chsys.c
18 */
19
20 /**
21  * @file chsys.c
22  * @brief System related code.
23  *
24  * @addtogroup system
25  * @details System related APIs and services:
26  * - Initialization.
27  * - Locks.
28  * - Interrupt Handling.
29  * - Power Management.
30  * - Abnormal Termination.
31  * - Realtime counter.
32  * .
33  * @{
34  */
35
36 #include "ch.h"
37
38 /*===========================================================================*/
39 /* Module exported variables. */
40 /*===========================================================================*/
41
42 #if (CH_CFG_NO_IDLE_THREAD == FALSE) || defined(__DOXYGEN__)
43 /**
44  * @brief Idle thread working area.
45  */
47 #endif
50 /* Module local types. */
52
54 /* Module local variables. */
56
58 /* Module local functions. */
60
61 #if (CH_CFG_NO_IDLE_THREAD == FALSE) || defined(__DOXYGEN__)
62 /**
63  * @brief This function implements the idle thread infinite loop.
64  * @details The function puts the processor in the lowest power mode capable
65  * to serve interrupts.<br>
66  * The priority is internally set to the minimum system value so
67  * that this thread is executed only if there are no other ready
68  * threads in the system.
69  *
70  * @param[in] p the thread parameter, unused in this scenario
71  */
72 static void _idle_thread(void *p) {
73
74  (void)p;
75
76  while (true) {
77  /*lint -save -e522 [2.2] Apparently no side effects because it contains
78  an asm instruction.*/
80  /*lint -restore*/
82  }
83 }
84 #endif /* CH_CFG_NO_IDLE_THREAD == FALSE */
85
86 /*===========================================================================*/
87 /* Module exported functions. */
88 /*===========================================================================*/
89
90 /**
91  * @brief ChibiOS/RT initialization.
92  * @details After executing this function the current instructions stream
93  * becomes the main thread.
94  * @pre Interrupts must disabled before invoking this function.
95  * @post The main thread is created with priority @p NORMALPRIO and
96  * interrupts are enabled.
97  *
98  * @special
99  */
100 void chSysInit(void) {
101
102  _scheduler_init();
103  _vt_init();
104  _trace_init();
105
106 #if CH_DBG_SYSTEM_STATE_CHECK == TRUE
107  ch.dbg.isr_cnt = (cnt_t)0;
108  ch.dbg.lock_cnt = (cnt_t)0;
109 #endif
110 #if CH_CFG_USE_TM == TRUE
111  _tm_init();
112 #endif
113 #if CH_CFG_USE_MEMCORE == TRUE
114  _core_init();
115 #endif
116 #if CH_CFG_USE_HEAP == TRUE
117  _heap_init();
118 #endif
119 #if CH_CFG_USE_FACTORY == TRUE
120  _factory_init();
121 #endif
122 #if CH_DBG_STATISTICS == TRUE
123  _stats_init();
124 #endif
125
126 #if CH_CFG_NO_IDLE_THREAD == FALSE
127  /* Now this instructions flow becomes the main thread.*/
128 #if CH_CFG_USE_REGISTRY == TRUE
129  currp = _thread_init(&ch.mainthread, (const char *)&ch_debug, NORMALPRIO);
130 #else
132 #endif
133 #else
134  /* Now this instructions flow becomes the idle thread.*/
135  currp = _thread_init(&ch.mainthread, "idle", IDLEPRIO);
136 #endif
137
138 #if CH_DBG_ENABLE_STACK_CHECK == TRUE
139  {
140  /* Setting up the base address of the static main thread stack, the
141  symbol must be provided externally.*/
142  extern stkalign_t __main_thread_stack_base__;
143  currp->wabase = &__main_thread_stack_base__;
144  }
145 #elif CH_CFG_USE_DYNAMIC == TRUE
146  currp->wabase = NULL;
147 #endif
148
149  /* Setting up the caller as current thread.*/
150  currp->state = CH_STATE_CURRENT;
151
152  /* Port layer initialization last because it depend on some of the
153  initializations performed before.*/
154  port_init();
155
156 #if CH_DBG_STATISTICS == TRUE
157  /* Starting measurement for this thread.*/
158  chTMStartMeasurementX(&currp->stats);
159 #endif
160
161  /* Initialization hook.*/
163
164  /* It is alive now.*/
165  chSysEnable();
166
167 #if CH_CFG_NO_IDLE_THREAD == FALSE
168  {
169  static const thread_descriptor_t idle_descriptor = {
170  "idle",
171  THD_WORKING_AREA_BASE(ch_idle_thread_wa),
172  THD_WORKING_AREA_END(ch_idle_thread_wa),
173  IDLEPRIO,
174  _idle_thread,
175  NULL
176  };
177
178  /* This thread has the lowest priority in the system, its role is just to
179  serve interrupts in its context while keeping the lowest energy saving
180  mode compatible with the system status.*/
181  (void) chThdCreate(&idle_descriptor);
182  }
183 #endif
184 }
185
186 /**
187  * @brief Halts the system.
