Here is a list of all documented functions, variables, defines, enums, and typedefs with links to the documentation:
- s -
- S2RTC
: chsys.h
- SD1
: hal_serial_lld.c
- SD_BREAK_DETECTED
: hal_serial.h
- SD_FRAMING_ERROR
: hal_serial.h
- sd_lld_init()
: hal_serial_lld.c
- sd_lld_start()
: hal_serial_lld.c
- sd_lld_stop()
: hal_serial_lld.c
- SD_NOISE_ERROR
: hal_serial.h
- SD_OVERRUN_ERROR
: hal_serial.h
- SD_PARITY_ERROR
: hal_serial.h
- SD_QUEUE_FULL_ERROR
: hal_serial.h
- SD_READY
: hal_serial.h
- SD_STOP
: hal_serial.h
- sd_switch_function_t
: hal_sdc.c
- sd_switch_t
: hal_sdc.c
- SD_UNINIT
: hal_serial.h
- sdAsynchronousRead
: hal_serial.h
- sdAsynchronousWrite
: hal_serial.h
- sdc_cmd6_check_status()
: hal_sdc.c
- sdc_cmd6_construct()
: hal_sdc.c
- sdc_cmd6_extract_info()
: hal_sdc.c
- sdc_detect_bus_clk()
: hal_sdc.c
- sdc_init()
: hal_sdc.c
- SDC_INIT_OCR
: hal_sdc.h
, halconf.h
- SDC_INIT_OCR_V20
: hal_sdc.h
, halconf.h
- SDC_INIT_RETRY
: hal_sdc.h
, halconf.h
- sdc_lld_init()
: hal_sdc_lld.c
- sdc_lld_read()
: hal_sdc_lld.c
- sdc_lld_send_cmd_long_crc()
: hal_sdc_lld.c
- sdc_lld_send_cmd_none()
: hal_sdc_lld.c
- sdc_lld_send_cmd_short()
: hal_sdc_lld.c
- sdc_lld_send_cmd_short_crc()
: hal_sdc_lld.c
- sdc_lld_set_bus_mode()
: hal_sdc_lld.c
- sdc_lld_set_data_clk()
: hal_sdc_lld.c
- sdc_lld_start()
: hal_sdc_lld.c
- sdc_lld_start_clk()
: hal_sdc_lld.c
- sdc_lld_stop()
: hal_sdc_lld.c
- sdc_lld_stop_clk()
: hal_sdc_lld.c
- sdc_lld_sync()
: hal_sdc_lld.c
- sdc_lld_write()
: hal_sdc_lld.c
- SDC_MMC_SUPPORT
: hal_sdc.h
, halconf.h
- SDC_NICE_WAITING
: hal_sdc.h
, halconf.h
- sdc_set_bus_width()
: hal_sdc.c
- sdc_vmt
: hal_sdc.c
- sdcbusclk_t
: hal_sdc.h
- sdcbusmode_t
: hal_sdc.h
- sdcConnect()
: hal_sdc.c
- SDCD1
: hal_sdc_lld.c
- sdcDisconnect()
: hal_sdc.c
- SDCDriver
: hal_sdc_lld.h
- sdcErase()
: hal_sdc.c
- sdcflags_t
: hal_sdc_lld.h
- sdcGetAndClearErrors()
: hal_sdc.c
- sdcGetInfo()
: hal_sdc.c
- sdcInit()
: hal_sdc.c
- sdcIsCardInserted
: hal_sdc.h
- sdcIsWriteProtected
: hal_sdc.h
- sdcmode_t
: hal_sdc_lld.h
- sdcObjectInit()
: hal_sdc.c
- sdControl()
: hal_serial.c
- sdcRead()
: hal_sdc.c
- sdcStart()
: hal_sdc.c
- sdcStop()
: hal_sdc.c
- sdcSync()
: hal_sdc.c
- sdcWrite()
: hal_sdc.c
- sdGet
: hal_serial.h
- sdGetI
: hal_serial.h
- sdGetTimeout
: hal_serial.h
- sdGetWouldBlock()
: hal_serial.c
- sdIncomingDataI()
: hal_serial.c
- sdInit()
: hal_serial.c
- sdObjectInit()
: hal_serial.c
- sdPut
: hal_serial.h
- sdPutI
: hal_serial.h
- sdPutTimeout
: hal_serial.h
- sdPutWouldBlock()
: hal_serial.c
- sdRead
: hal_serial.h
- sdReadI
: hal_serial.h
- sdReadTimeout
: hal_serial.h
- sdRequestDataI()
: hal_serial.c
- sdStart()
: hal_serial.c
- sdstate_t
: hal_serial.h
- sdStop()
: hal_serial.c
- SDU_READY
: hal_serial_usb.h
- SDU_STOP
: hal_serial_usb.h
- SDU_UNINIT
: hal_serial_usb.h
- sduConfigureHookI()
: hal_serial_usb.c
- sduControl()
: hal_serial_usb.c
- sduDataReceived()
: hal_serial_usb.c
- sduDataTransmitted()
: hal_serial_usb.c
- sduInit()
: hal_serial_usb.c
- sduInterruptTransmitted()
: hal_serial_usb.c
- sduObjectInit()
: hal_serial_usb.c
- sduRequestsHook()
: hal_serial_usb.c
- sduSOFHookI()
: hal_serial_usb.c
- sduStart()
: hal_serial_usb.c
- sdustate_t
: hal_serial_usb.h
- sduStop()
: hal_serial_usb.c
