in] usbp pointer to the @p USBDriver object
407  *
408  * @iclass
409  */
411  unsigned i;
412
414  osalDbgCheck(usbp != NULL);
415  osalDbgAssert(usbp->state == USB_ACTIVE, "invalid state");
416
417  usbp->transmitting &= 1U;
418  usbp->receiving &= 1U;
419
420  for (i = 1; i <= (unsigned)USB_MAX_ENDPOINTS; i++) {
421 #if USB_USE_WAIT == TRUE
422  /* Signaling the event to threads waiting on endpoints.*/
423  if (usbp->epc[i] != NULL) {
424  if (usbp->epc[i]->in_state != NULL) {
426  }
427  if (usbp->epc[i]->out_state != NULL) {
429  }
430  }
431 #endif
432  usbp->epc[i] = NULL;
433  }
434
435  /* Low level endpoints deactivation.*/
437 }
438
439 /**
440  * @brief Starts a receive transaction on an OUT endpoint.
441  * @note This function is meant to be called from ISR context outside
442  * critical zones because there is a potentially slow operation
443  * inside.
444  *
445  * @param[in] usbp pointer to the @p USBDriver object
446  * @param[in] ep endpoint number
447  * @param[out] buf buffer where to copy the received data
448  * @param[in] n transaction size. It is recommended a multiple of
449  * the packet size because the excess is discarded.
450  *
451  * @iclass
452  */
454  uint8_t *buf, size_t n) {
455  USBOutEndpointState *osp;
456
458  osalDbgCheck((usbp != NULL) && (ep <= (usbep_t)USB_MAX_ENDPOINTS));
459  osalDbgAssert(!usbGetReceiveStatusI(usbp, ep), "already receiving");
460
461  /* Marking the endpoint as active.*/
462  usbp->receiving |= (uint16_t)((unsigned)1U << (unsigned)ep);
463
464  /* Setting up the transfer.*/
465  /*lint -save -e661 [18.1] pclint is confused by the check on ep.*/
466  osp = usbp->epc[ep]->out_state;
467  /*lint -restore*/
468  osp->rxbuf = buf;
469  osp->rxsize = n;
470  osp->rxcnt = 0;
471 #if USB_USE_WAIT == TRUE
472  osp->thread = NULL;
473 #endif
474
475  /* Starting transfer.*/
476  usb_lld_start_out(usbp, ep);
477 }
478
479 /**
480  * @brief Starts a transmit transaction on an IN endpoint.
481  * @note This function is meant to be called from ISR context outside
482  * critical zones because there is a potentially slow operation
483  * inside.
484  *
485  * @param[in] usbp pointer to the @p USBDriver object
486  * @param[in] ep endpoint number
487  * @param[in] buf buffer where to fetch the data to be transmitted
488  * @param[in] n transaction size
489  *
490  * @iclass
491  */
493  const uint8_t *buf, size_t n) {
494  USBInEndpointState *isp;
495
497  osalDbgCheck((usbp != NULL) && (ep <= (usbep_t)USB_MAX_ENDPOINTS));
498  osalDbgAssert(!usbGetTransmitStatusI(usbp, ep), "already transmitting");
499
500  /* Marking the endpoint as active.*/
501  usbp->transmitting |= (uint16_t)((unsigned)1U << (unsigned)ep);
502
503  /* Setting up the transfer.*/
504  /*lint -save -e661 [18.1] pclint is confused by the check on ep.*/
505  isp = usbp->epc[ep]->in_state;
506  /*lint -restore*/
507  isp->txbuf = buf;
508  isp->txsize = n;
509  isp->txcnt = 0;
510 #if USB_USE_WAIT == TRUE
511  isp->thread = NULL;
512 #endif
513
514  /* Starting transfer.*/
515  usb_lld_start_in(usbp, ep);
516 }
517
518 #if (USB_USE_WAIT == TRUE) || defined(__DOXYGEN__)
519 /**
520  * @brief Performs a receive transaction on an OUT endpoint.
