hal.c
18  * @file hal.c
19  * @brief HAL subsystem code.
21  * @addtogroup HAL
27 /*===========================================================================*/
28 /* Driver local definitions. */
30
32 /* Driver exported variables. */
34
36 /* Driver local variables and types. */
38
40 /* Driver local functions. */
42
44 /* Driver exported functions. */
46
47 /**
48  * @brief HAL initialization.
49  * @details This function invokes the low level initialization code then
50  * initializes all the drivers enabled in the HAL. Finally the
51  * board-specific initialization is performed by invoking
52  * @p boardInit() (usually defined in @p board.c).
53  *
54  * @init
55  */
56 void halInit(void) {
57
58  /* Initializes the OS Abstraction Layer.*/
59  osalInit();
60
61  /* Platform low level initializations.*/
62  hal_lld_init();
63
64 #if (HAL_USE_PAL == TRUE) || defined(__DOXYGEN__)
65 #if defined(PAL_NEW_INIT)
66  palInit();
67 #else
68  palInit(&pal_default_config);
69 #endif
70 #endif
71 #if (HAL_USE_ADC == TRUE) || defined(__DOXYGEN__)
72  adcInit();
73 #endif
74 #if (HAL_USE_CAN == TRUE) || defined(__DOXYGEN__)
75  canInit();
76 #endif
77 #if (HAL_USE_CRY == TRUE) || defined(__DOXYGEN__)
78  cryInit();
79 #endif
80 #if (HAL_USE_DAC == TRUE) || defined(__DOXYGEN__)
81  dacInit();
82 #endif
83 #if (HAL_USE_EXT == TRUE) || defined(__DOXYGEN__)
84  extInit();
85 #endif
86 #if (HAL_USE_GPT == TRUE) || defined(__DOXYGEN__)
87  gptInit();
88 #endif
89 #if (HAL_USE_I2C == TRUE) || defined(__DOXYGEN__)
90  i2cInit();
91 #endif
92 #if (HAL_USE_I2S == TRUE) || defined(__DOXYGEN__)
93  i2sInit();
94 #endif
95 #if (HAL_USE_ICU == TRUE) || defined(__DOXYGEN__)
96  icuInit();
97 #endif
98 #if (HAL_USE_MAC == TRUE) || defined(__DOXYGEN__)
99  macInit();
100 #endif
101 #if (HAL_USE_PWM == TRUE) || defined(__DOXYGEN__)
102  pwmInit();
103 #endif
104 #if (HAL_USE_QSPI == TRUE) || defined(__DOXYGEN__)
105  qspiInit();
106 #endif
107 #if (HAL_USE_SERIAL == TRUE) || defined(__DOXYGEN__)
108  sdInit();
109 #endif
110 #if (HAL_USE_SDC == TRUE) || defined(__DOXYGEN__)
111  sdcInit();
112 #endif
113 #if (HAL_USE_SPI == TRUE) || defined(__DOXYGEN__)
114  spiInit();
115 #endif
116 #if (HAL_USE_UART == TRUE) || defined(__DOXYGEN__)
117  uartInit();
118 #endif
119 #if (HAL_USE_USB == TRUE) || defined(__DOXYGEN__)
120  usbInit();
121 #endif
122 #if (HAL_USE_MMC_SPI == TRUE) || defined(__DOXYGEN__)
123  mmcInit();
124 #endif
125 #if (HAL_USE_SERIAL_USB == TRUE) || defined(__DOXYGEN__)
126  sduInit();
127 #endif
128 #if (HAL_USE_RTC == TRUE) || defined(__DOXYGEN__)
129  rtcInit();
130 #endif
131 #if (HAL_USE_WDG == TRUE) || defined(__DOXYGEN__)
132  wdgInit();
133 #endif
134
135  /* Community driver overlay initialization.*/
136 #if defined(HAL_USE_COMMUNITY) || defined(__DOXYGEN__)
137 #if (HAL_USE_COMMUNITY == TRUE) || defined(__DOXYGEN__)
138  halCommunityInit();
139 #endif
140 #endif
141
142  /* Board specific initialization.*/
143  boardInit();
144
145 /*
146  * The ST driver is a special case, it is only initialized if the OSAL is
147  * configured to require it.
148  */
149 #if OSAL_ST_MODE != OSAL_ST_MODE_NONE
150  stInit();
151 #endif
152 }
153
154 /** @} */
void i2cInit(void)
I2C Driver initialization.
Definition: hal_i2c.c:59
void cryInit(void)
Cryptographic Driver initialization.
Definition: hal_crypto.c:56
void extInit(void)
EXT Driver initialization.
Definition: hal_ext.c:56
void hal_lld_init(void)
Low level HAL driver initialization.
Definition: hal_lld.c:56
void icuInit(void)
ICU Driver initialization.
Definition: hal_icu.c:56
void i2sInit(void)
I2S Driver initialization.
Definition: hal_i2s.c:56
void uartInit(void)
UART Driver initialization.
Definition: hal_uart.c:56
void dacInit(void)
DAC Driver initialization.
Definition: hal_dac.c:56
void sduInit(void)
Serial Driver initialization.
void sdInit(void)
Definition: hal_serial.c:135
void sdcInit(void)
SDC Driver initialization.
Definition: hal_sdc.c:542
void spiInit(void)
SPI Driver initialization.
Definition: hal_spi.c:56
void gptInit(void)
GPT Driver initialization.
Definition: hal_gpt.c:56
void pwmInit(void)
PWM Driver initialization.
Definition: hal_pwm.c:56
void stInit(void)
ST Driver initialization.
Definition: hal_st.c:60
void halInit(void)
HAL initialization.
Definition: hal.c:56
void usbInit(void)
USB Driver initialization.
Definition: hal_usb.c:270
void wdgInit(void)
WDG Driver initialization.
Definition: hal_wdg.c:56
#define palInit()
PAL subsystem initialization.
Definition: hal_pal.h:370
void canInit(void)
CAN Driver initialization.
Definition: hal_can.c:56
void rtcInit(void)
RTC Driver initialization.
Definition: hal_rtc.c:67
void osalInit(void)
OSAL module initialization.
Definition: osal.c:63
void mmcInit(void)
MMC over SPI driver initialization.
Definition: hal_mmc_spi.c:383
void macInit(void)
MAC Driver initialization.
Definition: hal_mac.c:64
void qspiInit(void)
QSPI Driver initialization.
Definition: hal_qspi.c:56
void adcInit(void)
ADC Driver initialization.
Definition: hal_adc.c:56
