lps25h.c
2  ChibiOS - Copyright (C) 2016..2018 Rocco Marco Guglielmi
18
19 */
20
21 /**
22  * @file lps25h.c
23  * @brief LPS25H MEMS interface module code.
24  *
25  * @addtogroup LPS25H
26  * @ingroup EX_ST
27  * @{
28  */
30 #include "hal.h"
31 #include "lps25h.h"
34 /* Driver local definitions. */
38 /* Driver exported variables. */
42 /* Driver local variables and types. */
46 /* Driver local functions. */
49 #if (LPS25H_USE_I2C) || defined(__DOXYGEN__)
50 /**
51  * @brief Reads registers value using I2C.
52  * @pre The I2C interface must be initialized and the driver started.
53  *
54  * @param[in] i2cp pointer to the I2C interface
55  * @param[in] sad slave address without R bit
56  * @param[in] reg first sub-register address
57  * @param[out] rxbuf pointer to an output buffer
58  * @param[in] n number of consecutive register to read
59  * @return the operation status.
60  *
61  * @notapi
62  */
64  uint8_t reg, uint8_t* rxbuf, size_t n) {
65  uint8_t txbuf = reg;
66  if(n > 1)
67  txbuf |= LPS25H_SUB_MS;
68
69  return i2cMasterTransmitTimeout(i2cp, sad, &txbuf, 1, rxbuf, n,
71 }
72
73 /**
74  * @brief Writes a value into a register using I2C.
75  * @pre The I2C interface must be initialized and the driver started.
76  *
77  * @param[in] i2cp pointer to the I2C interface
78  * @param[in] sad slave address without R bit
79  * @param[in] txbuf buffer containing sub-address value in first position
80  * and values to write
81  * @param[in] n size of txbuf less one (not considering the first
82  * element)
83  * @return the operation status.
84  *
85  * @notapi
86  */
88  uint8_t* txbuf, size_t n) {
89  if (n > 1)
90  (*txbuf) |= LPS25H_SUB_MS;
91  return i2cMasterTransmitTimeout(i2cp, sad, txbuf, n + 1, NULL, 0,
93 }
94 #endif /* LPS25H_USE_I2C */
95
96 /**
97  * @brief Return the number of axes of the BaseBarometer.
98  *
99  * @param[in] ip pointer to @p BaseBarometer interface.
100  *
101  * @return the number of axes.
102  */
103 static size_t baro_get_axes_number(void *ip) {
104  (void)ip;
105
107 }
108
109 /**
110  * @brief Retrieves raw data from the BaseBarometer.
111  * @note This data is retrieved from MEMS register without any algebraical
112  * manipulation.
113  * @note The axes array must be at least the same size of the
114  * BaseBarometer axes number.
115  *
116  * @param[in] ip pointer to @p BaseBarometer interface.
117  * @param[out] axes a buffer which would be filled with raw data.
118  *
119  * @return The operation status.
120  * @retval MSG_OK if the function succeeded.
121  * @retval MSG_RESET if one or more I2C errors occurred, the errors can
122  * be retrieved using @p i2cGetErrors().
123  * @retval MSG_TIMEOUT if a timeout occurred before operation end.
124  */
125 static msg_t baro_read_raw(void *ip, int32_t axes[]) {
126  LPS25HDriver* devp;
127  uint8_t buff[3];
128  msg_t msg;
129
130  osalDbgCheck((ip != NULL) && (axes != NULL));
131
132  /* Getting parent instance pointer.*/
134
135  osalDbgAssert((devp->state == LPS25H_READY),
136  "baro_read_raw(), invalid state");
137
138  osalDbgAssert((devp->config->i2cp->state == I2C_READY),
139  "baro_read_raw(), channel not ready");
140
141 #if LPS25H_SHARED_I2C
142  i2cAcquireBus(devp->config->i2cp);
143  i2cStart(devp->config->i2cp,
144  devp->config->i2ccfg);
145 #endif /* LPS25H_SHARED_I2C */
146
147  msg = lps25hI2CReadRegister(devp->config->i2cp, devp->config->slaveaddress,
148  LPS25H_AD_PRESS_OUT_XL, buff, 3);
149
150 #if LPS25H_SHARED_I2C
151  i2cReleaseBus(devp->config->i2cp);
152 #endif /* LPS25H_SHARED_I2C */
153
154  if(msg == MSG_OK) {
155  *axes = buff[0] + (buff[1] << 8) + (buff[2] << 16);
156  }
157  return msg;
158 }
159
160 /**
161  * @brief Retrieves cooked data from the BaseBarometer.