521  *
522  * @param[in] usbp pointer to the @p USBDriver object
523  * @param[in] ep endpoint number
524  * @param[out] buf buffer where to copy the received data
525  * @param[in] n transaction size. It is recommended a multiple of
526  * the packet size because the excess is discarded.
527  *
528  * @return The received effective data size, it can be less than
529  * the amount specified.
530  * @retval MSG_RESET driver not in @p USB_ACTIVE state or the operation
531  * has been aborted by an USB reset or a transition to
532  * the @p USB_SUSPENDED state.
533  *
534  * @api
535  */
536 msg_t usbReceive(USBDriver *usbp, usbep_t ep, uint8_t *buf, size_t n) {
537  msg_t msg;
538
539  osalSysLock();
540
541  if (usbGetDriverStateI(usbp) != USB_ACTIVE) {
542  osalSysUnlock();
543  return MSG_RESET;
544  }
545
546  usbStartReceiveI(usbp, ep, buf, n);
547  msg = osalThreadSuspendS(&usbp->epc[ep]->out_state->thread);
548  osalSysUnlock();
549
550  return msg;
551 }
552
553 /**
554  * @brief Performs a transmit transaction on an IN endpoint.
555  *
556  * @param[in] usbp pointer to the @p USBDriver object
557  * @param[in] ep endpoint number
558  * @param[in] buf buffer where to fetch the data to be transmitted
559  * @param[in] n transaction size
560  *
561  * @return The operation status.
562  * @retval MSG_OK operation performed successfully.
563  * @retval MSG_RESET driver not in @p USB_ACTIVE state or the operation
564  * has been aborted by an USB reset or a transition to
565  * the @p USB_SUSPENDED state.
566  *
567  * @api
568  */
569 msg_t usbTransmit(USBDriver *usbp, usbep_t ep, const uint8_t *buf, size_t n) {
570  msg_t msg;
571
572  osalSysLock();
573
574  if (usbGetDriverStateI(usbp) != USB_ACTIVE) {
575  osalSysUnlock();
576  return MSG_RESET;
577  }
578
579  usbStartTransmitI(usbp, ep, buf, n);
580  msg = osalThreadSuspendS(&usbp->epc[ep]->in_state->thread);
581  osalSysUnlock();
582
583  return msg;
584 }
585 #endif /* USB_USE_WAIT == TRUE */
586
587 /**
588  * @brief Stalls an OUT endpoint.
589  *
590  * @param[in] usbp pointer to the @p USBDriver object
591  * @param[in] ep endpoint number
592  *
593  * @return The operation status.
594  * @retval false Endpoint stalled.
595  * @retval true Endpoint busy, not stalled.
596  *
597  * @iclass
598  */
600
602  osalDbgCheck(usbp != NULL);
603
604  if (usbGetReceiveStatusI(usbp, ep)) {
605  return true;
606  }
607
608  usb_lld_stall_out(usbp, ep);
609  return false;
610 }
611
612 /**
613  * @brief Stalls an IN endpoint.
614  *
615  * @param[in] usbp pointer to the @p USBDriver object
616  * @param[in] ep endpoint number
617  *
618  * @return The operation status.
619  * @retval false Endpoint stalled.
620  * @retval true Endpoint busy, not stalled.
621  *
622  * @iclass
623  */
625
627  osalDbgCheck(usbp != NULL);
628
629  if (usbGetTransmitStatusI(usbp, ep)) {
630  return true;
631  }
632
633  usb_lld_stall_in(usbp, ep);
634  return false;
635 }
636
637 /**
638  * @brief Host wake-up procedure.
639  * @note It is silently ignored if the USB device is not in the
640  * @p USB_SUSPENDED state.
641  *
642  * @param[in] usbp pointer to the @p USBDriver object
643  *
644  * @api
645  */
647
648  if (usbp->state == USB_SUSPENDED) {
649  /* Starting host wakeup procedure.*/
650  usb_lld_wakeup_host(usbp);
651  }
652 }
653
654 /**
655  * @brief USB reset routine.
656  * @details This function must be invoked when an USB bus reset condition is
657  * detected.