188  * @details This function is invoked by the operating system when an
189  * unrecoverable error is detected, for example because a programming
190  * error in the application code that triggers an assertion while
191  * in debug mode.
192  * @note Can be invoked from any system state.
193  *
194  * @param[in] reason pointer to an error string
195  *
196  * @special
197  */
198 void chSysHalt(const char *reason) {
199
200  port_disable();
201
202  /* Logging the event.*/
203  _trace_halt(reason);
204
205  /* Pointing to the passed message.*/
206  ch.dbg.panic_msg = reason;
207
208  /* Halt hook code, usually empty.*/
209  CH_CFG_SYSTEM_HALT_HOOK(reason);
210
211  /* Harmless infinite loop.*/
212  while (true) {
213  }
214 }
215
216 /**
217  * @brief System integrity check.
218  * @details Performs an integrity check of the important ChibiOS/RT data
219  * structures.
220  * @note The appropriate action in case of failure is to halt the system
221  * before releasing the critical zone.
222  * @note If the system is corrupted then one possible outcome of this
223  * function is an exception caused by @p NULL or corrupted pointers
224  * in list elements. Exception vectors must be monitored as well.
225  * @note This function is not used internally, it is up to the
226  * application to define if and where to perform system
227  * checking.
228  * @note Performing all tests at once can be a slow operation and can
229  * degrade the system response time. It is suggested to execute
230  * one test at time and release the critical zone in between tests.
231  *
232  * @param[in] testmask Each bit in this mask is associated to a test to be
233  * performed.
234  * @return The test result.
235  * @retval false The test succeeded.
236  * @retval true Test failed.
237  *
238  * @iclass
239  */
240 bool chSysIntegrityCheckI(unsigned testmask) {
241  cnt_t n;
242
243  chDbgCheckClassI();
244
245  /* Ready List integrity check.*/
246  if ((testmask & CH_INTEGRITY_RLIST) != 0U) {
247  thread_t *tp;
248
249  /* Scanning the ready list forward.*/
250  n = (cnt_t)0;
251  tp = ch.rlist.queue.next;
252  while (tp != (thread_t *)&ch.rlist.queue) {
253  n++;
254  tp = tp->queue.next;
255  }
256
257  /* Scanning the ready list backward.*/
258  tp = ch.rlist.queue.prev;
259  while (tp != (thread_t *)&ch.rlist.queue) {
260  n--;
261  tp = tp->queue.prev;
262  }
263
264  /* The number of elements must match.*/
265  if (n != (cnt_t)0) {
266  return true;
267  }
268  }
269
270  /* Timers list integrity check.*/
271  if ((testmask & CH_INTEGRITY_VTLIST) != 0U) {
272  virtual_timer_t * vtp;
273
274  /* Scanning the timers list forward.*/
275  n = (cnt_t)0;
276  vtp = ch.vtlist.next;
277  while (vtp != (virtual_timer_t *)&ch.vtlist) {
278  n++;
279  vtp = vtp->next;
280  }
281
282  /* Scanning the timers list backward.*/
283  vtp = ch.vtlist.prev;
284  while (vtp != (virtual_timer_t *)&ch.vtlist) {
285  n--;
286  vtp = vtp->prev;
287  }
288
289  /* The number of elements must match.*/
290  if (n != (cnt_t)0) {
291  return true;
292  }
293  }
294
295 #if CH_CFG_USE_REGISTRY == TRUE
296  if ((testmask & CH_INTEGRITY_REGISTRY) != 0U) {
297  thread_t *tp;
298
299  /* Scanning the ready list forward.*/
300  n = (cnt_t)0;
301  tp = ch.rlist.newer;
302  while (tp != (thread_t *)&ch.rlist) {
303  n++;
304  tp = tp->newer;
305  }
306
307  /* Scanning the ready list backward.*/
308  tp = ch.rlist.older;
309  while (tp != (thread_t *)&ch.rlist) {
310  n--;
311  tp = tp->older;
312  }
313
314  /* The number of elements must match.*/
315  if (n != (cnt_t)0) {
316  return true;
317  }
318  }
319 #endif /* CH_CFG_USE_REGISTRY == TRUE */
320
321 #if defined(PORT_INTEGRITY_CHECK)
322  if ((testmask & CH_INTEGRITY_PORT) != 0U) {
323  PORT_INTEGRITY_CHECK();
324  }
325 #endif
326
327  return false;
328 }
329
330 /**
331  * @brief Handles time ticks for round robin preemption and timer increments.