162  * @note This data is manipulated according to the formula
163  * cooked = (raw * sensitivity) - bias.
164  * @note Final data is expressed as hPa.
165  * @note The axes array must be at least the same size of the
166  * BaseBarometer axes number.
167  *
168  * @param[in] ip pointer to @p BaseBarometer interface.
169  * @param[out] axes a buffer which would be filled with cooked data.
170  *
171  * @return The operation status.
172  * @retval MSG_OK if the function succeeded.
173  * @retval MSG_RESET if one or more I2C errors occurred, the errors can
174  * be retrieved using @p i2cGetErrors().
175  * @retval MSG_TIMEOUT if a timeout occurred before operation end.
176  */
177 static msg_t baro_read_cooked(void *ip, float axes[]) {
178  LPS25HDriver* devp;
179  int32_t raw;
180  msg_t msg;
181
182  osalDbgCheck((ip != NULL) && (axes != NULL));
183
184  /* Getting parent instance pointer.*/
186
187  osalDbgAssert((devp->state == LPS25H_READY),
188  "baro_read_cooked(), invalid state");
189
190  msg = baro_read_raw(ip, &raw);
191
192  *axes = (raw * devp->barosensitivity) - devp->barobias;
193
194  return msg;
195 }
196
197 /**
198  * @brief Set bias values for the BaseBarometer.
199  * @note Bias must be expressed as hPa.
200  * @note The bias buffer must be at least the same size of the
201  * BaseBarometer axes number.
202  *
203  * @param[in] ip pointer to @p BaseBarometer interface.
204  * @param[in] bp a buffer which contains biases.
205  *
206  * @return The operation status.
207  * @retval MSG_OK if the function succeeded.
208  * @retval MSG_RESET if one or more I2C errors occurred, the errors can
209  * be retrieved using @p i2cGetErrors().
210  * @retval MSG_TIMEOUT if a timeout occurred before operation end.
211  */
212 static msg_t baro_set_bias(void *ip, float *bp) {
213  LPS25HDriver* devp;
214  msg_t msg = MSG_OK;
215
216  osalDbgCheck((ip != NULL) && (bp != NULL));
217
218  /* Getting parent instance pointer.*/
220
221  osalDbgAssert((devp->state == LPS25H_READY),
222  "baro_set_bias(), invalid state");
223
224  devp->barobias = *bp;
225  return msg;
226 }
227
228 /**
229  * @brief Reset bias values for the BaseBarometer.
230  * @note Default biases value are obtained from device datasheet when
231  * available otherwise they are considered zero.
232  *
233  * @param[in] ip pointer to @p BaseBarometer interface.
234  *
235  * @return The operation status.
236  * @retval MSG_OK if the function succeeded.
237  */
238 static msg_t baro_reset_bias(void *ip) {
239  LPS25HDriver* devp;
240  msg_t msg = MSG_OK;
241
242  osalDbgCheck(ip != NULL);
243
244  /* Getting parent instance pointer.*/
246
247  osalDbgAssert((devp->state == LPS25H_READY),
248  "baro_reset_bias(), invalid state");
249
250  devp->barobias = LPS25H_BARO_SENS;
251  return msg;
252 }
253
254 /**
255  * @brief Set sensitivity values for the BaseBarometer.
256  * @note Sensitivity must be expressed as hPa/LSB.
257  * @note The sensitivity buffer must be at least the same size of the
258  * BaseBarometer axes number.
259  *
260  * @param[in] ip pointer to @p BaseBarometer interface.
261  * @param[in] sp a buffer which contains sensitivities.
262  *
263  * @return The operation status.
264  * @retval MSG_OK if the function succeeded.
265  */
266 static msg_t baro_set_sensitivity(void *ip, float *sp) {
267  LPS25HDriver* devp;
268  msg_t msg = MSG_OK;
269
270  osalDbgCheck((ip != NULL) && (sp != NULL));
271
272  /* Getting parent instance pointer.*/
274
275  osalDbgAssert((devp->state == LPS25H_READY),
276  "baro_set_sensitivity(), invalid state");
277
278  devp->barosensitivity = *sp;
279  return msg;
280 }
281
282 /**
283  * @brief Reset sensitivity values for the BaseBarometer.
284  * @note Default sensitivities value are obtained from device datasheet.
285  *
286  * @param[in] ip pointer to @p BaseBarometer interface.