658  *
659  * @param[in] usbp pointer to the @p USBDriver object
660  *
661  * @notapi
662  */
663 void _usb_reset(USBDriver *usbp) {
664  unsigned i;
665
666  /* State transition.*/
667  usbp->state = USB_READY;
668
669  /* Resetting internal state.*/
670  usbp->status = 0;
671  usbp->address = 0;
672  usbp->configuration = 0;
673  usbp->transmitting = 0;
674  usbp->receiving = 0;
675
676  /* Invalidates all endpoints into the USBDriver structure.*/
677  for (i = 0; i <= (unsigned)USB_MAX_ENDPOINTS; i++) {
678 #if USB_USE_WAIT == TRUE
679  /* Signaling the event to threads waiting on endpoints.*/
680  if (usbp->epc[i] != NULL) {
682  if (usbp->epc[i]->in_state != NULL) {
684  }
685  if (usbp->epc[i]->out_state != NULL) {
687  }
689  }
690 #endif
691  usbp->epc[i] = NULL;
692  }
693
694  /* EP0 state machine initialization.*/
696
697  /* Low level reset.*/
698  usb_lld_reset(usbp);
699
700  /* Notification of reset event.*/
702 }
703
704 /**
705  * @brief USB suspend routine.
706  * @details This function must be invoked when an USB bus suspend condition is
707  * detected.
708  *
709  * @param[in] usbp pointer to the @p USBDriver object
710  *
711  * @notapi
712  */
713 void _usb_suspend(USBDriver *usbp) {
714  /* No state change, suspend always returns to previous state. */
715
716  /* State transition.*/
717  usbp->saved_state = usbp->state;
718  usbp->state = USB_SUSPENDED;
719
720  /* Notification of suspend event.*/
722
723  /* Signaling the event to threads waiting on endpoints.*/
724 #if USB_USE_WAIT == TRUE
725  {
726  unsigned i;
727
728  for (i = 0; i <= (unsigned)USB_MAX_ENDPOINTS; i++) {
729  if (usbp->epc[i] != NULL) {
731  if (usbp->epc[i]->in_state != NULL) {
733  }
734  if (usbp->epc[i]->out_state != NULL) {
736  }
738  }
739  }
740  }
741 #endif
742 }
743
744 /**
745  * @brief USB wake-up routine.
746  * @details This function must be invoked when an USB bus wake-up condition is
747  * detected.
748  *
749  * @param[in] usbp pointer to the @p USBDriver object
750  *
751  * @notapi
752  */
753 void _usb_wakeup(USBDriver *usbp) {
754
755  /* State transition, returning to the previous state.*/
756  usbp->state = usbp->saved_state;
757
758  /* Notification of suspend event.*/
760 }
761
762 /**
763  * @brief Default EP0 SETUP callback.
764  * @details This function is used by the low level driver as default handler
765  * for EP0 SETUP events.
766  *
767  * @param[in] usbp pointer to the @p USBDriver object
768  * @param[in] ep endpoint number, always zero
769  *
770  * @notapi
771  */
772 void _usb_ep0setup(USBDriver *usbp, usbep_t ep) {
773  size_t max;
774
775  /* Is the EP0 state machine in the correct state for handling setup
776  packets?*/
777  if (usbp->ep0state != USB_EP0_STP_WAITING) {
778  /* This is unexpected could require handling with a warning event.*/
779  /* TODO: handling here.*/
780
781  /* Resetting the EP0 state machine and going ahead.*/
783  }
784
785  /* Reading the setup data into the driver buffer.*/
786  usbReadSetup(usbp, ep, usbp->setup);
787
788  /* First verify if the application has an handler installed for this
789  request.*/
790  /*lint -save -e9007 [13.5] No side effects, it is intentional.*/
791  if ((usbp->config->requests_hook_cb == NULL) ||
792  !(usbp->config->requests_hook_cb(usbp))) {
793  /*lint -restore*/
794  /* Invoking the default handler, if this fails then stalls the
795  endpoint zero as error.*/
796  /*lint -save -e9007 [13.5] No side effects, it is intentional.*/
797  if (((usbp->setup[0] & USB_RTYPE_TYPE_MASK) != USB_RTYPE_TYPE_STD) ||
798  !default_handler(usbp)) {
799  /*lint -restore*/
800  /* Error response, the state machine goes into an error state, the low