332  * @details Decrements the remaining time quantum of the running thread
333  * and preempts it when the quantum is used up. Increments system
334  * time and manages the timers.
335  * @note The frequency of the timer determines the system tick granularity
336  * and, together with the @p CH_CFG_TIME_QUANTUM macro, the round robin
337  * interval.
338  *
339  * @iclass
340  */
341 void chSysTimerHandlerI(void) {
342
343  chDbgCheckClassI();
344
345 #if CH_CFG_TIME_QUANTUM > 0
346  /* Running thread has not used up quantum yet? */
347  if (currp->ticks > (tslices_t)0) {
348  /* Decrement remaining quantum.*/
349  currp->ticks--;
350  }
351 #endif
352 #if CH_DBG_THREADS_PROFILING == TRUE
353  currp->time++;
354 #endif
355  chVTDoTickI();
357 }
358
359 /**
360  * @brief Returns the execution status and enters a critical zone.
361  * @details This functions enters into a critical zone and can be called
362  * from any context. Because its flexibility it is less efficient
363  * than @p chSysLock() which is preferable when the calling context
364  * is known.
365  * @post The system is in a critical zone.
366  *
367  * @return The previous system status, the encoding of this
368  * status word is architecture-dependent and opaque.
369  *
370  * @xclass
371  */
373
375  if (port_irq_enabled(sts)) {
376  if (port_is_isr_context()) {
378  }
379  else {
380  chSysLock();
381  }
382  }
383  return sts;
384 }
385
386 /**
387  * @brief Restores the specified execution status and leaves a critical zone.
388  * @note A call to @p chSchRescheduleS() is automatically performed
389  * if exiting the critical zone and if not in ISR context.
390  *
391  * @param[in] sts the system status to be restored.
392  *
393  * @xclass
394  */
396
397  if (port_irq_enabled(sts)) {
398  if (port_is_isr_context()) {
400  }
401  else {
403  chSysUnlock();
404  }
405  }
406 }
407
408 #if (PORT_SUPPORTS_RT == TRUE) || defined(__DOXYGEN__)
409 /**
410  * @brief Realtime window test.
411  * @details This function verifies if the current realtime counter value
412  * lies within the specified range or not. The test takes care
413  * of the realtime counter wrapping to zero on overflow.
414  * @note When start==end then the function returns always true because the
415  * whole time range is specified.
416  * @note This function is only available if the port layer supports the
417  * option @p PORT_SUPPORTS_RT.
418  *
419  * @param[in] cnt the counter value to be tested
420  * @param[in] start the start of the time window (inclusive)
421  * @param[in] end the end of the time window (non inclusive)
422  * @retval true current time within the specified time window.
423  * @retval false current time not within the specified time window.
424  *
425  * @xclass
426  */
428
429  return (bool)((cnt - start) < (end - start));
430 }
431
432 /**
433  * @brief Polled delay.
434  * @note The real delay is always few cycles in excess of the specified
435  * value.
436  * @note This function is only available if the port layer supports the
437  * option @p PORT_SUPPORTS_RT.
438  *
439  * @param[in] cycles number of cycles
440  *
441  * @xclass
442  */
445  rtcnt_t end = start + cycles;
446
447  while (chSysIsCounterWithinX(chSysGetRealtimeCounterX(), start, end)) {
448  }
449 }
450 #endif /* PORT_SUPPORTS_RT == TRUE */
451
452 /** @} */
static void port_wait_for_interrupt(void)
Enters an architecture-dependent IRQ-waiting mode.
Definition: chcore.h:414
void _scheduler_init(void)
Scheduler initialization.
Definition: chschd.c:65
#define chSysGetRealtimeCounterX()
Returns the current value of the system real time counter.
Definition: chsys.h:253
cnt_t lock_cnt
Lock nesting level.
Definition: chschd.h:396
#define chSysLock()
Enters the kernel lock state.
#define CH_CFG_SYSTEM_TICK_HOOK()
System tick event hook.
system_debug_t dbg
System debug.
Definition: chschd.h:423
void chSysPolledDelayX(rtcnt_t cycles)
Polled delay.
Definition: chsys.c:443
Type of a thread descriptor.
Definition: chthreads.h:57
#define IDLEPRIO
Idle priority.
Definition: chschd.h:55
Definition: chsys.c:72
#define NORMALPRIO
Normal priority.
Definition: chschd.h:57
virtual_timer_t * prev
Previous timer in the list.
Definition: chschd.h:326
void _core_init(void)
Low level memory manager initialization.
Definition: chmemcore.c:81
#define CH_STATE_CURRENT
Currently running.