287  *
288  * @return The operation status.
289  * @retval MSG_OK if the function succeeded.
290  */
291 static msg_t baro_reset_sensitivity(void *ip) {
292  LPS25HDriver* devp;
293  msg_t msg = MSG_OK;
294
295  osalDbgCheck(ip != NULL);
296
297  /* Getting parent instance pointer.*/
299
300  osalDbgAssert((devp->state == LPS25H_READY),
301  "baro_reset_sensitivity(), invalid state");
302
303  devp->barosensitivity = LPS25H_BARO_SENS;
304  return msg;
305 }
306
307 /**
308  * @brief Return the number of axes of the BaseThermometer.
309  *
310  * @param[in] ip pointer to @p BaseThermometer interface.
311  *
312  * @return the number of axes.
313  */
314 static size_t thermo_get_axes_number(void *ip) {
315  (void)ip;
316
318 }
319
320 /**
321  * @brief Retrieves raw data from the BaseThermometer.
322  * @note This data is retrieved from MEMS register without any algebraical
323  * manipulation.
324  * @note The axes array must be at least the same size of the
325  * BaseThermometer axes number.
326  *
327  * @param[in] ip pointer to @p BaseThermometer interface.
328  * @param[out] axes a buffer which would be filled with raw data.
329  *
330  * @return The operation status.
331  * @retval MSG_OK if the function succeeded.
332  * @retval MSG_RESET if one or more I2C errors occurred, the errors can
333  * be retrieved using @p i2cGetErrors().
334  * @retval MSG_TIMEOUT if a timeout occurred before operation end.
335  */
336 static msg_t thermo_read_raw(void *ip, int32_t axes[]) {
337  LPS25HDriver* devp;
338  int16_t tmp;
339  uint8_t buff[2];
340  msg_t msg;
341
342  osalDbgCheck((ip != NULL) && (axes != NULL));
343
344  /* Getting parent instance pointer.*/
346
347  osalDbgAssert((devp->state == LPS25H_READY),
348  "thermo_read_raw(), invalid state");
349
350  osalDbgAssert((devp->config->i2cp->state == I2C_READY),
351  "thermo_read_raw(), channel not ready");
352
353 #if LPS25H_SHARED_I2C
354  i2cAcquireBus(devp->config->i2cp);
355  i2cStart(devp->config->i2cp,
356  devp->config->i2ccfg);
357 #endif /* LPS25H_SHARED_I2C */
358
359  msg = lps25hI2CReadRegister(devp->config->i2cp, devp->config->slaveaddress,
360  LPS25H_AD_TEMP_OUT_L, buff, 2);
361
362 #if LPS25H_SHARED_I2C
363  i2cReleaseBus(devp->config->i2cp);
364 #endif /* LPS25H_SHARED_I2C */
365
366  if (msg == MSG_OK) {
367  tmp = buff[0] + (buff[1] << 8);
368  *axes = (int32_t)tmp;
369  }
370  return msg;
371 }
372
373 /**
374  * @brief Retrieves cooked data from the BaseThermometer.
375  * @note This data is manipulated according to the formula
376  * cooked = (raw * sensitivity) - bias.
377  * @note Final data is expressed as °C.
378  * @note The axes array must be at least the same size of the
379  * BaseThermometer axes number.
380  *
381  * @param[in] ip pointer to @p BaseThermometer interface.
382  * @param[out] axis a buffer which would be filled with cooked data.
383  *
384  * @return The operation status.
385  * @retval MSG_OK if the function succeeded.
386  * @retval MSG_RESET if one or more I2C errors occurred, the errors can
387  * be retrieved using @p i2cGetErrors().
388  * @retval MSG_TIMEOUT if a timeout occurred before operation end.
389  */
390 static msg_t thermo_read_cooked(void *ip, float* axis) {
391  LPS25HDriver* devp;
392  int32_t raw;
393  msg_t msg;
394
395  osalDbgCheck((ip != NULL) && (axis != NULL));
396
397  /* Getting parent instance pointer.*/
399
400  osalDbgAssert((devp->state == LPS25H_READY),
401  "thermo_read_cooked(), invalid state");
402
403  msg = thermo_read_raw(devp, &raw);
404
405  *axis = (raw * devp->thermosensitivity) - devp->thermobias;
406
407  return msg;
408 }
409
410 /**
411  * @brief Set bias values for the BaseThermometer.
412  * @note Bias must be expressed as °C.
413  * @note The bias buffer must be at least the same size of the
414  * BaseThermometer axes number.