801  level layer will have to reset it to USB_EP0_WAITING_SETUP after
802  receiving a SETUP packet.*/
803  usb_lld_stall_in(usbp, 0);
804  usb_lld_stall_out(usbp, 0);
806  usbp->ep0state = USB_EP0_ERROR;
807  return;
808  }
809  }
810 #if (USB_SET_ADDRESS_ACK_HANDLING == USB_SET_ADDRESS_ACK_HW)
811  if (usbp->setup[1] == USB_REQ_SET_ADDRESS) {
812  /* Zero-length packet sent by hardware */
813  return;
814  }
815 #endif
816  /* Transfer preparation. The request handler must have populated
817  correctly the fields ep0next, ep0n and ep0endcb using the macro
818  usbSetupTransfer().*/
819  max = (size_t)get_hword(&usbp->setup[6]);
820  /* The transfer size cannot exceed the specified amount.*/
821  if (usbp->ep0n > max) {
822  usbp->ep0n = max;
823  }
824  if ((usbp->setup[0] & USB_RTYPE_DIR_MASK) == USB_RTYPE_DIR_DEV2HOST) {
825  /* IN phase.*/
826  if (usbp->ep0n != 0U) {
827  /* Starts the transmit phase.*/
828  usbp->ep0state = USB_EP0_IN_TX;
830  usbStartTransmitI(usbp, 0, usbp->ep0next, usbp->ep0n);
832  }
833  else {
834  /* No transmission phase, directly receiving the zero sized status
835  packet.*/
837 #if (USB_EP0_STATUS_STAGE == USB_EP0_STATUS_STAGE_SW)
839  usbStartReceiveI(usbp, 0, NULL, 0);
841 #else
842  usb_lld_end_setup(usbp, ep);
843 #endif
844  }
845  }
846  else {
847  /* OUT phase.*/
848  if (usbp->ep0n != 0U) {
849  /* Starts the receive phase.*/
850  usbp->ep0state = USB_EP0_OUT_RX;
852  usbStartReceiveI(usbp, 0, (uint8_t *)usbp->ep0next, usbp->ep0n);
854  }
855  else {
856  /* No receive phase, directly sending the zero sized status
857  packet.*/
859 #if (USB_EP0_STATUS_STAGE == USB_EP0_STATUS_STAGE_SW)
861  usbStartTransmitI(usbp, 0, NULL, 0);
863 #else
864  usb_lld_end_setup(usbp, ep);
865 #endif
866  }
867  }
868 }
869
870 /**
871  * @brief Default EP0 IN callback.
872  * @details This function is used by the low level driver as default handler
873  * for EP0 IN events.
874  *
875  * @param[in] usbp pointer to the @p USBDriver object
876  * @param[in] ep endpoint number, always zero
877  *
878  * @notapi
879  */
880 void _usb_ep0in(USBDriver *usbp, usbep_t ep) {
881  size_t max;
882
883  (void)ep;
884  switch (usbp->ep0state) {
885  case USB_EP0_IN_TX:
886  max = (size_t)get_hword(&usbp->setup[6]);
887  /* If the transmitted size is less than the requested size and it is a
888  multiple of the maximum packet size then a zero size packet must be
889  transmitted.*/
890  if ((usbp->ep0n < max) &&
891  ((usbp->ep0n % usbp->epc[0]->in_maxsize) == 0U)) {
893  usbStartTransmitI(usbp, 0, NULL, 0);
896  return;
897  }
898  /* Falls through.*/
900  /* Transmit phase over, receiving the zero sized status packet.*/
902 #if (USB_EP0_STATUS_STAGE == USB_EP0_STATUS_STAGE_SW)
904  usbStartReceiveI(usbp, 0, NULL, 0);
906 #else
907  usb_lld_end_setup(usbp, ep);
908 #endif
909  return;
911  /* Status packet sent, invoking the callback if defined.*/
912  if (usbp->ep0endcb != NULL) {
913  usbp->ep0endcb(usbp);
914  }
916  return;
917  case USB_EP0_STP_WAITING:
919  case USB_EP0_OUT_RX:
920  /* All the above are invalid states in the IN phase.*/
921  osalDbgAssert(false, "EP0 state machine error");
922  /* Falls through.*/
923  case USB_EP0_ERROR:
924  /* Error response, the state machine goes into an error state, the low
925  level layer will have to reset it to USB_EP0_WAITING_SETUP after
926  receiving a SETUP packet.*/
927  usb_lld_stall_in(usbp, 0);
928  usb_lld_stall_out(usbp, 0);
930  usbp->ep0state = USB_EP0_ERROR;
931  return;
932  default:
933  osalDbgAssert(false, "EP0 state machine invalid state");
934  }
935 }
936
937 /**
938  * @brief Default EP0 OUT callback.
