hal_sdc_lld.c
18  * @file hal_sdc_lld.c
19  * @brief PLATFORM SDC subsystem low level driver source.
21  * @addtogroup SDC
27 #if (HAL_USE_SDC == TRUE) || defined(__DOXYGEN__)
37 /**
38  * @brief SDCD1 driver identifier.
39  */
40 #if (PLATFORM_SDC_USE_SDC1 == TRUE) || defined(__DOXYGEN__)
42 #endif
43
45 /* Driver local variables and types. */
47
49 /* Driver local functions. */
51
53 /* Driver interrupt handlers. */
55
57 /* Driver exported functions. */
59
60 /**
61  * @brief Low level SDC driver initialization.
62  *
63  * @notapi
64  */
65 void sdc_lld_init(void) {
66
67 #if PLATFORM_SDC_USE_SDC1 == TRUE
68  sdcObjectInit(&SDCD1);
69 #endif
70 }
71
72 /**
73  * @brief Configures and activates the SDC peripheral.
74  *
75  * @param[in] sdcp pointer to the @p SDCDriver object
76  *
77  * @notapi
78  */
79 void sdc_lld_start(SDCDriver *sdcp) {
80
81  if (sdcp->state == BLK_STOP) {
82
83  }
84 }
85
86 /**
87  * @brief Deactivates the SDC peripheral.
88  *
89  * @param[in] sdcp pointer to the @p SDCDriver object
90  *
91  * @notapi
92  */
93 void sdc_lld_stop(SDCDriver *sdcp) {
94
95  if (sdcp->state != BLK_STOP) {
96
97  }
98 }
99
100 /**
101  * @brief Starts the SDIO clock and sets it to init mode (400kHz or less).
102  *
103  * @param[in] sdcp pointer to the @p SDCDriver object
104  *
105  * @notapi
106  */
108
109  (void)sdcp;
110 }
111
112 /**
113  * @brief Sets the SDIO clock to data mode (25MHz or less).
114  *
115  * @param[in] sdcp pointer to the @p SDCDriver object
116  * @param[in] clk the clock mode
117  *
118  * @notapi
119  */
121
122  (void)sdcp;
123  (void)clk;
124 }
125
126 /**
127  * @brief Stops the SDIO clock.
128  *
129  * @param[in] sdcp pointer to the @p SDCDriver object
130  *
131  * @notapi
132  */
134
135  (void)sdcp;
136 }
137
138 /**
139  * @brief Switches the bus to 4 bits mode.
140  *
141  * @param[in] sdcp pointer to the @p SDCDriver object
142  * @param[in] mode bus mode
143  *
144  * @notapi
145  */
147
148  (void)sdcp;
149
150  switch (mode) {
151  case SDC_MODE_1BIT:
152
153  break;
154  case SDC_MODE_4BIT:
155
156  break;
157  case SDC_MODE_8BIT:
158
159  break;
160  default:
161  osalDbgAssert(false, "invalid bus mode");
162  break;
163  }
164 }
165
166 /**
167  * @brief Sends an SDIO command with no response expected.
168  *
169  * @param[in] sdcp pointer to the @p SDCDriver object
170  * @param[in] cmd card command
171  * @param[in] arg command argument
172  *
173  * @notapi
174  */
175 void sdc_lld_send_cmd_none(SDCDriver *sdcp, uint8_t cmd, uint32_t arg) {
176
177  (void)sdcp;
178  (void)cmd;
179  (void)arg;
180 }
181
182 /**
183  * @brief Sends an SDIO command with a short response expected.
184  * @note The CRC is not verified.
185  *
186  * @param[in] sdcp pointer to the @p SDCDriver object
187  * @param[in] cmd card command
188  * @param[in] arg command argument
189  * @param[out] resp pointer to the response buffer (one word)
190  *
191  * @return The operation status.
192  * @retval HAL_SUCCESS operation succeeded.
193  * @retval HAL_FAILED operation failed.
194  *
195  * @notapi
196  */
197 bool sdc_lld_send_cmd_short(SDCDriver *sdcp, uint8_t cmd, uint32_t arg,
198  uint32_t *resp) {
199
200  (void)sdcp;
201  (void)cmd;
202  (void)arg;
203  (void)resp;
204
205  return HAL_SUCCESS;
206 }
207
208 /**
209  * @brief Sends an SDIO command with a short response expected and CRC.
210  *
211  * @param[in] sdcp pointer to the @p SDCDriver object
212  * @param[in] cmd card command
213  * @param[in] arg command argument
214  * @param[out] resp pointer to the response buffer (one word)
215  *
216  * @return The operation status.
217  * @retval HAL_SUCCESS operation succeeded.
218  * @retval HAL_FAILED operation failed.