415  *
416  * @param[in] ip pointer to @p BaseThermometer interface.
417  * @param[in] bp a buffer which contains biases.
418  *
419  * @return The operation status.
420  * @retval MSG_OK if the function succeeded.
421  */
422 static msg_t thermo_set_bias(void *ip, float *bp) {
423  LPS25HDriver* devp;
424  msg_t msg = MSG_OK;
425
426  osalDbgCheck((ip != NULL) && (bp != NULL));
427
428  /* Getting parent instance pointer.*/
430
431  osalDbgAssert((devp->state == LPS25H_READY),
432  "thermo_set_bias(), invalid state");
433
434  devp->thermobias = *bp;
435
436  return msg;
437 }
438
439 /**
440  * @brief Reset bias values for the BaseThermometer.
441  * @note Default biases value are obtained from device datasheet when
442  * available otherwise they are considered zero.
443  *
444  * @param[in] ip pointer to @p BaseThermometer interface.
445  *
446  * @return The operation status.
447  * @retval MSG_OK if the function succeeded.
448  */
449 static msg_t thermo_reset_bias(void *ip) {
450  LPS25HDriver* devp;
451  msg_t msg = MSG_OK;
452
453  osalDbgCheck(ip != NULL);
454
455  /* Getting parent instance pointer.*/
457
458  osalDbgAssert((devp->state == LPS25H_READY),
459  "thermo_reset_bias(), invalid state");
460
461  devp->thermobias = LPS25H_THERMO_BIAS;
462
463  return msg;
464 }
465
466 /**
467  * @brief Set sensitivity values for the BaseThermometer.
468  * @note Sensitivity must be expressed as °C/LSB.
469  * @note The sensitivity buffer must be at least the same size of the
470  * BaseThermometer axes number.
471  *
472  * @param[in] ip pointer to @p BaseThermometer interface.
473  * @param[in] sp a buffer which contains sensitivities.
474  *
475  * @return The operation status.
476  * @retval MSG_OK if the function succeeded.
477  */
478 static msg_t thermo_set_sensitivity(void *ip, float *sp) {
479  LPS25HDriver* devp;
480  msg_t msg = MSG_OK;
481
482  osalDbgCheck((ip != NULL) && (sp != NULL));
483
484  /* Getting parent instance pointer.*/
486
487  osalDbgAssert((devp->state == LPS25H_READY),
488  "thermo_set_sensitivity(), invalid state");
489
490  devp->thermosensitivity = *sp;
491
492  return msg;
493 }
494
495 /**
496  * @brief Reset sensitivity values for the BaseThermometer.
497  * @note Default sensitivities value are obtained from device datasheet.
498  *
499  * @param[in] ip pointer to @p BaseThermometer interface.
500  *
501  * @return The operation status.
502  * @retval MSG_OK if the function succeeded.
503  */
504 static msg_t thermo_reset_sensitivity(void *ip) {
505  LPS25HDriver* devp;
506  msg_t msg = MSG_OK;
507
508  osalDbgCheck(ip != NULL);
509
510  /* Getting parent instance pointer.*/
512
513  osalDbgAssert((devp->state == LPS25H_READY),
514  "thermo_reset_sensitivity(), invalid state");
515
516  devp->thermosensitivity = LPS25H_THERMO_SENS;
517
518  return msg;
519 }
520
521 static const struct LPS25HVMT vmt_device = {
522  (size_t)0
523 };
524
525 static const struct BaseBarometerVMT vmt_barometer = {
526  sizeof(struct LPS25HVMT*),
530 };
531
532 static const struct BaseThermometerVMT vmt_thermometer = {
533  sizeof(struct LPS25HVMT*) + sizeof(BaseBarometer),
537 };
538
539 /*===========================================================================*/
540 /* Driver exported functions. */
541 /*===========================================================================*/
542
543 /**
544  * @brief Initializes an instance.
545  *
546  * @param[out] devp pointer to the @p LPS25HDriver object
547  *
548  * @init
549  */
551
552  devp->vmt = &vmt_device;
553  devp->baro_if.vmt = &vmt_barometer;
554  devp->thermo_if.vmt = &vmt_thermometer;
555
556  devp->config = NULL;
557
558  devp->baroaxes = LPS25H_BARO_NUMBER_OF_AXES;
559  devp->thermoaxes = LPS25H_THERMO_NUMBER_OF_AXES;
560
561  devp->state = LPS25H_STOP;
562 }
563
564 /**
565  * @brief Configures and activates LPS25H Complex Driver peripheral.