939  * @details This function is used by the low level driver as default handler
940  * for EP0 OUT events.
941  *
942  * @param[in] usbp pointer to the @p USBDriver object
943  * @param[in] ep endpoint number, always zero
944  *
945  * @notapi
946  */
947 void _usb_ep0out(USBDriver *usbp, usbep_t ep) {
948
949  (void)ep;
950  switch (usbp->ep0state) {
951  case USB_EP0_OUT_RX:
952  /* Receive phase over, sending the zero sized status packet.*/
954 #if (USB_EP0_STATUS_STAGE == USB_EP0_STATUS_STAGE_SW)
956  usbStartTransmitI(usbp, 0, NULL, 0);
958 #else
959  usb_lld_end_setup(usbp, ep);
960 #endif
961  return;
963  /* Status packet received, it must be zero sized, invoking the callback
964  if defined.*/
965 #if (USB_EP0_STATUS_STAGE == USB_EP0_STATUS_STAGE_SW)
966  if (usbGetReceiveTransactionSizeX(usbp, 0) != 0U) {
967  break;
968  }
969 #endif
970  if (usbp->ep0endcb != NULL) {
971  usbp->ep0endcb(usbp);
972  }
974  return;
975  case USB_EP0_STP_WAITING:
976  case USB_EP0_IN_TX:
979  /* All the above are invalid states in the IN phase.*/
980  osalDbgAssert(false, "EP0 state machine error");
981  /* Falls through.*/
982  case USB_EP0_ERROR:
983  /* Error response, the state machine goes into an error state, the low
984  level layer will have to reset it to USB_EP0_WAITING_SETUP after
985  receiving a SETUP packet.*/
986  usb_lld_stall_in(usbp, 0);
987  usb_lld_stall_out(usbp, 0);
989  usbp->ep0state = USB_EP0_ERROR;
990  return;
991  default:
992  osalDbgAssert(false, "EP0 state machine invalid state");
993  }
994 }
995
996 #endif /* HAL_USE_USB == TRUE */
997
998 /** @} */
USBOutEndpointState * out_state
USBEndpointState associated to the OUT endpoint.
Definition: hal_usb_lld.h:183
Definition: hal_usb.c:64
uint16_t in_maxsize
IN endpoint maximum packet size.
Definition: hal_usb_lld.h:167
void usbDisableEndpointsI(USBDriver *usbp)
Definition: hal_usb.c:410
Definition: hal_usb.c:713
Definition: hal_usb.c:772
Type of an OUT endpoint state structure.
Definition: hal_usb_lld.h:108
msg_t osalThreadSuspendS(thread_reference_t *trp)
Sends the current thread sleeping and sets a reference variable.
Definition: osal.c:185
void usbWakeupHost(USBDriver *usbp)
Definition: hal_usb.c:646
void usb_lld_init(void)
Low level USB driver initialization.
Definition: hal_usb_lld.c:99
usbstate_t state
Definition: hal_usb_lld.h:221
size_t rxcnt
Received bytes so far.
Definition: hal_usb_lld.h:116
const USBEndpointConfig * epc[USB_MAX_ENDPOINTS+1]
Active endpoints configurations.
Definition: hal_usb_lld.h:237
uint8_t setup[8]
Setup packet buffer.