Definition: chschd.h:68
int32_t cnt_t
Definition: chtypes.h:55
#define currp
Current thread pointer access macro.
Definition: chschd.h:459
void _tm_init(void)
Initializes the time measurement unit.
Definition: chtm.c:77
static void port_disable(void)
Disables all the interrupt sources.
Definition: chcore.h:388
#define CH_CFG_SYSTEM_INIT_HOOK(tp)
System initialization hook.
thread_t mainthread
Main thread descriptor.
Definition: chschd.h:427
Halts the system.
Definition: chsys.c:198
virtual_timers_list_t vtlist
Virtual timers delta list header.
Definition: chschd.h:419
uint8_t tslices_t
Definition: chtypes.h:49
#define THD_WORKING_AREA_END(s)
End of a working area casted to the correct type.
Definition: chthreads.h:149
uint32_t rtcnt_t
Definition: chtypes.h:43
#define THD_WORKING_AREA_BASE(s)
Base of a working area casted to the correct type.
Definition: chthreads.h:142
void _trace_halt(const char *reason)
Inserts in the circular debug trace buffer an halt record.
Definition: chtrace.c:162
void chSchRescheduleS(void)
Performs a reschedule if a higher priority thread is runnable.
Definition: chschd.c:456
static bool port_is_isr_context(void)
Determines the current execution context.
Definition: chcore.h:341
#define chSysUnlock()
Leaves the kernel lock state.
Definition: chsys.c:341
Definition: chsys.c:240
#define chSysUnlockFromISR()
Leaves the kernel lock state from within an interrupt handler.
void _trace_init(void)
Trace circular buffer subsystem initialization.
Definition: chtrace.c:85
void _vt_init(void)
Virtual Timers initialization.
Definition: chvt.c:61
THD_WORKING_AREA(ch_idle_thread_wa, PORT_IDLE_THREAD_STACK_SIZE)
ready_list_t rlist
Ready list header.
Definition: chschd.h:415
Definition: chsys.c:100
ch_system_t ch
System data structures.
Definition: chschd.c:42
NOINLINE void chTMStartMeasurementX(time_measurement_t *tmp)
Starts a measurement.
Definition: chtm.c:114
void _stats_init(void)
Initializes the statistics module.
Definition: chstats.c:62
uint32_t syssts_t
Definition: chtypes.h:45
syssts_t chSysGetStatusAndLockX(void)
Definition: chsys.c:372
#define chSysLockFromISR()
Enters the kernel lock state from within an interrupt handler.
void chSysRestoreStatusX(syssts_t sts)
Definition: chsys.c:395
Virtual Timer descriptor structure.
Definition: chschd.h:324
bool chSysIsCounterWithinX(rtcnt_t cnt, rtcnt_t start, rtcnt_t end)
Definition: chsys.c:427
thread_t * older
Older registry element.
Definition: chschd.h:159
cnt_t isr_cnt
ISR nesting level.
Definition: chschd.h:392
virtual_timer_t * next
Next timer in the delta list.
Definition: chschd.h:341
#define chSysEnable()
Lowers the system interrupt priority mask to user level.
thread_t * _thread_init(thread_t *tp, const char *name, tprio_t prio)
Initializes a thread structure.
Definition: chthreads.c:88
uint64_t stkalign_t
Type of stack and memory alignment enforcement.
Definition: chcore.h:156
Next timer in the list.
Definition: chschd.h:325
#define PORT_IDLE_THREAD_STACK_SIZE
Stack size for the system idle thread.
Definition: chcore.h:111
thread_t * chThdCreate(const thread_descriptor_t *tdp)
Creates a new thread into a static memory area.
Definition: chthreads.c:280
static void chVTDoTickI(void)
Virtual timers ticker.
Definition: chvt.h:370
const char *volatile panic_msg
Pointer to the panic message.
Definition: chschd.h:387
#define CH_CFG_IDLE_LOOP_HOOK()
Idle Loop hook.
Last timer in the delta list.
Definition: chschd.h:343
#define CH_CFG_SYSTEM_HALT_HOOK(reason)
System halt hook.
void _factory_init(void)
Initializes the objects factory.
Definition: chfactory.c:245
void _heap_init(void)
Initializes the default heap.
Definition: chmemheaps.c:107
static syssts_t port_get_irq_status(void)
Returns a word encoding the current interrupts status.
Definition: chcore.h:313
threads_queue_t queue
Threads queue header.
Definition: chschd.h:154
thread_t * newer
Newer registry element.
Definition: chschd.h:158
static bool port_irq_enabled(syssts_t sts)
Checks the interrupt status.
Definition: chcore.h:327
Definition: chschd.h:153