- sduSuspendHookI()
: hal_serial_usb.c
- sduWakeupHookI()
: hal_serial_usb.c
- sdWrite
: hal_serial.h
- sdWriteI
: hal_serial.h
- sdWriteTimeout
: hal_serial.h
- SEMAPHORE_DECL
: chsem.h
, nil/include/ch.h
- semaphore_t
: chsem.h
, nil/include/ch.h
- send_command_R1()
: hal_mmc_spi.c
- send_command_R3()
: hal_mmc_spi.c
- send_hdr()
: hal_mmc_spi.c
- sens_get_axes_number()
: bmp085.c
- sens_read_cooked()
: bmp085.c
- sens_read_raw()
: bmp085.c
- sensorGetChannelNumber
: hal_sensors.h
- sensorReadCooked
: hal_sensors.h
- sensorReadRaw
: hal_sensors.h
- SERIAL_BUFFERS_SIZE
: halconf.h
, hal_serial.h
- SERIAL_DEFAULT_BITRATE
: hal_serial.h
, halconf.h
- SERIAL_USB_BUFFERS_NUMBER
: halconf.h
, hal_serial_usb.h
- SERIAL_USB_BUFFERS_SIZE
: hal_serial_usb.h
, halconf.h
- SerialDriver
: hal_serial.h
- SerialUSBDriver
: hal_serial_usb.h
- set_address()
: hal_usb.c
- SIZEOF_PTR
: chtypes.h
- SPI_ACTIVE
: hal_spi.h
- SPI_COMPLETE
: hal_spi.h
- spi_lld_abort()
: hal_spi_lld.c
- spi_lld_exchange()
: hal_spi_lld.c
- spi_lld_ignore()
: hal_spi_lld.c
- spi_lld_init()
: hal_spi_lld.c
- spi_lld_polled_exchange()
: hal_spi_lld.c
- spi_lld_receive()
: hal_spi_lld.c
- spi_lld_select()
: hal_spi_lld.c
- spi_lld_send()
: hal_spi_lld.c
- spi_lld_start()
: hal_spi_lld.c
- spi_lld_stop()
: hal_spi_lld.c
- spi_lld_unselect()
: hal_spi_lld.c
- SPI_READY
: hal_spi.h
- SPI_SELECT_MODE
: halconf.h
, hal_spi.h
- SPI_STOP
: hal_spi.h
- SPI_SUPPORTS_CIRCULAR
: hal_spi_lld.h
- SPI_UNINIT
: hal_spi.h
- SPI_USE_CIRCULAR
: halconf.h
, hal_spi.h
- SPI_USE_MUTUAL_EXCLUSION
: hal_spi.h
, halconf.h
- SPI_USE_WAIT
: hal_spi.h
, halconf.h
- spiAbort()
: hal_spi.c
- spiAbortI()
: hal_spi.c
- spiAcquireBus()
: hal_spi.c
- spicallback_t
: hal_spi_lld.h
- SPID1
: hal_spi_lld.c
- SPIDriver
: hal_spi_lld.h
- spiExchange()
: hal_spi.c
- spiIgnore()
: hal_spi.c
- spiInit()
: hal_spi.c
- spiObjectInit()
: hal_spi.c
- spiPolledExchange
: hal_spi.h
- spiReceive()
: hal_spi.c
- spiReleaseBus()
: hal_spi.c
- spiSelect()
: hal_spi.c
- spiSelectI
: hal_spi.h
- spiSend()
: hal_spi.c
- spiStart()
: hal_spi.c
- spiStartExchange()
: hal_spi.c
- spiStartExchangeI
: hal_spi.h
- spiStartIgnore()
: hal_spi.c
- spiStartIgnoreI
: hal_spi.h
- spiStartReceive()
: hal_spi.c
- spiStartReceiveI
: hal_spi.h
- spiStartSend()
: hal_spi.c
- spiStartSendI
: hal_spi.h
- spistate_t
: hal_spi.h
- spiStop()
: hal_spi.c
- spiUnselect()
: hal_spi.c
- spiUnselectI
: hal_spi.h
- st_lld_get_alarm()
: hal_st_lld.h
- st_lld_get_counter()
: hal_st_lld.h
- st_lld_init()
: hal_st_lld.c
- st_lld_is_alarm_active()
: hal_st_lld.h
- st_lld_set_alarm()
: hal_st_lld.h
- st_lld_start_alarm()
: hal_st_lld.h
- st_lld_stop_alarm()
: hal_st_lld.h
- start_p_measurement()
: bmp085.c
- start_t_measurement()
: bmp085.c
- stGetAlarm()
: hal_st.c
- stGetCounter
: hal_st.h
- stInit()
: hal_st.c
- stIsAlarmActive
: hal_st.h
- stkalign_t
: chcore.h
- streamGet
: hal_streams.h
- streamPut
: hal_streams.h
- streamRead
: hal_streams.h
- streamWrite
: hal_streams.h
- stSetAlarm()
: hal_st.c
- stStartAlarm()
: hal_st.c
- stStopAlarm()
: hal_st.c
- sync()
: hal_mmc_spi.c
- sysinterval_t
: nil/include/ch.h
, chtime.h
, osal.h
- syssts_t
: osal.h
, chtypes.h
- system_debug_t
: chsystypes.h
- systime_t
: chtime.h
, nil/include/ch.h
, osal.h