Definition: hal_usb_lld.h:271
void usb_lld_init_endpoint(USBDriver *usbp, usbep_t ep)
Definition: hal_usb_lld.c:186
void usb_lld_clear_out(USBDriver *usbp, usbep_t ep)
Brings an OUT endpoint in the active state.
Definition: hal_usb_lld.c:366
size_t txsize
Requested transmit transfer size.
Definition: hal_usb_lld.h:87
#define usb_lld_wakeup_host(usbp)
Start of host wake-up procedure.
Definition: hal_usb_lld.h:344
size_t ud_size
Descriptor size in unicode characters.
Definition: hal_usb.h:320
void usb_lld_clear_in(USBDriver *usbp, usbep_t ep)
Brings an IN endpoint in the active state.
Definition: hal_usb_lld.c:381
#define usbGetReceiveStatusI(usbp, ep)
Returns the status of an OUT endpoint.
Definition: hal_usb.h:446
void usb_lld_start(USBDriver *usbp)
Definition: hal_usb_lld.c:114
#define osalDbgCheckClassI()
I-Class state check.
Definition: osal.h:292
void usb_lld_disable_endpoints(USBDriver *usbp)
Disables all the active endpoints except the endpoint zero.
Definition: hal_usb_lld.c:200
void usb_lld_start_out(USBDriver *usbp, usbep_t ep)
Starts a receive operation on an OUT endpoint.
Definition: hal_usb_lld.c:306
static void osalSysLockFromISR(void)
Enters a critical zone from ISR context.
Definition: osal.h:550
Definition: osal.h:540
void usb_lld_stall_in(USBDriver *usbp, usbep_t ep)
Brings an IN endpoint in the stalled state.
Definition: hal_usb_lld.c:351
void osalOsRescheduleS(void)
Checks if a reschedule is required and performs it.
Definition: osal.c:119
uint8_t configuration
Current USB device configuration.
Definition: hal_usb_lld.h:283
void usb_lld_start_in(USBDriver *usbp, usbep_t ep)
Starts a transmit operation on an IN endpoint.
Definition: hal_usb_lld.c:321
const USBConfig * config
Current configuration data.
Definition: hal_usb_lld.h:225
Structure representing an USB driver.
Definition: hal_usb_lld.h:217
uint8_t address
Assigned USB address.
Definition: hal_usb_lld.h:279
void * out_params[USB_MAX_ENDPOINTS]
Fields available to user, it can be used to associate an application-defined handler to an OUT endpoi...
Definition: hal_usb_lld.h:251
size_t ep0n
Number of bytes yet to be transferred through endpoint 0.
Definition: hal_usb_lld.h:263
void usb_lld_stall_out(USBDriver *usbp, usbep_t ep)
Brings an OUT endpoint in the stalled state.
Definition: hal_usb_lld.c:336
uint16_t receiving
Bit map of the receiving OUT endpoints.
Definition: hal_usb_lld.h:233
#define usbGetDriverStateI(usbp)
Returns the driver state.
Definition: hal_usb.h:391
Definition: hal_usb.c:569
thread_reference_t thread
Waiting thread.
Definition: hal_usb_lld.h:100
const uint8_t * txbuf
Pointer to the transmission linear buffer.
Definition: hal_usb_lld.h:95
#define usbGetTransmitStatusI(usbp, ep)
Returns the status of an IN endpoint.
Definition: hal_usb.h:432
void usbInit(void)
Definition: hal_usb.c:270
usbreqhandler_t requests_hook_cb
Requests hook callback.
Definition: hal_usb_lld.h:206
uint8_t * rxbuf
Pointer to the receive linear buffer.
Definition: hal_usb_lld.h:120
void usbStartReceiveI(USBDriver *usbp, usbep_t ep, uint8_t *buf, size_t n)
Definition: hal_usb.c:453
#define _usb_isr_invoke_event_cb(usbp, evt)
Common ISR code, usb event callback.
Definition: hal_usb.h:511
Definition: hal_usb.c:880
size_t txcnt
Transmitted bytes so far.
Definition: hal_usb_lld.h:91
Definition: hal_usb.c:753
void usb_lld_reset(USBDriver *usbp)
USB low level reset routine.