566  *
567  * @param[in] devp pointer to the @p LPS25HDriver object
568  * @param[in] config pointer to the @p LPS25HConfig object
569  *
570  * @api
571  */
572 void lps25hStart(LPS25HDriver *devp, const LPS25HConfig *config) {
573  uint8_t cr[2];
574  osalDbgCheck((devp != NULL) && (config != NULL));
575
576  osalDbgAssert((devp->state == LPS25H_STOP) || (devp->state == LPS25H_READY),
577  "lps25hStart(), invalid state");
578
579  devp->config = config;
580
581  /* Control register 1 configuration block.*/
582  {
583  cr[0] = LPS25H_AD_CTRL_REG1;
584  cr[1] = devp->config->outputdatarate | LPS25H_CTRL_REG1_PD;
585 #if LPS25H_USE_ADVANCED || defined(__DOXYGEN__)
586  cr[1] |= devp->config->blockdataupdate;
587 #endif
588  }
589
590 #if LPS25H_SHARED_I2C
591  i2cAcquireBus((devp)->config->i2cp);
592 #endif /* LPS25H_SHARED_I2C */
593  i2cStart((devp)->config->i2cp,
594  (devp)->config->i2ccfg);
595
596  lps25hI2CWriteRegister(devp->config->i2cp, devp->config->slaveaddress, cr, 1);
597
598 #if LPS25H_SHARED_I2C
599  i2cReleaseBus((devp)->config->i2cp);
600 #endif /* LPS25H_SHARED_I2C */
601
602  /* Resolution configuration block.*/
603  {
604  cr[0] = LPS25H_AD_RES_CONF;
605  cr[1] = 0x05;
606 #if LPS25H_USE_ADVANCED || defined(__DOXYGEN__)
607  cr[1] = devp->config->baroresolution | devp->config->thermoresolution;
608 #endif
609
610  }
611 #if LPS25H_SHARED_I2C
612  i2cAcquireBus((devp)->config->i2cp);
613  i2cStart((devp)->config->i2cp,
614  (devp)->config->i2ccfg);
615 #endif /* LPS25H_SHARED_I2C */
616
617  lps25hI2CWriteRegister(devp->config->i2cp, devp->config->slaveaddress,
618  cr, 1);
619
620 #if LPS25H_SHARED_I2C
621  i2cReleaseBus((devp)->config->i2cp);
622 #endif /* LPS25H_SHARED_I2C */
623
624  if(devp->config->barosensitivity == NULL) {
625  devp->barosensitivity = LPS25H_BARO_SENS;
626  }
627  else{
628  /* Taking barometer sensitivity from user configurations */
629  devp->barosensitivity = *(devp->config->barosensitivity);
630  }
631
632  if(devp->config->barobias == NULL) {
633  devp->barobias = LPS25H_BARO_BIAS;
634  }
635  else{
636  /* Taking barometer bias from user configurations */
637  devp->barobias = *(devp->config->barobias);
638  }
639
640  if(devp->config->thermosensitivity == NULL) {
641  devp->thermosensitivity = LPS25H_THERMO_SENS;
642  }
643  else{
644  /* Taking thermometer sensitivity from user configurations */
645  devp->thermosensitivity = *(devp->config->thermosensitivity);
646  }
647
648  if(devp->config->thermobias == NULL) {
649  devp->thermobias = LPS25H_THERMO_BIAS;
650  }
651  else{
652  /* Taking thermometer bias from user configurations */
653  devp->thermobias = *(devp->config->thermobias);
654  }
655
656  /* This is the Barometer transient recovery time */
658
659  devp->state = LPS25H_READY;
660 }
661
662 /**
663  * @brief Deactivates the LPS25H Complex Driver peripheral.
664  *
665  * @param[in] devp pointer to the @p LPS25HDriver object
666  *
667  * @api
668  */
670  uint8_t cr[2];
671
672  osalDbgCheck(devp != NULL);
673
674  osalDbgAssert((devp->state == LPS25H_STOP) || (devp->state == LPS25H_READY),
675  "lps25hStop(), invalid state");
676
677  if (devp->state == LPS25H_READY) {
678 #if LPS25H_SHARED_I2C
679  i2cAcquireBus((devp)->config->i2cp);
680  i2cStart((devp)->config->i2cp,
681  (devp)->config->i2ccfg);
682 #endif /* LPS25H_SHARED_I2C */
683
684  cr[0] = LPS25H_AD_CTRL_REG1;
685  cr[1] = 0;
686  lps25hI2CWriteRegister(devp->config->i2cp, devp->config->slaveaddress,
687  cr, 1);
688
689  i2cStop((devp)->config->i2cp);
690 #if LPS25H_SHARED_I2C
691  i2cReleaseBus((devp)->config->i2cp);
692 #endif /* LPS25H_SHARED_I2C */
693  }
694  devp->state = LPS25H_STOP;
695 }
696 /** @} */
LPS25H MEMS interface module header.