219  *
220  * @notapi
221  */
222 bool sdc_lld_send_cmd_short_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg,
223  uint32_t *resp) {
224
225  (void)sdcp;
226  (void)cmd;
227  (void)arg;
228  (void)resp;
229
230  return HAL_SUCCESS;
231 }
232
233 /**
234  * @brief Sends an SDIO command with a long response expected and CRC.
235  *
236  * @param[in] sdcp pointer to the @p SDCDriver object
237  * @param[in] cmd card command
238  * @param[in] arg command argument
239  * @param[out] resp pointer to the response buffer (four words)
240  *
241  * @return The operation status.
242  * @retval HAL_SUCCESS operation succeeded.
243  * @retval HAL_FAILED operation failed.
244  *
245  * @notapi
246  */
247 bool sdc_lld_send_cmd_long_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg,
248  uint32_t *resp) {
249
250  (void)sdcp;
251  (void)cmd;
252  (void)arg;
253  (void)resp;
254
255  return HAL_SUCCESS;
256 }
257
258 /**
259  * @brief Reads one or more blocks.
260  *
261  * @param[in] sdcp pointer to the @p SDCDriver object
262  * @param[in] startblk first block to read
263  * @param[out] buf pointer to the read buffer
264  * @param[in] n number of blocks to read
265  *
266  * @return The operation status.
267  * @retval HAL_SUCCESS operation succeeded.
268  * @retval HAL_FAILED operation failed.
269  *
270  * @notapi
271  */
272 bool sdc_lld_read(SDCDriver *sdcp, uint32_t startblk,
273  uint8_t *buf, uint32_t n) {
274
275  (void)sdcp;
276  (void)startblk;
277  (void)buf;
278  (void)n;
279
280  return HAL_SUCCESS;
281 }
282
283 /**
284  * @brief Writes one or more blocks.
285  *
286  * @param[in] sdcp pointer to the @p SDCDriver object
287  * @param[in] startblk first block to write
288  * @param[out] buf pointer to the write buffer
289  * @param[in] n number of blocks to write
290  *
291  * @return The operation status.
292  * @retval HAL_SUCCESS operation succeeded.
293  * @retval HAL_FAILED operation failed.
294  *
295  * @notapi
296  */
297 bool sdc_lld_write(SDCDriver *sdcp, uint32_t startblk,
298  const uint8_t *buf, uint32_t n) {
299
300  (void)sdcp;
301  (void)startblk;
302  (void)buf;
303  (void)n;
304
305  return HAL_SUCCESS;
306 }
307
308 /**
309  * @brief Waits for card idle condition.
310  *
311  * @param[in] sdcp pointer to the @p SDCDriver object
312  *
313  * @return The operation status.
314  * @retval HAL_SUCCESS the operation succeeded.
315  * @retval HAL_FAILED the operation failed.
316  *
317  * @api
318  */
319 bool sdc_lld_sync(SDCDriver *sdcp) {
320
321  (void)sdcp;
322
323  return HAL_SUCCESS;
324 }
325
326 #endif /* HAL_USE_SDC == TRUE */
327
328 /** @} */
Definition: hal_sdc_lld.c:319
bool sdc_lld_send_cmd_short_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Definition: hal_sdc_lld.c:222
bool sdc_lld_send_cmd_short(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Definition: hal_sdc_lld.c:197
void sdc_lld_stop_clk(SDCDriver *sdcp)
Definition: hal_sdc_lld.c:133
bool sdc_lld_send_cmd_long_crc(SDCDriver *sdcp, uint8_t cmd, uint32_t arg, uint32_t *resp)
Definition: hal_sdc_lld.c:247
Definition: hal_sdc_lld.c:79
SDCDriver SDCD1
Definition: hal_sdc_lld.c:41
Definition: hal_sdc_lld.c:65
void sdcObjectInit(SDCDriver *sdcp)
Initializes the standard part of a SDCDriver structure.
Definition: hal_sdc.c:554
void sdc_lld_set_data_clk(SDCDriver *sdcp, sdcbusclk_t clk)
Definition: hal_sdc_lld.c:120
Definition: hal_sdc_lld.c:175
sdcbusclk_t
Max supported clock.
Definition: hal_sdc.h:131
bool sdc_lld_write(SDCDriver *sdcp, uint32_t startblk, const uint8_t *buf, uint32_t n)
Definition: hal_sdc_lld.c:297
sdcbusmode_t
Type of SDIO bus mode.
Definition: hal_sdc.h:122
bool sdc_lld_read(SDCDriver *sdcp, uint32_t startblk, uint8_t *buf, uint32_t n)
Definition: hal_sdc_lld.c:272
Structure representing an SDC driver.
Definition: hal_sdc_lld.h:113
void sdc_lld_start_clk(SDCDriver *sdcp)
Definition: hal_sdc_lld.c:107
void sdc_lld_set_bus_mode(SDCDriver *sdcp, sdcbusmode_t mode)
Definition: hal_sdc_lld.c:146
Definition: hal_sdc_lld.c:93