Definition: hal_usb_lld.c:156
size_t rxsize
Requested receive transfer size.
Definition: hal_usb_lld.h:112
static void osalSysUnlockFromISR(void)
Leaves a critical zone from ISR context.
Definition: osal.h:560
Definition: hal_usb.c:947
uint16_t transmitting
Bit map of the transmitting IN endpoints.
Definition: hal_usb_lld.h:229
Definition: hal_usb.c:327
const uint8_t * ud_string
Pointer to the descriptor.
Definition: hal_usb.h:324
bool usbStallTransmitI(USBDriver *usbp, usbep_t ep)
Definition: hal_usb.c:624
void usbInitEndpointI(USBDriver *usbp, usbep_t ep, const USBEndpointConfig *epcp)
Definition: hal_usb.c:375
usbepstatus_t usb_lld_get_status_out(USBDriver *usbp, usbep_t ep)
Definition: hal_usb_lld.c:218
void * in_params[USB_MAX_ENDPOINTS]
Fields available to user, it can be used to associate an application-defined handler to an IN endpoin...
Definition: hal_usb_lld.h:244
uint16_t status
Current USB device status.
Definition: hal_usb_lld.h:275
#define usbReadSetup(usbp, ep, buf)
Reads a setup packet from the dedicated packet buffer.
Definition: hal_usb.h:496
USB reset routine.
Definition: hal_usb.c:663
Definition: hal_usb.c:303
Type of an IN endpoint state structure.
Definition: hal_usb_lld.h:83
static void osalSysLock(void)
Definition: osal.h:530
Definition: hal_usb.c:84
uint8_t * ep0next
Next position in the buffer to be transferred through endpoint 0.
Definition: hal_usb_lld.h:259
usbgetdescriptor_t get_descriptor_cb
Device GET_DESCRIPTOR request callback.
Definition: hal_usb_lld.h:200
usbcallback_t ep0endcb
Endpoint 0 end transaction callback.
Definition: hal_usb_lld.h:267
usbepstatus_t usb_lld_get_status_in(USBDriver *usbp, usbep_t ep)
Definition: hal_usb_lld.c:238
bool usbStallReceiveI(USBDriver *usbp, usbep_t ep)
Definition: hal_usb.c:599
Type of an USB descriptor.
Definition: hal_usb.h:316
uint8_t usbep_t
Type of an endpoint identifier.
Definition: hal_usb.h:264
Type of an USB driver configuration structure.
Definition: hal_usb_lld.h:190
void osalThreadResumeI(thread_reference_t *trp, msg_t msg)
Wakes up a thread waiting on a thread reference object.
Definition: osal.c:230
void usbStartTransmitI(USBDriver *usbp, usbep_t ep, const uint8_t *buf, size_t n)
Definition: hal_usb.c:492
void usb_lld_stop(USBDriver *usbp)
Definition: hal_usb_lld.c:135
Definition: hal_usb.c:536
Type of an USB endpoint configuration structure.
Definition: hal_usb_lld.h:134
void usbObjectInit(USBDriver *usbp)
Initializes the standard part of a USBDriver structure.
Definition: hal_usb.c:282
#define usbSetupTransfer(usbp, buf, n, endcb)
Request transfer setup.
Definition: hal_usb.h:476
usbstate_t saved_state
State of the driver when a suspend happened.
Definition: hal_usb_lld.h:287
USBInEndpointState * in_state
USBEndpointState associated to the IN endpoint.
Definition: hal_usb_lld.h:178
int32_t msg_t
Definition: chtypes.h:51
#define MSG_RESET
Definition: chschd.h:43
Waiting thread.
Definition: hal_usb_lld.h:125
void usb_lld_set_address(USBDriver *usbp)
Sets the USB address.
Definition: hal_usb_lld.c:172
usbep0state_t ep0state
Endpoint 0 state.
Definition: hal_usb_lld.h:255
#define usbGetReceiveTransactionSizeX(usbp, ep)
Returns the exact size of a receive transaction.
Definition: hal_usb.h:461
#define USB_MAX_ENDPOINTS
Maximum endpoint address.
Definition: hal_usb_lld.h:37