LPS25H 2-axis barometer/thermometer class.
Definition: lps25h.h:473
Definition: lps25h.c:212
msg_t i2cMasterTransmitTimeout(I2CDriver *i2cp, i2caddr_t addr, const uint8_t *txbuf, size_t txbytes, uint8_t *rxbuf, size_t rxbytes, sysinterval_t timeout)
Sends data via the I2C bus.
Definition: hal_i2c.c:170
#define LPS25H_THERMO_NUMBER_OF_AXES
LPS25H thermometer subsystem characteristics.
Definition: lps25h.h:85
I2CDriver * i2cp
I2C driver associated to this LPS25H.
Definition: lps25h.h:381
void i2cStart(I2CDriver *i2cp, const I2CConfig *config)
Configures and activates the I2C peripheral.
Definition: hal_i2c.c:93
LPS25H configuration structure.
Definition: lps25h.h:365
Definition: lps25h.c:336
Base thermometer class.
Definition: lps25h.c:572
Definition: lps25h.c:177
Definition: lps25h.c:314
void i2cAcquireBus(I2CDriver *i2cp)
Gains exclusive access to the I2C bus.
Definition: hal_i2c.c:261
BaseThermometer thermo_if
Base thermometer interface.
Definition: lps25h.h:479
void i2cReleaseBus(I2CDriver *i2cp)
Releases exclusive access to the I2C bus.
Definition: hal_i2c.c:277
Definition: lps25h.c:478
BaseThermometer virtual methods table.
Definition: lps25h.c:238
BaseBarometer virtual methods table.
Definition: hal_barometer.h:70
#define objGetInstance(type, ip)
Returns the instance pointer starting from an interface pointer.
Definition: hal_objects.h:80
Definition: lps25h.c:422
#define osalThreadSleepMilliseconds(msecs)
Delays the invoking thread for the specified number of milliseconds.
Definition: osal.h:451
void i2cStop(I2CDriver *i2cp)
Deactivates the I2C peripheral.
Definition: hal_i2c.c:113
void lps25hObjectInit(LPS25HDriver *devp)
Definition: lps25h.c:550
Definition: hal_i2c_lld.h:88
const struct BaseBarometerVMT * vmt
Virtual Methods Table.
Definition: hal_barometer.h:88
#define TIME_INFINITE
Infinite interval specification for all functions with a timeout specification.
Definition: chtime.h:55
Definition: lps25h.c:266
Definition: lps25h.c:291
LPS25H virtual methods table.
Definition: lps25h.h:445
#define MSG_OK
Normal wakeup message.
Definition: chschd.h:39
Base barometer class.
Definition: hal_barometer.h:86
Definition: lps25h.c:125
Definition: lps25h.c:504
Definition: lps25h.c:103
Definition: lps25h.c:449
void lps25hStop(LPS25HDriver *devp)
Definition: lps25h.c:669
lps25h_sad_t
LPS25H slave address.
Definition: lps25h.h:309
static msg_t lps25hI2CWriteRegister(I2CDriver *i2cp, lps25h_sad_t sad, uint8_t *txbuf, size_t n)
Definition: lps25h.c:87
static msg_t lps25hI2CReadRegister(I2CDriver *i2cp, lps25h_sad_t sad, uint8_t reg, uint8_t *rxbuf, size_t n)
Definition: lps25h.c:63
#define LPS25H_BARO_NUMBER_OF_AXES
LPS25H barometer subsystem characteristics.
Definition: lps25h.h:72
const I2CConfig * config
Current configuration data.
Definition: hal_i2c_lld.h:96
BaseBarometer baro_if
Base barometer interface.
Definition: lps25h.h:477
static msg_t thermo_read_cooked(void *ip, float *axis)
Definition: lps25h.c:390
const struct LPS25HVMT * vmt
Definition: lps25h.h:475
const struct BaseThermometerVMT * vmt
int32_t msg_t
Definition: chtypes.h:51
